Need a 4spd vintage cassette. Any ideas??
Midlifecyclist
Recently rescued a 1973 Motoconfort from the bin, and the original cassette is absolutely toast.
I’ve looked everywhere I can think of. Any ideas where to source one??
Quoted: 3811 Post(s)
Liked 6,713 Times
Use a 5-speed freewheel with one cog removed?
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
Many 4 speed freewheels available out there.
Likes For PhilFo:
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 279 Post(s)
Liked 955 Times
Check ebayuk. There's a much better and cheaper assortment than EBAY US.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
I'd be surprised if a '73 anything had a 4 speed freewheel. Pics of the bike?
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
On the 5-sp freewheels where the high gear cog threads into/onto the next larger cog, instead of onto the FW body, you can just leave the top gear cog off. Regina is the one I've done this with but I bet an Atom is about the same way if you need a French thread. I have a couple and can take a cog off to confirm if needed.
On the Regina I did that to, I ground down the "new" top gear on the belt sander to remove the projection that the old top gear threaded onto. Not strictly necessary but it looks more "right". If you do it neatly, it looks like it was made to be a top gear position. Sand out the belt-sander scratches with some fine sandpaper taped to a flat surface, just rubbing the cog against the paper by hand.
I suppose it'll rust where I ground off the factory coating, whatever that is (if any?) but I keep my freewheels coated in a nice layer of grime, which is effective at rust prevention. This was not an "Oro" FW, it's a GS Corse, so I think they may come with no coating at all, i.e. I didn't change the susceptibility to rust at all.
All that work is unnecessary of course if you just find a 4-sp FW, they're out there. But in my case, making my own was faster than waiting for something to arrive in the mail.
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
Recently, there was someone in Wisconsin who had a listing on FB with a couple of NOS 4 speed freewheels. IIRC they were in the $30-35 bracket. I will see if I can find her listings again.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,602 Times
What is wrong with it? I've encountered quite a few of those old freewheels, and more often than not I've been able to bring their mechanisms back to life with a liberal dose of WD40, sewing machine oil and some TLC. Worn cogs can be replaced, or even filed back into a usable shape.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,927 Times
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
The 1960 Schwinn Varsity had flat-bladed forks and a 15-18-21-25 four-speed freewheel, while the Continental had tubular forks and a 15-17-19-22-25 five-speed freewheel.
By the next year, the Varsity was a 10-speed, as well.
For a number of years, Regina and a few others made only 4-speed bodies, and the optional 5th cog was screwed directly into the 4th, as mentioned above.
Midlifecyclist
Midlifecyclist
the mail.
the mail.
Likes For Mr. Spadoni:
WGB
Liked 2,334 Times
I rechecked FB but either they sold or were withdraw.
