Shimano 600 "Triangle" Pedal - Dustcap Removal?
Old 08-08-11, 06:55 PM
delicious
delicious's Avatar
Quoted: 88 Post(s)
Liked 60 Times in 34 Posts
I've got a nice set of Shimano 6207 pedals here that may need a rebuild. They have a plastic dustcap with what looks like a slot for a flathead screwdriver. But the plastic is very deformable. My initial attempts to open it haven't been successful, and I don't want to screw things up.
I searched all around but haven't come up with any guides to opening these aside from "just pop them off."
Does anyone have experience with these? I'd appreciate any assistance!
Velobase picture:
Velobase link: https://velobase.com/ViewComponent.as...=109&AbsPos=11
delicious is offline
Old 08-08-11, 07:02 PM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 2923 Post(s)
Liked 2,914 Times in 1,488 Posts
I suspect it is press fit, with a O ring to hold it in place type of thing.
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Old 08-08-11, 07:07 PM
delicious
delicious's Avatar
Quoted: 88 Post(s)
Yes, there is a thin black O ring. And it doesn't seem to be threaded on. The problem seems to be - how to pop it off without deforming it?
Old 08-08-11, 07:22 PM
brian3069
brian3069's Avatar
Bikes: Raleigh Supercourse
Quoted: 218 Post(s)
Liked 167 Times in 101 Posts
I used a screw driver, popped off with no problem. Matter of fact, it came off so easy I lost one on the next ride.
brian3069 is offline
Old 08-08-11, 07:31 PM
Puget Pounder
Wookie Jesus inspires me.
Puget Pounder's Avatar
Really thin screw driver. You're bound to deform it a little bit.
Puget Pounder is offline
Old 08-08-11, 07:41 PM
randyjawa
randyjawa's Avatar
Quoted: 1372 Post(s)
Liked 1,747 Times in 937 Posts
Betcha there's a lesson there, grasshopper.
In days gone bye, I have used a sturdy and sharp knife to sort of roll the caps off.
The fine edge will find the grove, between the cap and the body of the pedal. Once inserted into the groove, wiggle the knife a little bit and then softly roll the knife to the next new position. Repeat the wiggle, keep moving around the cap, and it should come out without any distortion. Through out the process, you are trying to pull the cap off a wee bit at a time, not pop it off in one fell, and perhaps distorting, swoop.
Don't cut yourself, the O-Ring or the cap!
randyjawa is offline
Old 08-08-11, 08:50 PM
cbresciani
cbresciani's Avatar
Bikes: Colnago C40 HP, De Rosa-Primato, Titus Ti FCR, MOOTS YBB-SL, Pogliaghi Pista
Surprisingly dental floss works too! I used it to pop off the hood emblem on my old BMW.
cbresciani is offline
Old 08-08-11, 09:20 PM
delicious
delicious's Avatar
Quoted: 88 Post(s)
Thanks for everyone's input!
I finally got the cap off, though it isn't so pretty anymore. The key seemed to be a second notch directly across from the most noticeable one. a flathead in there gave me some purchase on the cap.
I tried the knife rolling method before that with little success. There were many different models of triangle pedal, so maybe it works better on some of the others.
The most frustrating thing is that the faint noise the pedal was making is still there after a rebuild. No pitting. Everything looked pristine. I think it may have something to do with the strange plastic seal at the threaded end of the axle.
Old 09-02-11, 07:17 PM
delicious
delicious's Avatar
Quoted: 88 Post(s)
UPDATE!
I just figured out a good technique for getting these caps off. The key is to remove the thin plastic o-ring first, or at least get it out of the way. Use the indented slot to do this. It allows much more purchase to get underneath the edge. It may deform the ring a bit, but it's better than the alternative, which almost certainly will - and the press fit cap too.
Also, a masked man passed along this tip:
The caps are a press fit but sometimes they are tough to get
out without breaking. The plastic gets brittle with age and
also tends to shrink a bit and so loss of the caps is a problem.
Try to get the edge of a credit card or something else plastic
under the edge or in the little slot made for the purpose of
prying them out. After youl get it started, work around the
edge of the cap and it will come off.
