My rear derailleur cable is about to...
ibb.co/qxcnjST
... snap, by the looks of it. Any idea as to what might have caused that?
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Pic assist:
Looks like the cable wore where it exits the barrel adjuster. It hard to see if this could have been prevented. The angle at which the cable enters the barrel adjuster doesn't align with the anchor bolt.
Replace ASAP, or get used to pedaling in a high gear.
Likes For Litespud:
Quoted: 1438 Post(s)
Liked 1,092 Times
You might want to make certain that the barrel adjuster and exit hole on the derailleur do not have any burrs or sharp edges, perhaps put a radius on the corners with a file.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Rubbing on the bolt? What are you talking about? Where is the cable rubbing on a bolt? These derailleurs chew through cables quicker than most, but the OP is missing the little tube that should be sticking out of the derailleur. The cable runs through it on the way to the anchor bolt. That helps a little.
Quoted: 3375 Post(s)
Liked 5,513 Times
Every time I've replaced a shifter cable, it was always due to fraying inside the shifter, but never at the derailleur.
Was wondering the same thing. On the older RDs, there was a ring press-fitted on the exit side of the cable hole, opposite of the cable tension adjuster. This would sometimes get pushed out by fully screwing in the adjuster.
The newer RD have a different design that has an insert that goes in from the tension adjuster side. Haven't examined how this looks or how the cable is effected by this new design.
Thus my earlier request for RD model #.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Quoted: 1088 Post(s)
Liked 1,024 Times
Does seem like a poor angle for the cable to come out at, not surprised it frayed. Just replace and move on but do check the barrel adjuster for burrs that could have done this.
Thank you all!
About a year old, only 4,000km on this bike
Shimano Tiagra 4700 GS
You can see that the cable makes a bit of a bend as it exits the adjusting barrel, and is probably rubbing on the inside edge where it enters open space. This combination of flexure and friction is fraying the cable a strand at a time.
This appears to be a design flaw in the derailleur.
Bikes: lots
Liked 2,932 Times
Part # Y5XX38000 'Cover with tongue' It's designed to prevent this from happening...for a while. Just like in the shifter it will happen eventually.
Attached is a pic of the RD-4700, note the pressed-in insert on the exit point of the cable housing stop. This was how older RDs were designed. The "cover with tongue" is new and included only on newer higher end RD. Not sure if these designs are compatible.
Quoted: 576 Post(s)
Liked 1,001 Times
Stock up on road shift cables, the new Shimano road stuff eats them up.
Quoted: 4559 Post(s)
Liked 2,802 Times
Yeah, with some systems, plan on replacing shifter cables at least once a year, maybe more often. Some brake cables seem to last forever -- my early 1990s Univega is still on the original massively thick brake cables. But it's gone through shifter cables about once a year. Ditto my 1980s-2000s road bikes, although I replace brake cables once a year on those as well.
Replaced the rear der cable on a SRAM Apex bike this past Tuesday. It was fraying exactly as the one in the picture, however it was about 5 years old. I see this every once in a while and am unable to figure out the exact cause. I have even seen it on der with the extended sleeve as shown in the second pic. Just may be one of those unsolved mysteries of the universe.
Likes For TiHabanero:
spilot, my suggestion is to start to try doing some of your own bike mechanical work, so many advantages, but if that's not your thing, it's not your thing.
it's like anything, it's a gradual process learning new things all the time
I'm working overseas at the moment, so it's a bit of a "benefit-cost" analysis situation at the moment, as I would need to throw all of my possessions away before moving back.... With that said, I've gotten a stand and a couple of toolboxes to deal with cassettes, rings, bb etc. Looks like cables are more expandable that I'd previously imagined, so this might need to be my next YouTube lesson.
It's also a gradual process of aquiring tools, and at some point, a good quality cable and housing cutter is worth it, will be paid for in not too long doing things on your own.
again though, only if you're into it.
