Simplex SLJ 5000 RD part needed.
Liked 1,443 Times
Simplex SLJ 5000 RD part FOUND
FOUND ONE. Thanks all.
I posted this in the ISO thread also but on the chance a lot of you don't check it often (like me) I'm duplicating my plea here in hopes of getting more eyes on it.
I have a very nice 1st design Simplex Super LJ 5000 RD but it has one small issue, the tension plate (see pic) has the stop tab broken off and I am in need of a replacement. If anyone has a spare or a non-repairable SLJ with this particular plate I would gladly buy the whole thing.
Ride, Wrench, Swap, Race
Liked 1,391 Times
Can you not install it as is, and (before fully tightening the rear mounting bolt), adjust the B-tension manually using a hex key, before fully tightening the mounting bolt?
I find it likely that the B-tension adjustment will hold, as there should only ever be spring-limited force pulling the derailer body forward (even if the chain were to go full-tight by some instance of chainsuck, etc.).
Alternately, a skilled welder could re-establish the mounting tab, at whatever position that your testing deems optimal (leaving perhaps some extra metal for you to set your adjustment later using a file or Dremel).
Making a new plate from scratch wouldn't be too hard, starting by scribing the existing plate's dimensions onto some sheet stock.
I would make the tab wider than needed, as reinforcement.
The Huffmeister
Bikes: Gängl, Trek 938, Raleigh Professional, Paramount, Allez, Guerciotti, Specialized Stumpjumper, Trek 750, Miyata 1000 < Huffy
Liked 4,008 Times
Bro, let me check the Simplex RD on my PXN-10. If it has the same part you need I'll just send the whole thing to you.
Standby for pics....
There were 135 Confentes, but only one...Huffente!
The Huffmeister
Liked 4,008 Times
Yes?
Liked 1,443 Times
I got this to put on my '77 PR 10 frameset, after a repaint of course.
The Huffmeister
Liked 4,008 Times
Haha, yeah I realized after I posted that, it was a bit vague - did I mean the whole derailleur or the whole bike? Honestly, I'd good w/ either interpretation
If I asked you for $$ for this thing you have the right to slap me! Just PM your addy and we'll be gtg.
The Huffmeister
Liked 4,008 Times
