Strangeness - are my tire sidewalls defective?
Quoted: 2588 Post(s)
Liked 4,823 Times
I've been riding on these tires since mid-August and they've been progressively popping fibers on the sidewall between the sidewall and the tread. Strangely enough, the majority of the popping fibers are on the driveside both front and rear.
A couple pics:
Would you continue to ride these? In my estimation, at some point enough fibers will have let go to the point the rest fail - and I can foresee this being a quick, catastrophic type of failure. While currently the wheels/tires have been shifted to my short-ride (school) bike, I would like to know what people think. I'll keep using them if I'm overreacting, but will retire them if the consensus is that they're dangerous to use.
DD
A couple pics:
DD
Quoted: 2350 Post(s)
Liked 1,728 Times
You're sure it's not some rub on the drive side? Reverse the tire on the rim and ride it for a while. If the fraying continues, then it just happens that it's that side of the tire evidencing the defect (and yeah, I'd say it's a defect, if the tire is fairly new). If it starts fraying on the "new" drive side, then look more closely for a rub.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
I think you're leaning to the right.
(Could frame misalignment cause this type of issue? I really think it's a defect))
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Liked 4,823 Times
DD
Liked 4,823 Times
DD
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4670 Post(s)
Liked 5,769 Times
Likes For gugie:
Liked 4,823 Times
DD
Likes For Drillium Dude:
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
IIRC, one of the issues with the extra-light version of the Grand Bois Hetre tire was that the tread was relatively thick up to the edges, yet the sidewall was very flexible. This difference in flexibility caused tire failures at the sidewall near the tread. I kinda wonder if something similar is happening here. The tread has become a little firmer with age, and it's forcing the sidewall to flex a little extra at that junction, causing the fabric to fray.
Quoted: 1629 Post(s)
Liked 814 Times
I think you have defective tires where the sidewall rubber is too thin to retain the sidewall pliers. Those fibers extend down to the bead and if enough of them let go, your bead could separate from your sidewall. Similar happened to an old Specialized Turbo foldable tire I had. The sidewall latex dried out and ceased to hold the kevlar/cotton sidewall fibers together and they let go at the bead, causing the innertube to blow out of the sidewall at the section where the bead separated from the sidewall.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
Keep ridin' 'em, but wear an extra tire around your neck like Stu.
Likes For SurferRosa:
Quoted: 1590 Post(s)
Liked 2,492 Times
Same thing is happening to my ears... I'd take them off and hold up to a light to see how thin they are compared to the other side. And trim those unsightly things, lol.
Likes For curbtender:
They look like they are old and the fabric has decayed. I've seen this happen to cotton tires many times. Can also affect rayon blend, etc. IMO they are toast and you should not ride them.
Here in lala land fabric can decay pretty quickly, I suppose from a combination of heat and ozone. Rubber goes south quickly too. I have to carefully consider sidewall fabric choices for this reason, especially for bikes that aren't ridden often.
Likes For Salamandrine:
Phyllo-buster
Quoted: 2287 Post(s)
Liked 2,031 Times
I've had that a couple of decades ago, rode them anyway. I think an electric facial trimmer took care of it.
Perhaps DD leans left, he just flipped his wheel around to keep us off guard.
Quoted: 821 Post(s)
Liked 253 Times
I would retire them.
Liked 4,823 Times
I will see how it continues to react on my short 2-mile school commute, but I don't think I'll take this bike too far from home. If a tire fails, I'll be walking home for sure!
DD
Liked 4,823 Times
In my case, I note none of the ends are fraying at the rim - just the tread. If they go, I believe they will at the tread.
These tires were nice and supple when I put them on. Running at 105psi recommended max. Oh, well...
DD
Liked 4,823 Times
DD
Phyllo-buster
Liked 2,031 Times
Roll video when you do! Should get you in the Darwinism Awards for 2019.
Likes For clubman:
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times
that's the noise exactly - back before I knew any better, I once re-used a set of old and badly worn armadillos that should have been trashed long beforehand. The sound is like spokes settling in after a fresh truing, or maybe like the creaking of loosely-clamped saddle rails - but quieter.
I spent an entire afternoon's riding puzzling over what could be not tight enough, until the entire sidewall blew out spectacularly. Lightbulb went off when I saw all the frayed plies ...
Hmmm, this has me thinking. You know, when I first started riding on these tires (same wheelset, used on two different bikes) I would hear a funny noise and now I wonder if it is the tires flexing and popping threads. The noise is hard to describe - kind of a creaking noise, but not quite - but it's obvious the noise is coming from the wheel, and I think it's the tire flexing.
DD
DD
Liked 4,823 Times
DD
Liked 4,823 Times
Thanks!
DD
Super Moderator
Quoted: 1173 Post(s)
Liked 924 Times
Take the bike outside, slowly rotate the tire as you hold a butane lighter flame to the fibers. After they're burned off, go for a ride.
Problem solved.
Problem solved.
Extraordinary Magnitude
Quoted: 2597 Post(s)
Liked 1,678 Times
I'm just not a fan of the idea of using old rubber.
I ought to see if my old Specialized Ground Controls are out in the garage.
These Ground Controls came on my Stumpjumper- I thought they were pretty cool. The looked and felt kinda dry to me, but I rode them all over the place- I mean, a tire is a tire- right? So one day, I'm riding over to my brother in law's house- I hear this "flip-flip-flip-flip" sound, and I see what I think is a leaf stuck to my tire, and the noise is the "leaf" hitting the fork leg. I stop and realize the sidewall had separated and a big ol' "thumb" of innertube was sticking out between the strands and the "thumb" of innertube was striking the fork leg on every rotation. Because I thought these Ground Controls were something really special, I tried patching up the interior of the tire with patches and even a big patch of innertube- but it kept separating once I got the tire up to pressure.
I don't really know what could have happened- probably just a catastrophic bang flat, but no idea if it would have put me on the ground or whatever. A few years later, I had a set of Specialized "Touring" and "Expedition" tires that looked and felt about the same way. As plush as those tires felt- I knew riding on them was not a wise thing to do.
Commence to jigglin’ huh?!?!
Quoted: 195 Post(s)
Liked 206 Times
A couple pics:
DD
A couple pics:
DD
