Bottle Relocation Product Review
Quoted: 1103 Post(s)
Liked 1,823 Times
Like almost everyone who frequents this particular forum, I ride older steel road bikes and I'm a little less flexible than I used to be. Hydration is especially important to me so I almost always carry two large water bottles. Since my positioning on the bike has changed, reaching down for the bottle on the downtube can be a bit of a stretch so I bought a bottle relocation gizmo thinking it might make a difference and boy did it ever. So much so that I'm in the process of putting them on all my bikes. I would say it would be even more useful if you normally carried smaller/shorter bottles. Install is easy and there's a bit of adjustability built in so you could even make it work for bikes with downtube shifters, especially with the shorter bottles. All the fasteners are in the kit are T25 so you'll need an L handle version tool.
The best 19 bucks and 5 minutes I've spent in a long time.
Likes For nomadmax:
Quoted: 2300 Post(s)
Liked 4,764 Times
I've got to agree although for me I needed to move the cage to get more space. Anyone with a Y-Foil knows how tight they are in terms of water bottles. I originally had bought a very short one to fit in there. Then I found this and was able to gain an inch or some more of clearance where I can now use one of my regular camelback 20 oz bottles.
In my case I just pushed the cage as far back as I could without the brake caliper hitting it as it moved.
Steel is real...and comfy.
Likes For jamesdak:
Quoted: 1192 Post(s)
Liked 1,324 Times
This is an issie with 2 of my Bianchi frames where the bottle cages almost overlap.
This will work...thanks for posting.
Likes For malcala622:
Bianchi Goddess
Quoted: 2910 Post(s)
Liked 2,830 Times
Maybe the real answer is taller bottles?
Sugar "Kane" Kowalczyk
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
I used the B-Rad system
To mod my Trek 720 to carry five bottles on tour this summer. One was on the underside of the down tube to lower the bottle, allowing a large bottle without tire rub. One was on the inside of the down tube, putting one bottle in somewhat the normal place, and above it a double adapter so two could be carried side by side. The third, on the seat tube, was used to raise the bottle so as not to interfere with the lower bottle on the down tube. Rock solid and effective.
Quoted: 4558 Post(s)
Liked 2,798 Times
Interesting. That might resolve a problem I'm having mounting the bottle cages I want on a '93 Trek 5900. Instead of the usual cage mount bolt holes it has protruding threaded studs, and needs a nut to fasten the cage. Problem is, some cages have recessed holes too narrow for an 8mm socket. I've had to try several different cages to find one that suits me.
But that B-Rad doodad might do the trick.
Quoted: 1073 Post(s)
Liked 1,881 Times
If I have two cages on my Pinarello the bottles foul each other.
I use a Shimano bottle cage adapter - looks like a similar set up to the OP:
I hate using it as it usually ends up scratching the paint though...which may say something about my mechanical skills as opposed to the quality of the product.
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I use handlebar mounts for my second bottle. And sometimes the only bottle.
Liked 1,823 Times
Man, I thought I was the only one!
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 521 Post(s)
Liked 943 Times
I made my own from a strip of 1" x 1/8" aluminum.
Likes For Pompiere:
Quoted: 83 Post(s)
Liked 193 Times
An interesting solution to a problem. My old Motobecane doesn't have brazed on mounts, so I went the hose clamp/piece of inner tube protection for the frame to mount mine so there was some flexibility on where to mount it (although in these Texas Summers, I tend to use a Camelback with the water bottle only used to squirt water through my helmet and back of my neck...).
Cheers
Cheers
Quoted: 237 Post(s)
Liked 83 Times
I've made a few too, although it doesn't need to be a full 1" wide. It's not necessary to have a slot, you can drill multiple sets of holes, but more importantly, you can just measure where you want the cage before drilling any holes.
Likes For Kuromori:
Quoted: 521 Post(s)
Liked 943 Times
Likes For Pompiere:
