Continental GP5000 Tour de France tan: PROBLEM?
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
I’ve been GP5000’s for a while and used to ride on GP4000’s, no issues. But I bought some of these “special edition” tanwall 700x25’s, two pair, and put one pair on my 1961 Gitane. They look great!
Oddly, the bike has been more or less finished for a couple of months, but only took it for an 18-mile shakedown ride this morning. I really like riding this bike; but, four miles from home, something felt odd and I looked down to see the front tire going flat. Shoot, might be my ongoing issue with shifting Velox rim tapes? I do not know yet. I had forgotten how excrutiatingly tight these were to install, and I could not get the tire off using the plastic tire levers that come with some packs of Continental tubes… could not even get under the tire bead at all, they are that tight! So, a four mile walk in cycling shoes - not happy.
I mean these things are tight; to the degree that, were it not mechanically impossible (someone fact check me on this), I’d think I had 700C tires on 27” rims. I just looked, the rims are mismatched with Rigida front and Wolber rear, but both say 700C on the stickers.
Anyone else experience this? As in, so tight tire changing is nearly impossible?
I’ll look and see if I have a regular GP5000 in the workshop to see if it fits better, even if blackwall. I might need to change tire type… were some tire mismanufactured? How to tell? I might be researching to see if can find another tire in tanwall with anything near the GP5000’s performance. And, while I have no issues with 25mm, i have vast clearance and could run up to 30mm, which would look odd to my eye but I know there are many stating that wider is faster.
And I need to dig out my old, thin style, metal tire irons; pretty sure I used them to install the tires (no simple pushing on with thumbs), and see about getting this tire off.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 1829 Post(s)
Liked 3,376 Times
this matches my experiences with Continental tires on vintage rims. In addition to carrying some metal tire irons with a sharp enough lip to get under the bead, I carry a small tire jack tool called EZ-Clincher:
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
VAR makes a similar bead jack, with included tire levers:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Mine are tight, but I managed to mount mine as easily as any other tire I've encountered. In fact I had to dismount one of mine and remount after getting distracted and mounting it backwards. I have mine on modern Bontrager tubeless ready rims so I don't know if that makes any difference.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If your tires are that tight, I would use a different tape than Velox. I don't leave the house on tires I couldn't change by hand, and that includes bikes with tubeless-compatible rims or stiff wire-beaded winter tires (thankfully not on the same wheels!)
RUSA #7498
Originally Posted by noglider
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Bike Hand Tire Seating Tool
After nearly 50 years of mounting bike tires using my hands plus lots of different tools, I found one that works the best for me: the Bike Hand Tire Seating Tool
I've seen these marketed under several different brands.
About the toughest rims I've mounted tires on are the old Ambrosio Elite 19 model.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 1641 Post(s)
Liked 831 Times
One can just imagine the possible crazy results of combining these apparently undersized GP 5000s with a notoriously hard to tire rim like the Ambrosio Elite.....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Should not be possible without ripping the tire bead apart.
Quoted: 987 Post(s)
Liked 641 Times
THIS!!!!! Sadly, too many months between when I mounted the tires and when I took the shakedown ride. Forgot.
Liked 3,376 Times
Considering how often this topic gets discussed, I wonder if there is any way to get tire manufacturers to publish their actual bead diameter, instead of the nominal 622mm bsd?
Offhand, I imagine they would prefer not to, since that would/might imply there was some sort of guarantee that they would maintain that value.
It would be very interesting to know whether they measure the bead diameter of every tire coming off of the production line, or if it is just a go/no-go gauge, or what.
Steve in Peoria
Steve in Peoria
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
FWIW, I've never had a problem getting Continental 4000s or 5000s onto Mavic Open Pro rims; they all but install themselves, and is a major reason why I ride that combination so much. Getting them onto a pair old old Weinmann (I think) "Gentlemen" rims, however, is basically impossible without a prying device like Steelbikeguy and verktyg showed above. I have two Kool-Stop Bead Jacks - one in the tool collection and one for carrying in my pocket on rides. I used the Bead Jack for pretty much all tire installations now as my hands are not as strong as the used to be.
Liked 2,568 Times
Velox cloth tape is a quality product, and I use it on a few wheels... but it's thick, and sometimes that makes the tire fit way tighter than it needs to. Even if you don't plan to set a wheel up tubeless, "tubeless tape" or the like can be great because it's thin and strong. Try some Kapton 1 mil or Scotch 8898 or Tesa 4289 tape in 1/2" width, two layers, and see if that makes it easier to get tires on and off.
RUSA #7498
Liked 831 Times
Question is, how does a big, established tire company like Continental get this tire so wrong??
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Liked 2,568 Times
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Velox cloth tape is a quality product, and I use it on a few wheels... but it's thick, and sometimes that makes the tire fit way tighter than it needs to. Even if you don't plan to set a wheel up tubeless, "tubeless tape" or the like can be great because it's thin and strong. Try some Kapton or Scotch 8898 or Tesa 4289 tape in 1/2" width, two layers, and see if that makes it easier to get tires on and off.
My Bikes
My Bikes
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
Sunshine
Liked 7,492 Times
Conti 5k TDF tires fit easily for me. Hand mount without a struggle.
Meanwhile, I wrestled with some 28mm Panaracer GK slicks tonight- both pulling off and putting back on the wheel. I put that same tire on one of my kid's bikes a couple months ago and it went on without a thought.
Some tires mount easier on some wheels and some are torturous on those same wheels, but are a breeze on other wheels.
Likes For mstateglfr:
Quoted: 4560 Post(s)
Liked 2,802 Times
With Velox or other cloth tape, I use the narrowest tape I can get that will cover the spoke holes but not climb up the rim walls. That helps with tight fitting tires.
Otherwise, ditto the more rigid plastic rim strips like the Conti Easy Tape, Schwalbe high pressure rim strips, etc. Or Gorilla tape or tubeless tape.
The tricky bit is squeezing the beads together from both sides of the tire, into the center channel. But if the center channel is shallow and the cloth rim tape is thick, that's a problem. And with new tires it's hard to keep the beads squeezed together around the entire... umm... tire.
I'm guessing Conti is erring on the side of a tighter fit to ensure compatibility with tubeless rims.
FWIW, I've been very satisfied with Conti GP Classic skinwalls for a couple of years on three bikes. Rolling resistance isn't quite on par with the GP5k or GP4k tires, but they're still very good and easy to mount with just my hands and unmount with a single plastic tire lever. And I like the reddish brown sidewalls better than the lighter tan or cream sidewalls used on some tires (including the Soma Supple Vitesse, which are otherwise excellent tires).
Likes For canklecat:
Quoted: 987 Post(s)
Liked 641 Times
I question that premise. Continental's own rim tape is -- drum-roll -- thinner than Velox: https://www.biketiresdirect.com/prod...tape-rim-strip
I’m typically using Stans rim tape now. I think it is kapton with some white tint mixed in, kapton is typically clear/yellowish. I know two layers are recommended but I only lay down one. I have a lot of trust in the durability of the material. Has anyone ever had issues wit one layer of Kapton or Stans failing?
FSA makes a non-adhesive continuous strip (like the Conti) that is thin and stretches slightly into place. I like this one if it can closely match the channel width of the rim I’m using. It’s handy if you think you may need to remove it for access to nipples, etc.
I’ve tried the Conti black strips too, seem to recall them being thicker. They might be fine.
I’ve given up on the cotton Velox in favor of plastic as it dries out faster when wet.
Liked 3,376 Times
Well, one thing I won't be doing is changing rims to better fit the tires. And I think I need to check, I bought a bead jack a while back, but to carry it I'd need to replace every under-seat bag I own due to size. I did see something called a TyreKey online last night, it might be an option, more portable.
Steve in Peoria
Liked 2,568 Times
Well, that's an option. Wow, almost ten bucks and I presume that's per wheel? Not per pair?
Disclaimer: I haven't used the above products specifically. But Pacenti blue tape and Stan's tape work on the same principle.
RUSA #7498
