Recumbent veteran to upright newbie
Quoted: 896 Post(s)
Liked 2,065 Times
After 10 years, ~35,000km of randonneuring on a recumbent, with multiple 1200s, I'm giving it a go on an upright bike, with the goal of completing PBP in 2023. It's a work in progress, to be sure. I've said it a few times about my upright rando friends: they finish a brevet tired and sore, while I finish it tired. My turn to address the soreness issues. Thus far I've completed about a half-dozen 200k rides, with a few issues to resolve. Low back pain, hand numbness, and saddle discomfort.
I've been finishing these 200ks with quite a bit of low back pain. The last couple hours are pretty much dominated by back discomfort. A moment off the bike, stretching, helps for a short time. I've not had success stretching while on the bike. Back in my 30's, when I switched to a recumbent, low back pain was the issue. At 60 my back is far better than in those days, but this is definitely issue #1. It must be resolved if I'm going to do anything longer than a 400k.
A distant second is hand numbness and pain, particularly my left hand. It comes on as early as 30 miles in; I rest my left hand behind my back for a moment for relief. I've measured carefully, and the bars are straight. Everything is even on the bike, as closely as I can tell. Maybe my body isn't left/right symmetric. I might try offsetting the bars by a few mm and see what that does.
Saddles. Jeez, this isn't my favorite part of an upright bike. My Selle Anatomica seems like the most comfortable saddle I've every used, and a moment out of the saddle from time to time takes the edge off. I don't think there's anything to do here except saddle time and see what a fitter says.
May 1st is a 300k.
May 1st is a 300k.
Randomhead
Liked 3,698 Times
I admire your switch, I hope you can work things out. It took me a lot of fiddling to get to the point where any problems I have with discomfort are related to fitness rather than position.
I used to have low back pain and riding got rid of it. I don't think that 'bents use your low back as much. Eddy B (rip) used to insist that sit ups help lower back pain. I think this is one reason cyclists do squats.
I have gotten rid of hand pain for the most part through small changes in my position. A little longer stem and seat back a little.
I have never been sore at the end of a 1200k. Other distances, yes. I sometimes have trouble with neck soreness, but I am able to do shoulder rolls on the bike and that helps a lot.
I'm in the midst of the same transition ('bent to DF), hoping to get back into rando and maybe even ride the next PBP. But if not for having to stop and pee every 10 miles riding the 'bent (I can do 30-40 mi nonstop on the DF, no prob), I'd probably still be on the 'bent.
Quoted: 2333 Post(s)
Liked 2,097 Times
Ghostrider reached down into the unterworld, Rip said iliopsoas muscle pains in lower back on long rides can indicate weak stomach muscles or sometimes too high of a seat post can tweak the hip flexors. He said he would try to remember another cause, he had been so long on a bent on the other side, his memory is impaired. He congratulated downtube42 escaping the darkside and entering back into the light.GL!!
Liked 2,097 Times
Unknown what model recumbent but in general, it harder to engage the hip flexors on a bent than it is on an upright. In my experience, my hip flexors have weakened from bent riding while my vastus lateralis had to develop on the bent. I took up hiking and preparing for the Appalachian Trail, I was very surprised to have soreness in my hip flexors but that has been fixed.
The hip flexors fatigue much quicker than the much larger extension muscles (butt, vastus lateralis, etc). Many cyclists still think pulling back and up is helpful but this has been proven in many studies to be false. On long rides, working these relatively small muscles often manifests in sore lower back (that is where these muscles attach). Another possibility albeit unlikely is an extreme difference in Q factor between your bent and upright. I suppose going from one platform to the other is almost like starting anew WRT to training and it is easy to overextend oneself. Once I went midsole and elliptical chainrings, I just pushed and never pulled. No leg cramps, no foot pain, and no back pain. These types of aches and pains only show up on long rides, so, I am sure everyone here has experience them at one time or another. YMMV. GL.
"The primary hip flexors, psoas and iliopsoas, originate on the transverse process and body of the T12 – L5 vertebrae. Essentially the pull on your lower back. If you are using the muscles extensively they can start to fatigue your lower back and lead to a lordotic curve in your lumbar spine. This is often a cause of lower back pain in cyclist and triathletes.
"""Problems Associated with Pulling Up on the Upstroke""
"""Over-use of the hip-flexors when the hip joint is closed can cause all sorts of issues:
• Lower-back pain
• Tightness and pain in the hip
• Loss of power and efficiency"""""
(I cannot post the links but those quotes come from reasonable sources, sorry)
• Lower-back pain
Randomhead
Liked 3,698 Times
Your lower back muscles are involved in pushing too, I don't think most of us pull up much.
There are some muscles that I manage to recruit somehow while climbing. More pushing before the pedal reaches the top than pulling at the bottom. It really feels great until I cramp. I am not a good climber on my best day.
Liked 2,097 Times
I was thinking of Downtube42 coming from recumbents, where scraping and pulling back are often recommended pedaling techniques. I did not mean to be pedantic, merely completing the original post when I could not remember another cause albeit more common with less experienced riders new to distance cycling.
Steve Hogg had had a video on this very subject of lower back pain but I think it is now behind a paywall or I can no longer find it. Pushing before the top of the stoke can be efficient if you either ankle or sort of rotate (not rock) the hip backwards (posteriorly) and slightly tilt the bike. Getting over the top is important, of course. On most recumbents (depends on seat type and angle), your torso is generally locked and the muscle engagement is a bit different than riding an upright. Hogg's video had the upright rider without a jersey with black magic marker dots to see the overall movement of incorrect and correct pedal technique. It appeared to me that the hip moves back slightly just before coming over the top. I theorize that the inability to make that little move is one reason recumbent riders often go to much shorter cranks, 140-155mm or shorter. It isn't just the hip opening up, it affects the knee angle too. I stuck with long cranks, but "cheat" on the first 10 degrees (Rotor RS4X). I wish OP best in going back, I suspect it won't be easy trading bent legs for upright legs.
I found brevets and grand randonnees easier overall on an upright but there isn't an easy way to make a direct comparison.
Likes For GhostRider62:
Randomhead
Liked 3,698 Times
I wish I could figure out a way to train those muscles, because it really feels great until I cramp. Which has never failed to happen. Problem is I'm not really sure what I'm doing.
Quoted: 896 Post(s)
Liked 2,065 Times
I'm just going to admit this: When it comes to descriptions of body mechanics, like hip flexors or pelvic rotation or open hips, I have no concept. Somebody says with great authority well your hip abductors are doing this... wtf. Sure I can find an anatomy book, but I don't feel anything going on there, and in general I have no awareness of any specific muscle unless it hurts.
Are my hips wide open like a barn door or closed like a mousetrap? I have no idea. Here's what I do know about my hips: they don't hurt. After a 1500k they didn't hurt.
Is my pelvis rotated so far back it's pointing at the sky, or down waving hello to China? No idea. Also, no pelvic pain, ever.
Do I pedal in squares or circles? I'm just pedaling. Sometimes I get hotfoot, but aside from that generally no pain below the waist no matter the distance. Am I efficient? Probably not.
I occasionally get cramps, in quads or calves or or toes or inside thighs - the latter when climbing. I mostly tell them to shut the f up because they will get no sympathy from me, then perhaps slow down a bit, and carry on. For lower back pain I'll stop and stretch my back, which helps for a bit. I have learned that ignoring low back pain has very negative consequences within 24-48 hours of the event.
Point being, my primary muscular feedback and awareness is from pain.
Liked 2,097 Times
Wish I could help. My better half has this problem. I only had cramps twice IIRC on an upright. Once was the day after doing 211 miles and 26,000+ feet of climbing in Ky/Va with scores of sprints escaping viscous dogs. The next day, it was like, "So, this is what everyone talks about with calf cramps" Another fellow shared some packets of mustard or relish (I forget which) and it did help a little. There are a lot of theories out there. I dunno.
I recently got painful cramps in my feet after switching from a 10mm drop hiking shoe to a 4 mm drop. Very painful. I did a lot of reading but the research is scant but lots of anecdotes. I decided to switch back and forth to slow the conditioning process and after a month, my feet can handle the new shoes.
Liked 2,097 Times
Go Ride
Why give up the recumbent? I choose to use to use an upright or a recumbent on appropriate courses.
May 1st is a 300k.
May 1st is a 300k.
Quoted: 896 Post(s)
Liked 2,065 Times
Go Ride
Liked 2,097 Times
I probably need to have John Morciglio custom build me a fast recumbent that can handle something wider than 25 mm.
I did have an Alpha 7 for about 2 weeks, it could handle wide tires.
