Go Back  Bike Forums > Bike Forums > Utility Cycling
Mixte frame poll
Utility Cycling Want to haul groceries, beer, maybe even your kids? You don't have to live car free to put your bike to use as a workhorse. Here's the place to share and learn about the bicycle as a utility vehicle.
Mixte frame poll
Old 03-09-24, 09:43 PM
Bike jambalaya
Liked 19 Times in 12 Posts
Mixte frame poll
I'm looking at getting a mixte. Can I get y'all's votes on these frames. I could share pictures but i want to avoid visual appeal and for the sake of conversation let's assume they all are the correct size for me.
Trek Belleville white ish thick tube chromoly
Peugeot model name N/A is teal with carbolite 103 tubing
univega Nuevo sport light blue chromoly
Univega via charisma white chromoly
Votes opinions experiences
Thanks
Bike jambalaya is offline
Old 03-10-24, 12:24 AM
Arrowana
Bike Sorceress
Arrowana's Avatar
Bikes: Yes
Liked 126 Times in 75 Posts
The Via Carisma probably has the most tire clearance, canti-studs, and nicest tubing. And maybe even a cool splatter paintjob.
Belleville looks classy, and is quite practical coming stock with fenders, racks, an IGH, and a dynamo setup. I haven't seen one in person, but I'm guessing it is heavy.
Peugeot might be more of a PITA to work on, but is probably stylish enough to be worth it.
Nuovo Sport isn't as exciting to me, but still a good bike.
Arrowana is offline
Likes For Arrowana:
Old 03-10-24, 01:05 AM
Bike jambalaya
Thanks chances are I pick up the via charisma tomorrow I just wish I could find univega catalogs past 1989.
I see a few potential univega supra sports I can get. Which is the top model mixte I can find in available catalogs. I forgot what site shows via charisma available from about 93-01 but I can't find catalogs past 89. Which sucks because I've seen very few images of via charisma mixtes on Google and some of which have very very cool paint schemes.
Old 03-10-24, 01:16 AM
Bike jambalaya
Examples
Old 03-10-24, 06:35 PM
Bike jambalaya
I got it $29
Old 03-10-24, 06:49 PM
Bike jambalaya
Old 03-10-24, 07:29 PM
Arrowana
Bike Sorceress
Arrowana's Avatar
Bikes: Yes
Nice find! To get it up and going, looks like you will need new tires, probably new tubes, pedals, some cables and housing at the bare minimum. Overhauling the bearings will help ensure they last awhile, especially important for the hubs. To move the brake levers, the bolt is hidden inside the lever, and is easier to access when the brake is not hooked up. If you plan to use the levers, replacing the bolt with something that has a proper allen head makes it easier to adjust in the future. I'd consider replacing the shifters, either with a set of thumb shifters made of real metal, or some type of newer trigger shifter.
Arrowana is offline
Likes For Arrowana:
Old 03-10-24, 09:22 PM
Bike jambalaya
I've never seen dual sets of eyelets in the rear. I'm guessing one set is for fenders and the other for a rack. I want to ask if anyone knows which sets of eyelets is supposed to be for what?
Old 03-10-24, 09:41 PM
Arrowana
Bike Sorceress
Arrowana's Avatar
Bikes: Yes
For ease of installation, the rack goes on the front eyelet, the fender goes on the rear eyelet.
Arrowana is offline
Likes For Arrowana:
Old 03-11-24, 01:00 AM
Bike jambalaya
I would like to attain a fork like this one in the future. What key words would help in the search.
Old 03-11-24, 01:49 PM
Arrowana
Bike Sorceress
Arrowana's Avatar
Bikes: Yes
Look for a fork that has mid-blade eyelets. Aside from the amount of eyelets, look for something that has a similar axle-to-crown length. Measure from the center of the hub to the bottom of the headset, I would expect the fork on this bike to be somewhere around 390-400mm. Grabbing a fork with a shorter axle-to-crown length will make the steering more twitchy and responsive, and will probably reduce tire clearance. Grabbing a fork with a longer axle-to-crown length will make the bike feel more stable and predictable when there isn't a lot of weight on the front end, but might have more of a tendency to flop to either side when there is a bunch of weight on the fork, and might give you more tire clearance. You probably don't want to go anymore than 10mm shorter or 20mm longer.
Before you grab a new fork, it is wise to decide on the rack you want to use up front. Some racks attach at the axle and would work fine with the stock fork, others will work best if you do swap to something with more eyelets. Or maybe take a look at the Crust Clydesdale fork.
Arrowana is offline
Likes For Arrowana:
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
