Campagnolo BB spindle
Quoted: 1199 Post(s)
Liked 1,354 Times
So earlier today i had an issue with the record cranks and the 70-111 BB spindle. It caused the inner chainring to rub against the frame.
My question is can I use a 68-SS-114 or does it have to be a 70-114?
Frame is a Gios Super Record with Italian BB shell. I have the cups just need help with the spindle.
Thanks
Thanks
Quoted: 76 Post(s)
Liked 76 Times
sheldon brown says on his website he's ran campy cranks on non-campy bbs, and the other way around as well, and never really had any trouble. what you have to look out for is the crank bolt bottoming out before the arms are tight when using non-campy cranks on a campy bb (i may have that backwards, i've slept since the last time i played with this stuff). i kinda ran into this a little when putting chorus cranks on a specialized frame, but i ended up just buying an origin8 campy bb with the right spindle width.
Liked 1,354 Times
All parts in this setup are campy including bolts.
I think better asked is if theres a huge difference between a 68ss and 70ss spindle. I figured it was only the cups tha. were different.
Quoted: 786 Post(s)
Liked 520 Times
You will need to stick with an Italian spindle designed for a 70mm bottom bracket. If the cranks are pre 1978 then an Italian width Record spindle should be 113 mm. If later, then 115.5 mm. I assume you have "thick cups" with spiral rifling around the holes? If not, you'll need a spindle designed for them, like a GS. But all spindles would be marked "70", and not "113", etc.
Pics would help.
Pics would help.
Quoted: 1856 Post(s)
Liked 664 Times
Pics would help.
Pics would help.
If you set the two spindles on the table, you can compare the distance between the bearing races on the two spindles. The same set of cups need to enable to match that space, but the space is up to 2 mm narrower.
There could be other considerations based on pre-CPSC versus post-CPSC, but the basic issue is that the spindle is precisely sized to make a pair of bearings that can be set correctly in an imprecise (compared to bearings) bearing shell, the BB shell. The cups are sized and precisely made to match the spindle in the frame, when you use the right ones.
There is a pretty good online reference for Campy BB compatibility. I haven't used any others and was not steered wrong. It's by Greg Parker from his LLC website, Untitled document
Here's the link Vintage Bicycle Parts : Bottom Brackets.
It looks weird and may not be secure, but you're just going to look at the table at the bottom of the page given by the link. It gives selection guidelines and lists the expected results in case of mismatches. I used that table to get the year and model of the NR double on my 1980 Cali Masi, and the BB parts lined up exactly as the table said. And when I assembled them back onto the frame the arm offsets were identical left to right, the chainline was perfect, and Q was below 150 mm. I'd say some at least of what's in that table is completely correct.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
There are many variables that make Campagnolo bottom brackets a hot mess. Besides the 68 and 70mm shell widths, there are CPSC-mandated design changes that appeared around 1977, "thick" and "thin" cups, "male" and "female" axles, 1/4" balls for most but 3/16" balls for Super Record and C-Record, and then a change to symmetrical spindles in the mid-80s. Campagnolo-USA's "Record News" newsletter published an article describing the issues:
https://www.os2.dhs.org/~john/campy-BB-specs.pdf
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
+1 for what @JohnDThompson and @road_Fan said above, I had the same problem as the OP with my Tommasini Prestige. I found a 116mm Record spindle on eBay that had the correct Italian BB shell spacing for the bearings and kept the drive side CPSC compliant Record spider proud of the cup face. Those thicker cups and the numerous choices in spindle configurations that have been mixed over the years can really cause some headaches. John's link the the Campagnolo newsletter is one of the best explanations and solutions there is. Sutherlands also has some good details in the relative section of the Third Edition.
Bill
Bill
Semper Fi, USMC, 1975-1977
Liked 1,354 Times
Sweet mother of Tulio Campagnolo thats alot of info to process but much appreciated.
The 68 English and 70 Italian difference I understand but its the spindle length is what has me questioning spindle compatibility.
I see now theres alot more that factorss into getting the correct spindle.
