Birdy thread
#2401
Quoted: 14 Post(s)
Afterthought: Using some fibreglass mesh tape such as https://www.amazon.co.uk/APT-Tape-Re.../dp/B09HY1R2V7 instead of wire could be a neater solution. First apply a thin layer of epoxy (the slow setting type might be better) then wrap with tape and apply another layer of epoxy.
#2402
electric birdy
Hello this is my first message.
I have a first or second generation Birdy and I want to put an electric front hub.
I was looking for engines and found one, I would like your opinion, if it will be possible to put that engine in the unusual front fork AKM85SX(F3) lo pueden encontrar en la web site de aikema-e
i cant post link or pics sorry
#2403
Quoted: 575 Post(s)
Liked 119 Times
I see the Touring currently ships with a three speed Sunrace gear hub and a ten-cog 9-32T Sunrace cassette, and have a couple of questions:
1. What are the gear ratios on the gear hub, so I can computer the gear range?
2. Is that gear hub draggy or efficient? I intend to ride that bike in mountains so the less drag the better
3. Is that 9-32T cassette common? Once it's worn, can I easily replace it, with the same model or from eg. Shimano?
Thank you.
Thank you.
#2404
Quoted: 807 Post(s)
Liked 250 Times
This Sunrace hub is not an IGH, its a hub for a cassette, the Riese & Müller Birdy Touring has a pure 10s derailleur transmission (while the Pacific Cycles Birdy Touring is a 3x8s with an IGH, quite confusing same model name for different components).
This Sunrace hub+cassette system is meant for small wheels bikes and is derived from the old Shimano Capreo group. Its proprietary, the hub only accept special Sunrace cassettes (with 10s or 11s) and these proprietary cassette can only be mounted on the special Sunrace hub (and maybe on a Shimano Capreo hub ?), mounting requires a special tool (similar to the Shimano cassette and centerlock disc tool but different).
Its very difficult to find these Sunrace special cassettes as spare parts. (same for the hub but there is usually no need to replace it).
The gear inch range provided by this 9-32t cassette with the Birdy Wheel size is excellent and fit the needs of most users.
For those like me who don't like that transmission, the other possibility is to use a SRAM XD or XDR compatible rear hub (the Birdy rear hub is a standard 135mm OLD hub with 5mm quick release) with a Ethirteen or 3T 11S 9-34t or 9-32t cassette same as mounted on the Helix Superlight.
#2405
Bikes: Spec AWOL comp 2014, Birdy Anthracite, A focus egravel bike
Quoted: 575 Post(s)
Liked 119 Times
This Sunrace hub is not an IGH, its a hub for a cassette, the Riese & Müller Birdy Touring has a pure 10s derailleur transmission (while the Pacific Cycles Birdy Touring is a 3x8s with an IGH, quite confusing same model name for different components).[…] For those like me who don't like that transmission, the other possibility is to use a SRAM XD or XDR compatible rear hub (the Birdy rear hub is a standard 135mm OLD hub with 5mm quick release) with a Ethirteen or 3T 11S 9-34t or 9-32t cassette same as mounted on the Helix Superlight.
#2407
deep maintenance
How do I maintain the rear joint axis? Any person with experience?
I just removed the axis because I noticed that it was run to the side, it was not symmetric,
The axis is a piece of solid metal, nothing in particular but the female axis in the main picture, has NEEDLE ROLLER BEARING and for a piece of nylon and has oxide, is there any replacement for that? icant send picture yet but im shooting for the future
#2409
Quoted: 807 Post(s)
Liked 250 Times
This has some influence when mounting a front derailleur.
#2411
Quoted: 807 Post(s)
Liked 250 Times
If its a Birdy 2, I think there is no grease nipple on the rear swingarm bearing+axle like on the Birdy 3 ? Without that, the only possibility is to dismount the axle.
#2412
yeah no grease nipple, I already dismount the axle cleaned and put some silicone wd40 spray but i dont know if is good solution or is better grease...
#2414
Schwinnasaur
I have actually brought old 3 speed hubs back to life by feeding them WD40 and then when they start to work putting them back on oil. I think they get sludgy and WD40 breaks that up. The old hubs with ports seemed to be designed to leak.
#2415
Quoted: 8 Post(s)
Liked 9 Times
A Sunrace 9 speed cassette 9-28 is available here:
https://www.somafabshop.com/shop/590...2340#attr=4801
Using Shimano cogs, it should be possible to modify it to 9-32.
#2418
Quoted: 575 Post(s)
Liked 119 Times
Before I order one, for those of you how bought H&H's Front Carrier Block for Brompton Bag Lug Adapter, can you confirm that
1. The inner distance between the two flanges is 71.12 mm
2. If need be, each flange can be rotated 180° to fit a non-Birdy folder?
And what's the height/thickness of each flange?
Thank you.
Thank you.
#2419
Schwinnasaur
Thank you.
Thank you.
#2421
Birdy 10D head stem wanted
I have a Birdy Gen II with 21D sport stem and would like to replace it with the comfort stem. Does anyone have one they are willing to sell or swap?
Thanks
Thanks
#2422
Bikes: 2014 Birdy Disc Polished Silver 9sp; 2013 Downtube Nova; 2008 Specialized Sequoia Elite
Hi all,
My Birdy folding hinge lever keep coming loose (pops up) as I ride. How do I adjust it? It is as simple as adjusting some bolt? I have a Birdy Gen 2. Thanks all.
Pictured is my Brompton T Line and by Birdy Gen 2.
#2423
I would try tightening the longitudinal bolt that runs from the cam to the front of the hinge. Do it in quarter turn increments. It should feel harder to close the locking lever. But not too hard.
#2424
