Bike now Broken?
Bike now Broken?
Hello everybody,
today was my first day at work after 2 weeks of vacation. I normaly droved to work and back. But I needed to go back in the afternoon. At the way to work everything worked fine, but at the way home, I couldn't switch gears and the chain have a really low tension. So I looked at my bike (Triban Grvl 120) and saw this (look at pictures). Now my Question is, if that is broken or is the problem elsewhere?
Liked 2,981 Times
der went derp. time to figure why it derp derp'd.
-Oh Hey!
-Oh Hey!
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Looks like possibly this spring broke releasing tension on the "B" screw.
https://www.parktool.com/en-us/blog/...lleur-overhaul
Likes For dedhed:
Quoted: 6199 Post(s)
Liked 4,816 Times
What are you doing or what gear combo are you in when you get the loose chain? Is it only when in the small rear cogs and small front, of does it happen in the larger tooth combinations.
Quoted: 4806 Post(s)
Liked 3,933 Times
In the top photo of your second batch, looks like the derailleur mounting bolt (just below the hub axle) is angled down. This almost always means the derailleur hanger is bent or broken. On virtually all modern bikes, that hanger is a replaceable part. I'd take the bike to a shop that carries the brand or call their US office. (Many other shops should be able to help you through their suppliers if the shop has the person with the computer savvy and desire to help.)
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 324 Times
Looks like you crashed on that side. Scuff marks and the hanger looks bent.
Why is the top bolt so far out?
Bikes: Trek FX 7.3, Specialized Roubaix, Orbea Terra, Aostimotor S17 ebike, Huffy RedRock (first bike)
Quoted: 207 Post(s)
Liked 269 Times
Move derailleur back and see if you can get the set screw catch on top of the hanger. Screw looks stripped to me, and may need replacement. Take a look at that first.
SE Wis
Liked 3,401 Times
Something doesn't look right here
Likes For dedhed:
Sunshine
Quoted: 10970 Post(s)
Liked 7,498 Times
Quoted: 207 Post(s)
Liked 269 Times
Does shifter loosens or tightens the cable? I think regardless if hanger is bent, derailleur would still move up or down gear.
It looks like the B-screw was forced to overshoot where it's supposed to rest on, so there's no way it's doing its job.
The upper derailleur pulley looks to be right up against the cogs.
Likes For Paul_P:
Bikes: Way too many
Quoted: 900 Post(s)
Liked 607 Times
The lock/unlock symbol indicates that the clutch is disengaged, which means the chain won't be as tight. That shouldn't have any impact on the shifting though.
Likes For wheelreason:
