1950s? SEARS ROEBUCK 5 SPEED MADE IN AUSTRIA
Found this beauty at local thrift store & am ding to find out more about it! First thing I saw was the badge with 'Made in Austria', then the fancy lugs around the neck & then it has a orange disc behind the rear sprockets with '5 Speed Selector'.
Finally it looks like a 1960s bike to me, but it has 2 bike licenses on the down tube that are dated 1957!
I also love the horn, waffle pedals & a cool light that runs from the front tire. Plus, it has a old wood handle pump that came with it and a small tool kit (pliers and screwdriver) - it even had an old chain with a small lock - and the key in the lock!
The bike looks like someone put it away & forgot about for 60+ years!
What do I have here? What is it worth?
Thanks, I appreciate any help.
Quoted: 3824 Post(s)
Liked 3,372 Times
value as it sits ~$40.
dating: suspect mid-'60's. "57" on license sticker may not be a date.
manufacturer is steyr/styria of graz.
https://www.classicrendezvous.com/Austria/AD.htm
https://en.wikipedia.org/wiki/Puch
handsome bell!
handsome bell!
Quoted: 1361 Post(s)
Liked 425 Times
I agree with you all the way and just as confused with the license stickers. Is it possible the city had an excess or bulk quantity and simply administered for later years?
I would have bought the bike just to have the bell
Liked 3,372 Times
wrt date/license -
the printing of the words "bicycle license" and "_____-on hudson" is done differently than the numeral "57." likely as not this small hudson valley community did not license a great many bicycles in pre-boom times. those stickers may have come on a roll and and were numbered sequentially. so the number 57 may represent the 57th bike registered in a given annum.
edit: looks like licensing agency was the village of Croton-On-Hudson.
https://www.hudsonriver.com/croton-on-hudson
machine may have been brought to florida by a retiree...
Well, I sold the bike for $100, but I kept the horn & the headlight. The headlight is a vintage Sanyo 6v-3w and has a cool kind of flat look to it's round shape (as opposed to the torpedo look); almost like the WWII anti-aircraft or james cagney prison wall spotlights! - It is marked 'Made in Japan' as you would expect. - any value?
The pleasant surprise was the bell - which is marked 'Made in Germany' but no name. Is it a Peugeot bell? Any value to it?
Thanks again for all the help
Liked 3,372 Times
wrt bell-
the other side of the trigger is stamped with a logo which will be a clue as to manufacturer.
Quoted: 795 Post(s)
Liked 1,805 Times
I would say the bike is from the early 70's, based on the Shimano parts and red dork disc and worth about $50 in it's current rough shape
Thanks! 1 side says Made in Germany & the other side has a image of a crown? Any help with who the crown represents would be greatly appreciated!!
Still learning
Quoted: 795 Post(s)
Liked 1,805 Times
Elitest Murray Owner
Bikes: 1972 Columbia Tourist Expert III, Columbia Roadster
I don't know about the bell, but the light is not that old, and not worth very much. Maybe $10-$15. I have several older, better made block generators, and I've paid little more than that for those ones.
The bike itself, I'd have not paid even $50 for it personally. If it had been all original and well cleaned I could see $100, but I'd have felt ripped off otherwise. The Lark derailleur is probably not original, the gear lever does not look like a Shimano unit. Probably originally had a Huret Alvit.
Liked 3,372 Times
https://farm8.staticflickr.com/7106/7...42110d00_z.jpg (file too large for posting)
wrt dynamo -
does skirtguard have markings to indicate it is from the dynamo manufacturer or does it have other markings, no markings?
just curious as these are sometimes included with dynamo and sometimes an after market item.
You gonna eat that?
That's actually a 10 speed. I had one like it. There's a cetrifugally operated 2-speed built into your rear hub. You can control the gear with the shifter but when you get above a certain speed (usually fast 5th gear), the internal hub will shift up. When you stop it shifts back down. I had one of these a while ago and it was wild. I loved the combination.
That version of the Shimano Lark derailleur was introduced in 1969.
I stop for people / whose right of way I honor / but not for no one.
Liked 3,372 Times
had wondered about the meaning of the unique markings on the spoke protector disc.
You gonna eat that?
Bikes: too many
Quoted: 413 Post(s)
Liked 236 Times
I could see the bell go for $20, polished up. Maybe more. Maybe significantly more, to the right buyer. There's not really a set market for such things, but one could take a look at online auction sights and get some idea. Doesn't look like an official Peugeot item, to me, but would certainly be at home on one.
Liked 3,372 Times
Binky
0
05-03-13 12:49 PM
Fleck
10
08-03-12 10:54 AM
