So I finally got a power meter
#51
Has a magic bike
Quoted: 4456 Post(s)
Liked 425 Times
Or maybe Strava is assigning TSS for my mtb rides on HR. I could see that being an underestimation because what’s really fatiguing for me on the mtb are the microbursts of power to say get over a rock or root. Those happen for such short bursts of time that they don’t necessarily elevate HR (unless you string together a series of such efforts) so I could see Strava “missing” the stress of these microbursts in the absence of power data, and significantly underestimating the physiologic impact. Especially for someone like me, who is relatively fit (ie resistant to HR elevation) but not strong (so the microburst of effort is proportionately way higher over threshold than your ‘typical’ ie male mountain biker).
I think this explanation makes more sense than the speed idea I floated in my previous post. But regardless, it’s pretty obvious and not something that it’s too hard to get past intellectually, despite the numbers you see calculated by the software.
#52
Quoted: 1975 Post(s)
Liked 232 Times
I honestly don't even bother carefully analyzing TSS, as rubiksoval put it above, it isn't all that important as I've trained with power more. What does it really tell you? You trained hard? Your legs kinda tell you that. Your TSB is super negative? You should feel that too. So while the PMC is a good check, small differences in TSS/NP from different algorithms won't substantially make a difference in quantifying training. How you hit the intervals for the day or for the week and how they compare to the following week or following month etc are where the PM is helpful
#53
Quoted: 18883 Post(s)
Liked 10,646 Times
Looking this up, it appears TSS is based on total elapsed time of the .FIT file and what you have displayed on your Garmin is irrelevant. Which I suppose is why Coach’s instructions are to turn the Garmin off entirely for any lunch-length ride pauses and why he’s never commented one way or the other on the use of autopause otherwise.
This does not address Seattle’s 200 stoplight paradigm but that’s not a scenario that applies to me so not of huge relevance for my situation.
This is what "the beer and burrito rule" is about. If you stopped long enough to enjoy those, it's a new ride when you start again. To avoid messing your TSS up.
I do enough non-bike exercise that an HR based training load works better for me than TSS.
#54
Liked 10,646 Times
I've got a bunch of loops I do where I never leave city limits. Get out into the residential zones where the nice parks are, and the lights aren't every block anymore but still pretty common. I've never counted, and now I'm curious but not enough to actually count them... Over a 3 or 4 hour ride that night not be too far off. They're not all red though.
#55
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
Now that I have a PM for my single, I'll use power for TSS on singles, still using HR for the tandem and everything else. I would think that TSS should approximately equal hrTSS, except be a bit more accurate in terms of kj. As the PMers note, HR at the same effort can vary with exhaustion, hydration, and blood sugar. TSS tells one more about kj, but less about one's physiological state. On my Ohanapecosh ride a few weeks ago, before I had the PM, Strava estimated my power on Cayuse and White passes as exactly the same, though my HR on White was 6 beats higher. OTOH there was a slight headwind on White, so maybe that wasn't all exhaustion. I did leave it all on the road, had to lie down in the White Pass parking lot, like a Nordic skier. The PM will help resolve these anomalies.
Results matter
Results matter
#57
Liked 10,646 Times
How do you like using it now that you've had it a while?
#58
Liked 1,938 Times
Loving it. For the price, it's totally been worth while. I particularly like it on my fluid resistance rollers. As the fluid heats, resistance goes down, so now I can finally get a better fix on HR drift and thus aerobic fitness. It's also nice to be able to keep a more even effort out on the road. I now have power displayed larger than HR on my Garmin. That says it all, eh? My Garmin is out on my clip-ons, so I don't have that "looking at my stem" thing going on all the time - it's visible in my periphery.
Results matter
Results matter
#59
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4376 Post(s)
Liked 3,013 Times
So I just joined the club. Favero Assioma Duo pedals arrived yesterday. So far, I have one ride on the trainer and one outdoors. Some observations that others may or may not care about:
1. Previously I was measuring power on the trainer with the Kurt Kinetic Inride sensor. It's not truly a power meter and though it's reputation is pretty good, I wasn't sure how accurate the numbers are. It turns out, they are spot on - within a couple of percent. At least, they are when I'm careful with calibration, which means that I ride for 10 minutes to let the rollers warm up before I do the calibration.
2. I have always felt that my right leg was dominant. It just feels stronger. It's one of the reasons I really wanted dual-sided power, as I wasn't confident that single-sided power would be accurate for me. Not so. My L/R balance is about 48%-52%. That's pretty even.
3. Outdoors I had my garmin set to read out instantaneous power. I can see why usually people look at the 3 second average, but it was interesting to see how much the values jump around. I am thinking that this is partly telling me that I have some significant deadspots in my pedal stroke and that I need to be more conscious about pedaling smoothness. On the subject of which, with Cycling Dynamics, there are now actually measurements of pedaling smoothness. I need to learn what these numbers mean.
4. My power spikes sprinting up little hills are more watts than anything I ever produce on the trainer. I guess there's something to be said for the real world.
#60
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
#61
Liked 1,938 Times
Strong hip flexors are good. Ride duration seems to make a difference in pedaling style. Randonneurs and LD racers pedal circles. Short duration riders tend to hammer the downstroke more. Makes sense.
Good article on pedaling by a USAC coach here: https://biketestreviews.com/correct-...s-of-pedaling/
EMG image of muscle usage of a readable size here:
Results matter
Results matter
#62
Bikes: bikes
Liked 1,429 Times
Here we are again. I was pedaling with my shoe uppers for much of my VT1 workout on my rollers today. Going to do it again tomorrow. Pedaled at ~130w, no HR drift over the hour. Maybe I'm not in such poor condition after all. Loving the PM.
I can put out the same watts in tennis shoes. I'm sure most can, save the comfort and control aspect. How would that be?
#63
Liked 3,013 Times
5. I'm surprised at how little power I've been putting out on downhills.
#64
Liked 1,938 Times
https://www.ncbi.nlm.nih.gov/pubmed/21507064
which because of the very short training time, underestimates the benefits it found of pedaling circles.
My usual short endurance rides are 3-4 hours and on a 330 lb. bike. Not everyone goes to such lengths, but why not learn to pedal well and be able to do anything one wants?
If you haven't ridden with them personally, you should watch videos of solo RAAM and 508 riders. They are so smooth.
Results matter
Results matter
#65
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
Over time, I got much better at holding constant power. Even today, I do a local climb that has sections of 8-9% grades, flattish sections and some downhill. During a threshold climb, I find it much easier (perceived effort) to hold power on the steeper grades versus the less steep or flat to downhill sections.
I think it has to do with my muscle composition and how my neurology recruits muscle fibers as speed changes. Even though, I am doing the same cadence, when I am going faster such as on the downhill sections, my neurology is topping up the energy required to keep the bike going at the faster speed to overcome predominantly wind resistance. During the climbing parts, the speeds are slower and I am mostly overcoming the force of gravity which is more constant so the recruitment patterns are different. Hence perceived effort changes as well as resulting fatigue.
For me, the more I practice higher power on flat and downhill terrain, the better I get at doing it. YMMV.
#66
Bikes: bikes
Liked 1,429 Times
You're cherry-picking an extreme outlier that is not in any way relevant to this thread or the post I was responding to (nor do I even agree with your assertion in that context, either, but I digress). In any case, kind of defies the point.
#67
Bikes: bikes
Liked 1,429 Times
Same. That, to me, was the biggest benefit of a power meter: showing the incredible amounts of time I wasn't actually putting out much power when I thought I was "training". A four hour pre-powermeter ride would probably equate to a three hour ride today in terms of kJs/ work performed. Now I typically have less than 10% Z1 time versus 30-40% when I first started checking it with the PM.
gurk700
Road Cycling
39
08-18-17 03:20 PM
whitemax
Road Cycling
44
06-17-17 01:23 PM
