suggest an inner tube for me
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I'm using 700x28 clincher tires and ride exclusively road. I only want butyl and would like to keep the weight below 100g
I've used Continental race 28 in 25-32 variety with good results but they are on the heavy side (140g). I know I'm counting grams but I want to buy a few tubes with new tires and want to set it up right.
I do NOT race. I am an enthusiast who loves to ride especially on hills.
(yes I tried the search function but for whatever reason I'm not finding the info easily - possibly I'm using too common words for the search)
thanks
thanks
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
How about Schwalbe SV20 (65g)?
I've been really impressed with their Superlight tubes in my 650B bike. They don't seem to be any less reliable than standard thickness tubes.
RUSA #7498
Quoted: 345 Post(s)
Liked 237 Times
Thanks for the reply and I'll definitely look into Schwalbe based on your experience. However, I cannot seem to find the SV20 in 700x28 even on their website
Liked 2,571 Times
Quoted: 18883 Post(s)
Liked 10,646 Times
Orange seal.
Quoted: 977 Post(s)
Liked 1,638 Times
Holy Mackerel Bat Man... Speciality Tubes Too...
Now lets see, what ever happened to my sew-ups?
Quoted: 345 Post(s)
Liked 237 Times
It's technically an "18-26mm" tube but stretching an extra millimeter in each direction isn't a lot. Rene Herse has them in stock: https://www.renehersecycles.com/shop...or-700c-tires/
Quoted: 241 Post(s)
Liked 232 Times
Teravail Superlight (92g) (These are Quality Bike's house brand. You're LBS should be able to get them if they have a Quality account.)
Quoted: 6233 Post(s)
Liked 4,836 Times
My Bell 700C 25-32 mm inner tubes from Walmart weigh 111 grams. So a little heavier than you want, but they last a long time for me. Several tires will wear out first usually. Watch the stem length if you have deep section rims.
Target and Academy Sports are two of the other places I can find them locally.
Method to My Madness
Quoted: 1970 Post(s)
Liked 1,491 Times
MICHELIN AIRSTOP ROAD (michelinman.com)
I use the version with 52 mm values, which is 98 g according to Amazon, and quite inexpensive:
Amazon.com : Michelin A1 Airstop Road Presta Valve Inner Tube, 700 x 18-25cm, Black : Bike Tubes : Sports & Outdoors
Quoted: 4560 Post(s)
Liked 2,803 Times
Continental Race 28 Light -- much thinner and lighter than the Race 28. Well under 100 grams, although online specs vary from 65 to 82 g. Put it this way -- the Race 28 Light will fit in my Lezyne Road Caddy minimalist saddle pack, with room for tire levers, CO2 cartridge and inflator tool. The Race 28... won't. It takes up pretty much all the room in the bag's main compartment. I usually pack the Conti Race 28 Light as spares for all my bikes. There's room for two or maybe three in my Serfas wedge bag.
The ride feels a little nicer with the Race 28 Light tubes too. Not as nice as the difference between latex and butyl, but nicer than medium/heavy duty butyl tubes like the Race 28 or typical Bontrager and Panaracer standard tubes.
Next step lighter and better ride -- latex tubes. I've ridden Silca for more than a year before any real problems and liked 'em so well I plan to buy 'em again. I think Vittoria makes them for Silca. The Silca branded latex tubes are sized for 700x25 up to 700x30, if I'm recalling correctly. Perfect for my Conti GP Classic tires. But for my 700x23 Soma Supple Vitesse SL, I had to buy Vittoria branded narrower tubes.
Keep in mind that latex tubes demand more care to install. I think both Silca and Vittoria latex tubes are now pre-powdered. Or you can add your own bath/body powder -- I use corn starch, including to install butyl tubes. Helps ease seating and avoids pinching the tube. Latex tubes are more vulnerable to pinch damaged, partly because they're a bit sticky or gummy without the powder, so they get trapped between the rim and tire bead. Silca has a good tutorial video on installation.
And it's best to follow Silca's recommendation to get rid of the cloth rim tape or rubber band rim strips, and use tubeless rim tape instead. Latex needs more support to prevent extruding into the spoke holes and valve hole. I failed to do that and after a little more than a year the base of the valve was weakened and burst after extruding into the oversized valve hole in the semi-rigid plastic rim strip I used... because I was anxious to install the tubes and didn't wait to get proper tubeless tape. Hey, the ride was great for more than a year. I feel like I got my money's worth in a year of very pleasant riding on rough chipseal roads.
Thread Killer
Quoted: 3165 Post(s)
Liked 1,723 Times
Anyway, I’ve been using Aerothan for a short while now, having bailed out on successfully running Herse Bon Jon Extralight tubeless. What I can say is that while they are light, feel fine and have been trouble-free, they’re not as nice feeling as rollin’ that rubber tubeless. It’s a small thing, though, and it does not occupy my thoughts while riding, but it was noticeable when I made the switch.
It’s hard to assess the value of Aerothan outside of weight savings— in my 700x35c size, they weigh a mere 52— so it’s more a matter of faith that they’re more puncture resistant and have lower Crr than butyl, but I’m good with that.
Oh, they hold pressure well, too; better than latex, and more like butyl.
Likes For chaadster:
Advocatus Diaboli
Quoted: 4750 Post(s)
Liked 1,536 Times
Michelin Airstop A1 700c x 18-25. Yes, these will work on 28 mm tires. 93 g according to Michelin.
https://www.benscycle.com/tubes?map=...in&searchState
Likes For rubiksoval:
Quoted: 345 Post(s)
Liked 237 Times
One thing I'd want to know is how repairable they are - i've seen a youtube video where the patch kit specific to it didn't work. Could be a fluke but that is a big warning sign for me.
Thread Killer
Liked 1,723 Times
Troubleshooting a slow leak, I was reminded that I was running Panaracer R’air innertubes in one of my bikes. Thinking of this thread, I threw the 23-25c tube on my scale and got 70g.
I did find a tiny pinhole, which I patched and reinstalled the tube.
They’re extralight butyl tubes, very similar to Conti Race Light, and I can attest to having very good luck with them inside GravelKing 26c. These are wheels which see winter/spring/rain duty, so they get the worst of it in terms of road debris.
Quoted: 345 Post(s)
Liked 237 Times
Liked 1,491 Times
Which type of inner tube holds air the best? - CyclingTips
