Schwinn Stingray
Schwinn Stingray
Need some input from you wise Schwinn experts. Just purchased a Schwinn Stingray from a yard sale. Trying to determine the year made has proven difficult from exhaustive internet searching. I know it is not from the original release in 1963 and it is not the relative current retro models. The flat fork with chrome crown, crank set design and screwed on head tube badge are reminiscent of the early models but frame welds at head tube and drop outs are more recent. The serial number, TCA04D01134, is not recognized through the Schwinn searches so I am sure it was not USA built. Any help would be appreciated.
Quoted: 6199 Post(s)
Liked 4,816 Times
All my friends in the 70's had one of those. Looks in very good shape. No idea of it's age or place of manufacture. Does it also have a code stamped on the head badge?
Might be someone in the Classic & Vintage sub-forum that knows. Not all of them come to the General Section much. There use to be some that actually worked for the original Schwinn company back prior to the name being sold in the nineties. But I haven't seen them around in quite a while.
Maybe you can get a moderator to move this thread there for you.
52psi
Quoted: 790 Post(s)
Liked 802 Times
The small numbers stamped on the headbadge will tell you. Find the number then google "schwinn headbadge decoder" for your answer.
Quoted: 3515 Post(s)
Liked 2,927 Times
The lack of any appreciable rust except on the bars is interesting.
And the wheel reflector is upside down.
Thanks for noticing. I actually removed the reflector, haha. Also, the rear wheel rim has more rust on it than I like to see. But overall, especially on the frame, rust is at a minimum.
Likes For wltr w8:
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
99% sure it's a mix. It's a modern Stingray frame, has swapped modern Krate crankset, period bars (as in old, but not sure manufacture), modern stem etc.
I think it's someone's attempt to either "fabricate" a real Stingray to fool somebody, or just to slap some old parts on for fun. Drilling two holes and adding screws to a headbadge is an old trick, but the welds make it obvious it isn't "real" to anybody that knows about vintage Schwinns.
Likes For Erzulis Boat:
Pennylane Splitter
Bikes: Yes
Quoted: 1807 Post(s)
Liked 1,447 Times
Can you post a picture of the headbadge, the numbers stamped on them were quite small, and the numbers were sometimes stamped just below the headbadge and above the headset's lower crown race. That frame looks like it was from the 1980s or later as the earlier stingray frames (IIRC) had a simple 4-digit number stamped on the bottom of the bottom bracket; about 1980 they went with a long alpha-numeric code on the BB. The wheels look newer as does the banana-seat saddle. Still a nice-looking example of a Stingray.
Likes For skidder:
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
ETA- Did a little digging, I was right, going off warning label on top tube, looks like a batch from 2000 or so. There was a 1998 run with same sticker, but welds looked more "correct". To be safe, date bike to 20 something years old.
Thanks all for the comments. I don't disagree and don't mind as I bought it for a fun purchase. I actually was given this same style and color bike when I was 10 in 1968. Bought it for my grand daughters to ride. It's hard to believe that someone would go through the trouble of frankensteining parts but there are a lot of dishonest people out there.
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
If it really was an intent to deceive, removing the warning label would have been the first order of business I would think.
ETA- Let me clarify, its a real Schwinn, just not a real Chicago Schwinn (vintage).
For my learning, can you explain your observation of the flat head phillips? Does the authentic Schwinn have a rounded head phillips?
Likes For wltr w8:
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
Original screws were a very pronounced (domed) slot fasteners. The threads had a very "relaxed" helix compared to the shank, the opposite of a fine thread if you will. An early version of a self tapping screw in appearance.
Quoted: 523 Post(s)
Liked 230 Times
Lots of confusion on how to date older Schwinn bikes. Are you sure you identified the first letter in the sequence? From the picture, it looks as though there is a mark before the letter "T". If you did not correctly identify the first letter in the sequence it would make dating it from the list of Schwinn dates impossible.
Actually, the first 2 letters on the sequence is SN. I assumed they stood for: Serial Number. When searching I did initially include all the letters and then did repetitive searching without the SN and then started discounting subsequent letters. Nothing went thru as valid numbers.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Likely made in China for Pacific Aug. 2004
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
Those are called 'drive screws'. Many didn't have any slots, they were hammered in.
Likes For rollagain:
Quoted: 523 Post(s)
Liked 230 Times
That pretty much identifies it as a Chinese made bike imported by Pacific Cycle. Pacific uses identification starting with SN. Unlike older Schwinns there do not seem to be any serial number lookups for Pacific Cycle Schwinn bikes.
I remember driving past the abandoned Schwinn factory in Chicago soon after it closed. Ditto for Ashtabula crank company in Ashtabula OH. The name was still on the factory but it was not in producing anything at that time.
Likes For VegasTriker:
I figured it is a Schwinn commissioned bike in that the accessories such as the banana seat, rear reflector, seat post collar bolt, head badge, decals and hand grips all Schwinn identification on them. I ordered a set of Schwinn ape hangers off ebay and when I replace I'll check existing bar for identification.
Likes For wltr w8:
Pennylane Splitter
Bikes: Yes
Liked 1,447 Times
The Schwinns from the 1960s-1970s also could have the headbadges attached with rivets. I've got a mid-1970ish LeTour that I had to drill the rivets out to get the headbadge off before I got it powdercoated. I found some small screws to put it back on when re-assembling, not authentic but I was just looking to get it re-hab'd and rideable. Mine isn't authentic by any stretch of the imagination, but its something I put together for nostalgic reasons and its a different 'feel' of a ride when I want something different than my usual 'daily drivers'.
