Top-pull road triple FD?
Bikes: Focus trash find commuter, Eddy Merckx Corsa, BP Stealth TT bike, Leader 720 TT bike, Boardman Comp Hybrid drop bar conversion, Quantec CX budget cyclocross build, SerottaNOS frameset ready to build up!
Quoted: 128 Post(s)
Liked 103 Times
Hereīs a good one.
Does anyone make a FD, compatible with a Shimano triple road STI shifter, thatīs top pull?
I know I can get a problem solver pulley thing by the way.
A Speen adaptor is another possibilty.
Just wondered.
Just wondered.
Quoted: 5767 Post(s)
Liked 2,541 Times
I don't follow all the product offerings so I don't know if anything is out there. But I convert top pull bikes to bottom by routing the cable around the left chainstay and back up. I use a piece of teflon tubing to protect the stay, but cut a hole in the outside bottom, so it's not a sump for all the water the wheel sends to the open end.
BTW- the right chainstay also works, but most FDs get in the way.
FB
Chain-L site
One accurate measurement is worth a thousand expert opinions - Adm Grace Murray Hopper - USN
FB
Chain-L site
I have a Speen adaptor on my cyclocross bike. I don't like it much. Way too difficult to get proper tension. I imagine it would be even worse on a triple.
Likes to Ride Far
I'm pretty obsessive about all of the FD options that Shimano offers and their compatibility, but I'm almost certain that what you're asking for doesn't exist (top pull triple FD that works with STI shifters). Shimano does make a version of the cyclocross-specific CX70 that is top pull (there may be a cheaper CX50 version also), but that is double only.
One option would be to use a top-pull trekking front derailleur operated by a bar-end or down-tube shifter. If you want to stick with the STI shifter, then you'll have to run a regular road FD with some kind of adaptor or pulley.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
There's also a trick of using a length of housing from the last frame stop to the cable anchor on the derailleur, while anchoring the inner cable to the frame somewhere below the der. I've never tried it, but with a FD close-enough usually works.
Bikes: 2012 GT Transeo 3 2014 Cannondale CAAD 10 105
Quoted: 26 Post(s)
for what it's worth, I run a shimano top pull mountain derailleur with old sora shifters.
it's not perfect, but it works... takes a lot of adjusting to get it to work well, and it noticeably rubs in cross chain situations.
i'm running a shimano FD-M430 with ST-3400 shifters
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
V-brake noodles are fodder for endless ingenuity...
There should be an Olympic Games for cleverness, and coming up with new uses for V-brake noodles should be a sport.
That's a gold medal effort, right there.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
bike whisperer
Liked 716 Times
AFAIK every left STI shifter is functionally identical to its double or triple brethren.
Quoted: 26 Post(s)
wheelinthai
Bicycle Mechanics
11
03-05-15 02:32 PM
|3iker
Bicycle Mechanics
5
07-02-10 05:13 PM
