Is it hard to get full blown schematics ?
So something I’m looking at is getting some schematics to study on and get a better understanding of individual bikes
is this a concept already?
Quoted: 1074 Post(s)
Liked 295 Times
It’s common to find geometry charts detailing the angles and (virtual) tube lengths of frames.
For hubs there are often ”exploded views” that also serve as spare parts lists. Sometimes even service/assembly instructions.
I’ve seen good exploded views on Campy shifters.
Some assemblies are considered ”not rebuildable” by the manufacturers, and may not have any published schematics. Many Shimano shifters have the actual shifting mechanism, with the pawls and the ratchets, riveted together for instance. AFAIK, if you want to take something like that apart, you’re on your own. Unless you find some Youtube or aftermarket material on how to fix it.
Likes For dabac:
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
geez, this is a broad question. schematics of what, specifically?
some manufacturers provide exploded views of items. others don't. your target is too broad.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Bicycles are component systems. If you want a schematic of a particular component, check the component manufacturer's website for whatever model component you have.
Likes For JohnDThompson:
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
A lot of Shimano components have exploded drawings. Is this something you want?
Likes For mstateglfr:
Likes For Moe Zhoost:
Likes For mack_turtle:
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
Bike frames are made of
Aluminum, Titanium, Iron, Carbon (fibre), Magnesium, wood, or bamboo.
Maybe this helps
Wood and bamboo aren't on this schematic. The metals are also alloys. The carbon frames use numerous other ingredients to hold it together. But this is a starting point of basic ingredients.
Maybe this helps
Likes For Wildwood:
Veteran, Pacifist
Liked 4,836 Times
@mack_turtle you got a part number and compatibility chart for that hyperdrive core? I need one on every bike! Yesterday.
Likes For Wildwood:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Maybe this helps
Maybe this helps
Stuart Black
Stuart Black
Veteran, Pacifist
Liked 4,836 Times
Universe? - hardly.
Quoted: 1944 Post(s)
Liked 2,164 Times
While not in response to the OP’s question, is there a way to get exploded views/parts lists of current Shimano components?
As an example, the old Shimano Tech Docs site provided a .pdf of the component, like a freehub, with a parts list but I can’t find an exploded .pdf view of a new version of the same component. There are just user guides.
John
John
Liked 4,218 Times
Yup. Universe. Of course, that’s the hard bits of the universe.
Stuart Black
Stuart Black
Quoted: 18415 Post(s)
Liked 15,551 Times
Likes For indyfabz:
Bikes: 3 road steelys, 3 alu, 1 mtb, 1cx
Quoted: 20 Post(s)
Liked 22 Times
John
John
Veteran, Pacifist
Liked 4,836 Times
Likes For Wildwood:
Veteran, Pacifist
Liked 4,836 Times
To @justinschulz9
What useful knowledge would a new cyclist learn from schematics?
Rather than schematics, a book like this would be your best friend.
Liked 4,218 Times
Not really. Every element on the periodic table can be seen in the spectra of stars. The nature of the elements also don’t allow for any elements in between the elements we already know. No element between two elements is possible. There can’t be an element between aluminum (13 protons) and silicon (14 protons), for example, because there is no such thing as half a proton. There may be heavier elements that aren’t on the periodic table but, so far, all the ones discovered are highly unstable and split into something else very rapidly.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 1364 Post(s)
Liked 1,677 Times
Maybe this helps
Maybe this helps
Likes For BobbyG:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Of course, you can't know that. And I really like your posts (99.9995% of the time). Of course, I estimated that figure, because I haven't seen enough of your posts to calculate.
EDIT: I expected the OP to have been asking about Di2 or some electronic gizmo.
Liked 2,164 Times
Veteran, Pacifist
Liked 4,836 Times
Believing everything you can theorize, is the first step to delusion and entitlement.
Liked 4,218 Times
Believing nothing is the first step to ignorance.
Stuart Black
Stuart Black
Liked 4,218 Times
Even subatomic particles are part of the periodic table since protons, neutrons, and electrons are taken into account. Protons are the atomic number, neutrons (along with protons) are responsible for the atomic weight, and electrons (equals to protons) are responsible for the atom’s interaction with other atoms.
But, outside of a few ephemeral heavy elements, all matter in the Universe is contained within that table. All kinds of combinations of those elements can result in some very strange bits of matter but that doesn’t invalidate the elements in the periodic table. The weird bits are still made of the known bits.
Stuart Black
Stuart Black
Randomhead
Liked 3,698 Times
Likes For unterhausen:
