White Lightning Clean Ride -- How to apply?
This chain lube comes highly recommended both here and on Amazon, but I'm finding it a royal pain to use. I shake it well but as soon as I start to apply, the tip clogs and I have to shake again.
Any tips?
Any tips?
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 339 Post(s)
Liked 230 Times
Wow, never had that problem, maybe try running something down the tip to enlarge the hole. My only issue is shaking the stuff enough to re dissolve all the solids on the bottom.
You did remind me though that I was gong to wipe down and lube my chain before todays ride....Thanks.
edit...I thought about it, and I do tend to shake it back up, after every couple dozen links.
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
Shake it. Violently and for a loooong time. Then shake it some more. Beware if you attempt to enlarge the dripping hole -- it goes from finicky to pouring out rapidly with a very slight enlargement. Also, echoing Wileyrat, shake it during application too.
-Kedosto
-Kedosto
Interocitor Command
I have the quart size of Clean Ride so I draw some up into an oral syringe and apply 1 drop per roller. Haven't had any problems with application. Maybe the tip of the oral syringe has a larger diameter than the spout your using?
In keeping with the other directions on the bottle, don't use in under 45F. You could bring your bike inside to clean and lube the chain, but usually I use something messier in the winter. Anyway, WL doesn't protect very well in wet/slushy conditions.
Quoted: 564 Post(s)
Liked 350 Times
I love the stuff, but it doesn't love me back.
It works well as a chain lube and definitely keeps the chain cleaner than just about anything else I've ever heard of. Unfortunately, it sheds constantly. Small flecks of black debris flake off the chain all over the floor of my office and on my carpeted floor of my garage. After tracking one too many black specks into the house I decided I'd rather live a full, rich life than face the wife again over a spot on the floor.
But, shake it well before and during use and you're good to go.
-Kedosto
-Kedosto
Quoted: 5224 Post(s)
Liked 3,585 Times
if it needs to be mixed & there's a low temp warning, then you can probably help the mixing by floating it in a plastic tub of warm water before shaking it
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
I use it year round on the beater. When it's cold out, it's cold in the garage. If I need to lube the chain, I put the bottle in my pants (maturity reminder...) and work on something else. After 5 or so minutes, I then lube the chain until the nozzle clogs. Repeat.
that sounds....
that sounds....
Likes For Ferrouscious:
Quoted: 507 Post(s)
Liked 237 Times
I have Finish Line dry teflon lub which does this. I turn it right side up (tip to the ceiling), then squeeze the bottle to clear the nozzle. You could squeeze either on the flat sides (pushes air out) or on the narrow sides (widens the bottle and sucks air in). Sometimes I have to do this 4-5 times.
Clark W. Griswold
Quoted: 4367 Post(s)
Liked 4,006 Times
Never had the problem when I used Clean Ride. Maybe try dipping the sealed shaken bottle in some warm water, that could help. You could also enlarge the hole at the tip and see if that helps.
I have used Clean Ride in the past and was our shop lube at my old shop but now currently use Finish Line Ceramic Wax Lube and haven't had any issues either.
I tried to like Clean Ride. It was a pain to apply for me also. I never really did get a good balance between not clogging and gushing all over the floor. I switched to Squirt and have never looked back.
I'm going to give Squirt a try, see if I have any better luck with it.
Wattsup,
If you try Squirt, completely clean the chain first...really deep clean as in get all residual gunk out of the links then apply the Squirt liberally the first time. I'd go so far as to start with a new chain and completely clean it of factory oil. Yeah, I was skeptical about doing that also because the factory oil is pretty darn good.
I lay the chain out on aluminum foil and hit every link joint. So far I am almost two years without a chain cleaning and I only re-apply the stuff maybe once every month or so. And after this long there is hardly any wear on the chain. It still measures close to what it did when new. Color me impressed.
It worked well when I lived in Arizona and I live in North Carolina with the humidity and it works just as well.
Wattsup,
Wattsup,
I generally don't ride in the rain and I don't do a lot of mountain-biking lately. However, the Squirt doesn't just wash off. It is fairly tenacious on damp road rides. Just about any lube will wash out in a down-pour.
Have you gotten the chain wet? I'm curious to see how it would do when I roll through mud puddles.
Bikes: Bianchi Infinito CV disk, and rim brake
Quoted: 29 Post(s)
Liked 98 Times
I used White Lightning clean ride for years, and was always satisfied. I made the switch to Squirt here in Asia, and it's definitely a big improvement. It's much thicker, so application is a breeze.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
The possible problem that I see with a product like Squirt that I see is that it is a water/wax emulsion. Whatever detergent that is being used for emulsifying the wax...and it has to be a pretty powerful detergent given how water insoluble wax is...is still there. Add water and the detergent goes back to emulsifying which means that the wax can be washed off. I'm not saying that this happens as I've not used Squirt but the possibility exists.
On the other hand, oil based lubricants do flow but they also emulsify the water which is going to sit on the metal and provide an avenue for corrosion. People think that the oil is doing a great job but it is really only masking the problem. If you ride in rain, you should any lubricant you use.
Finally, on cleaning, "deep" cleaning isn't what most people think it is. A cup of mineral spirits in a Gatorade bottle and a minute of vigorous agitation (probably less) is all you need. Let the chain dry and lubricant it. A new chain lasts me about 3500 miles which is 3 years on some bikes and 10 years on others...depending on usage.
Stuart Black
Stuart Black
One concern I have about White Lightening is that it uses a volatile, flammable carrier. Someone lubing his bike in a basement with a hot water heater that uses a pilot light might find himself, his wife and children, his dog, and his house go up in smoke! I'm not saying that this happens, but the possibility exists.
p.s. Velonews gave very high marks to Squirt in its lubricity tests. If I recall, it came in second only to a molten wax chain bath. Also, I see some Squirt users on Amazon are getting 6500 miles from their chains!
Quoted: 1975 Post(s)
Liked 232 Times
Molten speed wax>paraffin>squirt>>>>>WL Clean ride when it comes to rain riding. Here in the PNW the CL will start squeeking almost immediately as soon as the rain starts or if there's a lot of road spray.
Liked 4,222 Times
FUD!
On the other hand, the surfactant used in Squirt is still there and still available to do what it does best. Surfactants don't evaporate.
I would be highly dubious about any claims of 6500 miles for any chain lubricant. I put claims like that in the same category as 25" trout. The mileage tends to grow with each retelling.
Stuart Black
Stuart Black
Well, there's only one way to find out. Overcome your fear of the (hypothetical) detergent issue and go get yourself a bottle!
Liked 4,222 Times
Probably not going to happen. I’m still finding bottles from the case of White Lightning I bought nearly 20 years ago and I just bought some Rock and Roll to try. It will take me 5 years or more to get through that.
Stuart Black
Stuart Black
