Steel All-road frames
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
It sucks that production steel bikes are generally so overbuilt these days, makes the "steel is real...heavy" thing a self-fulfilling prophecy. @Spoonrobot, could you say more about the "high value legal proceedings"? Where there some frame failures that have the manufacturers scared?
I remember a few posts in the Framebuilders forum about how the testing puts unusual forces on forks, but I'd have to dig.
Seems like you have to go vintage or custom to get lightweight steel...
RUSA #7498
Originally Posted by noglider
Likes For ThermionicScott:
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
Thanks for the suggestion- ive seen it before. There is a frustratingly limited amount of worthwhile youtube content featuring Ritchey for someone who really loves the history of him/his company when put into context and comparison with the market.
Liked 2,563 Times
I don't think it's the frames that are the issue, it's the other items being updated and having an outsize effect. Like full-carbon forks for off-road bikes almost require an OS steerer to meet testing requires a OS headtube which requires a different TT/DT butting profile. All of which is stiffer and heavier. It's funny because the marketing for carbon road race bikes for so long was trumpeting "X% stiffer than last years model!" and now it's steel allroad bikes getting updated and the marketing is "Tapered steerer but it's just as compliant!"
I was thinking specifically of the Trek QR lawsuit, the Cannondale fork one that's currently in litigation and the nexus found to include Giant Taiwan in a domestic product liability case in the USA a few years ago. There was some wheel ejection lawsuit(s) as well but I can't remember enough pertinent info to find the ones I was thinking of. I don't have access to any closed source information just stuff that's out there in the open.
Kinda reminds me of hardware/software in computers: they develop faster processors and better memory to cope with more complex code, code bloats because it can, requiring better hardware...
FWIW, here's the thread I was thinking of with regard to tests driving heavier frames. I'm not sure it actually says what I thought it did, but I was getting frustrated when I couldn't find it right away. https://www.bikeforums.net/framebuil...-iso-test.html
Quoted: 1872 Post(s)
Liked 692 Times
Bros! did you all see the Rodeo Labs Flaanimal 5.0? I'm in love!
https://bikepacking.com/news/rodeo-labs-flaanimal-5/
2019 Salsa Warbird
2019 Salsa Warbird
Sunshine
Liked 7,473 Times
https://us.ritcheylogic.com/us_en/outback-frameset
So if you are now looking at steel frames with a carbon fork that are 'roadish' geometry like your Windsor- maybe this would work for you.
It clears 40mm tires, has a lower A-C than most gravel frames so it isnt as 'perched', the geometry definitely wont be upright riding, its relatively light overall, and the front end uses a 1 1/8 steerer instead of the large tapered steerers that are common now. The smaller steerer means a stiffer front end than your Windsor, but not as stiff as the 44mm or tapered head tubes on almost all other steel gravel frames. And geometry definitely is more road oriented with 72-23degree head tube angles, about 66mm of trail, and 73-74 degree seat tube angles.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
(oops, no canti's. Can't have everything a retro-grouch wants).
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 6939 Post(s)
Liked 10,944 Times
OP, have a look at Gunnar. If you fit on their off-the-rack geometry, the frames are fairly reasonable and are available with steel or cf forks. And they have models to fit various "all road" tire sizes, right up to the Hyper-X which will take 700x42.
However, to jump on a theme others have started, that Hyper-X is a beefy frame. Mine is a 58 (custom geo) with 44mm headtube, T/As, and disc brakes, and it's both heavier and stiffer than expected.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Expired Member
Quoted: 3656 Post(s)
Liked 5,392 Times
Likes For shoota:
Liked 692 Times
I've been intrigued by BikesDirect 853 Gravel frameset.
Full Reynolds 853. Disc, thru axels, says capable of 700c*40.
Edit: Fork is Carbon
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 427 Post(s)
Liked 339 Times
Likes For dwmckee:
Quoted: 353 Post(s)
Liked 92 Times
Some gravel models are scarce right now. My shop told me they get at least one call per day asking if they have Rove ST's. Apparently Kona has them on backorder until April 2020.