These caps are expensive to replace. It's often cheaper to buy
a complete set of peds with the caps than to replace the caps
alone but that is a big waste. I've got two sets with my own
replacement caps, fashioned from pliable, black plastic end
caps made for the ends of iron/aluminum patio chair legs. They
are available in sets of for for $2 at ACE Hardware. In my
store, there are two sizes and the bigger size is correct.
These need to be cut down by about a quarter inch so they don't
protrude too much when pressed rully into place. They are also a
loose fit so I take a slice of old skinny inner tube and
stretch it around the trimmed cap and just "screw" it into
the ped recess. The inner tube not only insures a secure fit
but insures a watertight fit as well.
When trimming the caps (I use nail scissors) be sure not to
trim too much or the cap could interfere with the bearings/axle.
If you have trouble pressing them in, try lubricating the
inner tube with something like the tiniest bit of grease you
used for the bearings (I use synthetic Finish Line bearing
grease with Teflon).
I've not lost one of these caps yet and I ride every day,
year 'round and long on weekends.
Old 12-18-18, 11:44 AM
robertorolfo
robertorolfo's Avatar
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times in 113 Posts
Posting in this old thread to offer some advice from personal experience. If your caps are on tight, and mine most certainly were, then there is basically no way to effectively pry them without damaging the cap itself. I tried and knife and gentile, progressive prying around all sides, but the only way to generate enough force involved deforming the caps to some extent.
So once I got frustrated enough, and the cap was already considerably damaged (luckily I have a replacement pair from a cheap second pair of these pedals I bought), I simply decided to get very aggressive. I left the screwdriver as deep in the little slot (the one that is always visible from the start) as possible, and simply hammered at it. This will put a nice little gouge deep in that slot, but the cap will come off and the damage will basically be invisible once the cap is put back on (as opposed to damage around other parts of the cap from prying that cannot be hidden).
To test this technique, I did the same thing on the second pedal from the start: just got the screwdriver end in, prying ever so slightly to get it in nice and deep, and then hammered the end of the screwdriver with repeated low-force blows. The cap popped off and the damage was as limited as I believe it can possibly be. Hope this might help someone down the road.
robertorolfo is offline
Likes For robertorolfo:
Old 12-18-18, 01:39 PM
mixteup
mixteup's Avatar
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times in 27 Posts
I just did a set of these - Like they all said, pry, wedge, and deform.
The worst parts of the edge can be dressed a bit with a fine file -
Just hammer them back in, sigh, and get on with life - At least the pedals will turn smoothly, now
mixteup is offline
Old 12-19-18, 07:49 AM
Classtime
Classtime's Avatar
Quoted: 1946 Post(s)
Liked 2,004 Times in 1,105 Posts
These are 1050 pedals. The "slots" are at 3 and 9 o'clock.
Classtime is offline
Old 12-19-18, 02:05 PM
mgopack42
Bikes: 2020 Argon 18 Krypton Pro, 1985 Masi 3V Volumetrica, 3Rensho Super Record Aero, 2022 Trek District 4.
Quoted: 343 Post(s)
Liked 423 Times in 206 Posts
Take them off, 3D scan them, and print a bunch in metal and sell them to guys like me that need replacements!
I am pretty sure these pedals are famous for the dust caps falling out all by them selves!
mgopack42 is offline
Old 04-30-20, 10:53 AM
Piff
Piff's Avatar
Quoted: 791 Post(s)
Liked 741 Times in 406 Posts
I decided to overhaul a pair of these and this technique works really well! Also, I didn't have the special pedal locknut tool when servicing my pedals. I ended up tightening down the locknut and then backing off the race until they were tight​​​​​​ against each other. I got lucky and the pedals turn smoothly. If I had originally tightened the locknut too far or too little I could see myself having tighten and loosen these little nuts many times to get it just right.
Piff is offline
Likes For Piff:
hchoy
Bicycle Mechanics
3
10-18-14 10:19 AM
Miele Man
Classic & Vintage
17
07-06-14 03:46 PM
offrdmania
Singlespeed & Fixed Gear
29
01-17-13 12:24 AM
s4one
Road Cycling
0
10-14-11 11:54 AM
Redline927
Road Cycling
6
01-31-10 11:37 AM