Ill post pics shortly of bottom bracket
Bikes: Numerous
Quoted: 1677 Post(s)
Liked 3,096 Times
Good info above and I will only add to make it even more complex is that your 111 spindle is likely intended for use with a C Record era crank that looks like or near like this one.
Liked 1,354 Times
You are correct sir. I did come across some info stating my spindle was intended for C record cranks or track.
Bikes: 75 Raleigh Gran Sport, 88 Bridgestone RB3, 72 Raleigh Super Course, 75 Jeunet 620, 95 Fuji Team
Quoted: 80 Post(s)
Liked 21 Times
Old fart
Liked 3,400 Times
Correct. Most Campagnolo BB axles are "female" in that a bolt is threaded into the axle to mount the crank arms. After breakage issues with the first generation of titanium Super Record axles, Campagnolo changed the Super Record axle to a "male" axle, onto which a nut is threaded to mount the crank arms.
Quoted: 3464 Post(s)
Liked 2,829 Times
all else being equal, the 70 mm spindles have the same Overall length as their 68 mm brothers BUT the races are positioned 1mm more outboard per side, wider shell need a wider stance.
Liked 1,354 Times
Pics would help.
Pics would help.
Old fart
Liked 3,400 Times
That looks like a C-Record bottom bracket, which uses 14 3/16" balls. Can you count them to be sure? If it is C-Record, your axle options are limited, as all other Campagnolo bottom brackets (except Super Record) use 1/4" balls.
68-SS-114 ? breaking down the numbers as I read their catalogs
68 is BB shell width , SS is Strada (road)
114 ? IDK that is usually rear hub width , chainline .. 120 is 5 speed
70-SS-120 would be classic 5 speed road
70-P (pista, Track ) 120 ( there were 110 wide track frames. # 17 catalog does not show any italian width
[Catalog No.17 was published in 1974]
Semper Fi
Liked 358 Times
From Classic Rendezvous, Mark Petry's explanation of the CPSC spindle and length/interference problems, and how to read the markings of the spindles.
Mark Petry's Primer: Some Cool-to-Know NR/SR Facts....
The 120 has nothing to do with rear frame spacing for drivelines.
From the pictures its clear that the crank arm/spider are going to hit the cup faces before the tapers bottom out and take. I too learned this the hard way and I have a feeling that you have a mixed generation bottom bracket possibly. A C-Record spindle and a pair of Record cups maybe, or as John said, a C-Record set of cups, and perhaps incorrect balls and spindle. These get mixed together by folks that are parting out bikes and doing the ebay selling, or at jumbles.
Bill
Bill
Liked 1,354 Times
Im figuring to use a Campy 70-SS 113 spindle with the same cups.
Old fart
Liked 3,400 Times
Ok, eleven balls makes it easier. I suspect an Athena 114mm spindle would give you the clearance you need:
https://www.os2.dhs.org/~john/camp-qu...h-spindles.pdf
Otherwise, a non-shouldered cartridge like Phil Wood would allow you to set the chainline where you need it to be.
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
When all this stuff was made, engineers or manufacturers were not worrying about , (or probably even imagining) a bunch of old(mostly) guys(mostjy) trying to mix and match them together half a century later. And I gotta say back then, neither was I...
Quoted: 786 Post(s)
Liked 520 Times
What markings are on your spindle? Here's my cheat sheet:
NR/SR-
Italian:
Double -Pre CPSC ('78): 113mm. Post: 115.5
Triple - Pre: 118. Post: 124
English:
Double - Pre: 112. Post: 114.5
Triple - Pre:117. Post: 123
Late-80s-90s markings:
Spc -- ≻ c - record
Ssa -- ≻ croce d'aune
Ssb -- ≻ chorus
Ssg -- ≻ athena
NR/SR-
Italian:
English:
Spc -- ≻ c - record
Ssb -- ≻ chorus
Ssg -- ≻ athena
Correct me if I'm wrong, but I believe the C-Record BB used 11 7/32" balls. The Record Pista used 14 3/16".
Have we established the OP is using a C Record Crank set (or the same era lower tiered ones)?
