Rear rack extension?
Count Dorkula
Bikes: 2008 Specialized Tricross Sport
My two wheel gear suit pannier covers the rear of my rack and sits too high to allow cars to see my seatpost. I'm thinking of making an extension bar out of PVC pipe for the rear rack so that I can mount my tail lights farther back to increase their visibility. It would look something like the picture but wouldn't be connected to a handmade rack that retails for almost $200 which I cannot afford. Anyone know of a company that sells something like this? I like my rack it just needs a little more...length.
Quoted: 5219 Post(s)
Liked 3,564 Times
Can you show us a picture of your current rack? I extended mine. It was the kind that clamps to the seat post. Only problem with those is, if you put a full (heavy) bag on it - it will swing your seat left and right on some occasions AGH! To stop the swinging I bought some thin steel bars and cut and bolted them to the little holes on the frame down by the derailer. To extend the rack I bought some tubular aluminum which fit nicely into where the stock bar was. It just took a little drilling and some nuts and bolts. How do you post pictures on this web site? Can I just upload something small or do I have to link to another site?
Count Dorkula
It's this one, a topeak explorer disc compatible model. I'm not going to put a load on the extension. Just want to mount my tail lights in an area that isn't underneath and obscured by my garment bag much like the rack pictured in my original post. You can upload photos if they're 100K or less using the paper clip icon. You can also link to photos elsewhere on the inter-tubes.
Liked 3,564 Times
rack extensions for lights and reflectors
Well, if you're handy you can get a strip of material from the hardware store. I like this stuff, it's steel, but very thin and is a series of holes. It's about 1/8" thick, 3/4" wide and is very flexible and very easily cut with a hacksaw if you hold it on edge in a vise. Anyway, you can cut a few inches of it and bend it and twist it anyway you want to make whatever kind of extension you need. If I can photograph mine and post it, I will.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
If you extend the rear beef up the front or the leverage will fail the front mounts.
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Liked 3,564 Times
I think he is only "extending" in as much as he is mouting lights not really moving a heavy load.
Bikes: 08 Novara Safari; 06 Schwinn Super Sport DBX
I zip tied a piece of PVC to stick out a few inches past the back of the rack. Spray painted black so it wouldn't look too bad.
rumrunn6 - pics would be great. wouldn't mind doing something less amateur with my setup
Liked 3,564 Times
OK - pics tonight! :-) I rode in this morning and it was garbage recycling day, so I was pressed for time.
Count Dorkula
PVC and Zip ties are probably what I will do though I also like the idea of simply bending a strip of steel to serve as a "hanger" of sorts. Either way, I guarantee I'll make it look amateur. Maybe it'll ghetto up my Kona JTS enough so that it will be less likely to be stolen!
Liked 3,564 Times
Yeah, that's the spirit!
OK, I took the pics but it was dark by time I got home and remembered so I had to bring the bike inside and use the on-camera flash. Yuk. Now I can't find my stupid wires to download the images. Ugh They're comin'
Liked 3,564 Times
tballx - I took some new pics this morning. I'll try to post just the ones that relate to my own rack extension and tail light extension. I used 3 things from the hardware store aside from nuts bolts & washers. 1) Channel Aluminum (to extend the reach of the rack's main arm that clamps to the seat post) 2) Thin flat steel as legs for the extension (these keep the whole rack from swinging my seat side to side! AGH! and they provide more holding power for heavier weights) 3) Thin steel strip with holes (it comes like that) which is soft and very malleable and easy to cut with a hacksaw (for the rear strobe mount)
Actually I find all steel at the hardware store pretty easy to cut with a hacksaw. Though I usually have to buy fresh drill bits for every project ...
OK these may not be in the best order bur here they are. I have a picture or two of the whole bike as well but I'm going to post them in the antique / classic section
Liked 3,564 Times
Tyrell - Thanks, the dam thing was spinning my seat while I was riding! AGH! Those things look good but their design is flawed. Plus their heavy steel clamp and bar is overkill considering it's needs a supplemental support in the rear. I had no idea of the issue before I bought the rack. I do like having a "Schwinn" rack though. It has a nice emblem.
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
They're super handy for fabbing mounts and extenders and other fiddly-bits. I used a joiner plate and some PVC pipe to make the front rack mount for my handlebar bag. Decaleur = $40.00 My fabbed mount < $5.00
Liked 3,564 Times
CliftonGK1 - Are joiner plates about 4"x5" with a bunch of tiny holes? If so I've used them too for stuff. Good thinking. I don't remember cutting them though. Do you cut them?
I just looked for images on google and found those "L" bracket things, you know for supporting corners on old drawers and stuff. Those would be useful too.
Quoted: 5 Post(s)
Liked 7 Times
If you can't find the size you need, they're thin enough that you can easily cut them with a Dremel.
Count Dorkula
Joiner plates, eh? I will investigate this magic. I'm planning on hitting the home depot for the pvc this weekend anyway.
Liked 3,564 Times
tballx - Don't forget to show us what you wind up doing, OK?
Liked 3,564 Times
Hey tballx, How you doing? remember those P-clips someone mentioned? I found some at my store called compression clamps. I built a little front rack today.
Liked 3,564 Times
Oh here are pics of the new front rack and clamps
Count Dorkula
I'm afraid next to your set up, mine is going to look pretty weak. I'll take some pics tomorrow after I bust out my Zip tie collection. So far, I've spent $3 on pvc pipe. Oddly enough, all the damn pipe had male threaded ends yet the elbow joints had a male and female end. What the hell? I was shopping in the sprinkler system gear so maybe only the sprinklers get the female ends. Who knows.
Prefers Cicero
