Stripped Hex Bolt Head
Bikes: Diamondback "parkway" Spec. "expedition
Quoted: 47 Post(s)
Liked 42 Times
Friend stripped hex bolt head (it recessed into adjustable stem) what is the best / easiest way to removed bolt?
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
Try a torx bit.
Quoted: 166 Post(s)
Liked 252 Times
sometimes.
I would spray whatever you have with lots of PB blaster or something close and let it sit before I did anymore damage. if the bolt stripped because its a ball of rust inside the head tube its best to free that up as much as possible.
Quoted: 47 Post(s)
Liked 42 Times
gonna tackle this over weekend. Friend wanted to adjust the handlebars closer. Got 1 bolt out and looks like the wrench was put in at an angle and stripped the head
Thanks for the assists. will advise when resolved.
Likes For bktourer1:
Quoted: 1438 Post(s)
Liked 1,092 Times
The problem with trying a bolt extractor is that if you break the extractor now you have a piece of hardened steel stuck in the drive recess to contend with. I would suggest pounding a Torx or oversized hex (perhaps fractional) into the opening. I have also had success with epoxying a sacrificial hex driver into the recess; it is much less likely than an EZ-out to break off.
Sierra
I recently experienced a similar situation. The torque was too high to get any backout bite. I used a Wera Hex-Plus bit for the save and swear by them now.
A persuasive testament to the effectiveness of the hex-plus (TLDW @ 12:10)
Likes For ChrisWagner:
SE Wis
Quoted: 2747 Post(s)
Liked 3,397 Times
Technically speaking if you ask for a hex head bolt this is what you are going to get.
What you are trying to remove is an Allen or socket head bolt
Likes For dedhed:
Quoted: 1572 Post(s)
Liked 643 Times
Once you have toe stripped bolt out, you've solved only half of the problem.
Find the allen wrench you were using when it stripped. Throw that sucker away and buy a new one. DO NOT save it somewhere for a spare.
Quoted: 1529 Post(s)
Liked 718 Times
I work on hydraulic stuff like excavators a lot, and they are a total bastard. When I come across a barely-accessible rounded-out allen head, I want hex plus on my side.
Thanks for the tip!
Likes For Kimmo:
