kids' bike wheels conversion to QR feasible?
Bikes: 2020 Trek Domane AL 3, 2019 Giant Escape RX Disc
Quoted: 52 Post(s)
Liked 15 Times
I recently bought this kids' bike: https://www.giant-bicycles.com/us/escape-jr-24
The bike's spec sheets says it has "Joytech nutted type, 32H" hubs. There's some kind of black cap or nut with shallow grooves on it where I'm used to seeing quick release skewer ends on adult bikes. See pics below. I don't even know what tool is supposed to be used to take that black cap/nut off. Anybody know? It seems to be on too tight to just remove by hand.
Is it feasible to install QR skewers on wheels with this type of hub? If not, is it feasible to take off that hub, buy a QR-compatible hub and lace the spokes to it instead?
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
It's a kids bike likely just a plastic protector to prevent "injuries" from a axle end. Probably pops right off exposing a nut. If it's actually metal a pair of vise grips or pliers will probably unscrew it.
To go QR you'd have to replace the axle with a correct thread and length hollow axle and skewer. A lot easier than replacing the hub.
Likes For dedhed:
Bikes: More bikes than riders
Quoted: 1438 Post(s)
Liked 749 Times
Yes -- just wiggle that black cap side to side to pull it off (it may take a pair of pliers to get enough purchase on it). I bet there's a hex pattern inside that's designed to engage with and fit over the axle nut. That, or the material is soft enough to where it just conforms to the nut when it's pushed on.
Likes For hokiefyd:
Quoted: 52 Post(s)
Liked 15 Times
Thanks for the replies, all. The conversion looks like a fun project for a rainy day.
Liked 1,092 Times
Depending upon the size and strength of the kid, they may not have enough hand strength to close a QR sufficiently tightly. Using the internal cam type will help some, but....
Likes For dsbrantjr:
Liked 1,092 Times
Quoted: 6100 Post(s)
Liked 4,732 Times
There is nothing magical about having QR's on your bike if you aren't always needing to remove your wheel.
I guess it might be a fun rainy day thing as you say, but to need to look like all the rest seems a tad ..... well I don't know what it seems like.
Quoted: 52 Post(s)
Liked 15 Times
I have car interior and roof racks with fork mounts that I use to transport bikes, so QR is much more convenient for me. Just didn't have the budget for a bike that came with QR wheels this time. The parts needed for the conversion look like they'll be affordable though.
Likes For el forestero:
Quoted: 1073 Post(s)
Liked 999 Times
Take the axle nut into a hardware store and there's usually someplace you can screw it on to and find out the thread pitch and diameter. I'd thought of doing this with an old trek MTB for a similar reason but the axle was an odd size for being a QR and the cheapest I could find was about 30.00. Cheaper QR axles are plentiful but then you need to find cones and lock nuts that fit and don't leave an excessive gap at the dust shield. Since you can't try till you buy on that one it seemed like too much hassle to bother.
Likes For Russ Roth:
Quoted: 194 Post(s)
Liked 204 Times
I suppose whether one fits a QR or not depends on how the bike is to be ridden. My folks were not into family rides, so I needed a bike that could safely smack into things as I rode along an abandoned railway line to the next village at the age of 8 years and still get me home.
But for frequent transport - well, let that winter project roll on!
Likes For Geepig:
Quoted: 508 Post(s)
Liked 434 Times
Bolted axles are 3/8". Quick release axles are 9.0 mm for front, 10.0 mm for rear. When converting you will need to replace the cones, lock nuts, and spacers. Remove the axle and take it with the the hardware and the wheel to a bike shop and they will help you find a replacement axle-cone assembly that will fit. You might also need to take a file to the frame to enlarge the dropouts.
I can guarantee that a hardware store will not have the nuts and cones you will need for a replacement axle.
Likes For oldbobcat:
Quoted: 52 Post(s)
Liked 15 Times
SE Wis
Liked 3,361 Times
Can't vouch for this product but...
https://www.amazon.com/Axle-Release-.../dp/B004Y97ZLK
Verify the thread but there are 3/8" X 26 tpi hollow axles out there. The other common threading is 3/8 - 24
https://porkchopbmx.com/porkchop-bmx...m-long-silver/
https://www.ebay.com/itm/BICYCLE-3-8...-/391521110659
Likes For dedhed:
