Permanent fix to prevent fender slipping?
https://www.amazon.com/SKS-Fender-700...s+fenders+700c
As you can see, where the front fender is attached at the brake bolt, the hole is oval rather than round. To fit my situation, I need the fender pushed up as far as it can go. This means that the brake bolt will be passing through the lowermost part of the oval hole. Gravity and vibration being what they are, I figure it's just a matter of time until the fender slips down.
I'm looking for a permanent way to prevent this slippage by blocking the top 2/3 of that ovalized hole. No dremel to cut a customized insert, so looking for an off-the-shelf kind of fix.
You guys are so ingenious, I know somebody has a great idea! Thank you.
Robot Check
Or if there is enough bracket that you could bend it 90 degrees above the bolt
I use locktite everywhere I can on fenders & racks
Velo Orange sells a mount that allows adjustment at that point but I don't believe you need it
its more for adjusting for large gaps between fender & tire, but it may give you some ideas
cheers
Quoted: 1572 Post(s)
Liked 643 Times
Bend the tab back so the top of it catches on your bolt head.
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
Like the others said, bend the top of the tab.
I use a Sheldon's Fender nut in this spot so I can keep the fender mounting independent of the brake bolt.
MikeDVB
Hybrid Bicycles
9
05-15-14 10:56 PM
Bat56
Bicycle Mechanics
7
08-21-12 07:23 PM
xnetter
Bicycle Mechanics
12
09-15-11 01:17 PM
