Suntour GPX Hub odd attachment
Quoted: 566 Post(s)
Liked 1,052 Times
I picked up a set of wheels and the rear has the thing screwed on as in pic.
A) What is it?
B) How do I remove it?
Wheels are from an RB-1 primarily used on a trainer FWIW.
A) What is it?
Pedalin' Erry Day
That's the inner half of a freewheel that someone took apart while it was still on the wheel. You'll need the matching 4-prong freewheel removal tool to get this off of the hub.
Likes For lasauge:
Quoted: 566 Post(s)
Liked 1,052 Times
Ahh, I’ve never disassembled a FW so that explains my ignorance. Thank you for the education.
Regardless, carcass removed and things will be cleaned for its next life.
Or if you don’t expect to rebuild the freewheel, since the other bits are lacking, you could just use a set of vice grips or a big pair of channel lock pliers.
Likes For Mr. Spadoni:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Was also thinking that this freewheel might have come apart while riding(?).
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
The big bench vise method would be my choice. It’s been on there 30+ years… it might not want to let go.
Jeff Wills
Jeff Wills
Quoted: 4410 Post(s)
Liked 1,566 Times
There isn't any downside to any method if you aren't keeping the freewheel.
Liked 1,296 Times
One thing about the bench vise though, is that the shell of the freewheel body and the threaded snout on the hubshell aren't quite as thick as might be assumed, given that freewheel bodies look and feel pretty hefty.
So best to not use any more tightening force than necessary for "traction", especially on a bigger vise's handle, lest the hubshell become vulnerable to deformation or cracking.
That small bit of elastic ovalization will only assist with cracking loose the static bond at the threads, but exceeding the elastic range of the hubshell might not be hard to do.
Quoted: 566 Post(s)
Liked 1,052 Times
Removal of the FW body wasn’t too horrible. I removed the pawls and put some channelocks on the flats and it came off fairly easy. Lucky me!
Note to future googlers - a 2 pin Suntour tool on a 4 slot FW will turn out badly.
Likes For RustyJames:
Quoted: 2364 Post(s)
Liked 1,751 Times
Dork disc outlasted the freewheel, and without yellowing to boot.
