Tire and tube suggestions
Bikes: Bianchi San Jose, Dahon Mu Uno, Origami Wasp
Quoted: 118 Post(s)
Liked 23 Times
I need to buy new tires and tubes for my Bianchi San Jose. It came with all terrain tires that I just never got around to changing and am now wanting to finally do it. They are knobby and slow. I want a smooth profile that's not hideously expensive. I ride 70 percent on the street, 20 percent on bike paths, and 10 percent through yards when Miami drivers try to run me over!
Any suggestions would be helpful. The tires on there now are 700c 32/30. The rims are 622 x 14.
Your cog is slipping.
28c Gator Hardshells FTW.
Gatorskins and Hardshells give a semi-harsh feeling ride at smaller widths but the 28mm will help soften it a bit, while still being a fast-rolling high-psi tire. They're also pretty indestructable.
Calamari Marionette Ph.D
Do you want the same size tire, or larger, or smaller?
What is your budget?
Bikes: Wabi Classic, Schwinn Madison
Quoted: 19 Post(s)
https://www.probikekit.com/bicycle-tyres/michelin-pro4-endurance-v2-tyre-twin-pack/11322994.html
And a gatorskin twinpack
https://www.probikekit.com/bicycle-tyres/continental-gatorskin-folding-clincher-tyre-twin-pack
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times
I run 28c Gatorskins and really like them for the less than ideal roads near me (bumps, debris, etc..). They roll well and best part is they are tough, I was getting flats constantly before switching. I run the folding version mainly to make them easier to get on and off.
Fresh Garbage
Panaracer RiBMO!! IME they are also pretty indestructible, have a smooth ride, and are relatively inexpensive.
Quoted: 118 Post(s)
Liked 23 Times
Thanks for the suggestions so far. Gives me a good start on what to look at.
Ant specific tubes that are commonly known to be reliable?
How narrow? And why?
Going from a knobby to a slick of the same size will be a huge difference in smoothness and speed. Going to a smaller volume size will produce a harsher ride than you have now. I'd stay with the same size and just buy a quality folding bead slick, which you can for $50 no problem. FWIW I have Schwalbe Kojaks which measure 32mm on narrow rims like yours. I dig them.
Quoted: 118 Post(s)
Liked 23 Times
Thinner will wear out faster. By thinner do you mean "Narrower?
I broke from the samo-samo mould when I got my Wabi fixie and installed 700cx30 Challenge Strada Bianca "open tubular" tires. Oh man, I love the ride on these tires and am looking to convert my old Pinarello to the smaller diameter (27c) Paris Roubaix's once the current tires (Vittoria Rubio's) wear out. I've ridden a lot of tires over the years and miss the ride of tubular tires.
Well, it's back! These Challenge tires have a road feel that just isn't replicated in many tires any more. Yes, 30's are wide but the suppleness and speed of these tires makes them roll and feel like a 25c tire with the smooth ride of a larger tire, and they are really sticky on corners to. No kidding. Plus, they are hand-made and cold laminated. With 260 tpi skins, these are tough tires to.
If you can run 30's through your frame, I highly recommend the Challenge Strada Bianca's. You'll love the speed and smoothness. Yes, mounting them the first time can be a challenge but after that and on the road they are a piece of cake.
Clark W. Griswold
Quoted: 4369 Post(s)
Liked 4,008 Times
Since you can fit a 32c tire I would go with the 32 rather than 28s.
For tubes, Continental is my go to brand but we sell Q-Tubes and Specialized tubes which are just fine and dandy.
Quoted: 118 Post(s)
Liked 23 Times
Do I have to worry about any other sizes when ordering other than the 700 x 32? I mean the rim size? 622 x 14?
Clark W. Griswold
Liked 4,008 Times
One useful thing to note, different rims and different tires will give you different tire widths so you could have the same 25c tire that is wider on one rim and narrower on another or have two different 25c tires on the same rims and the measure out differently.
Here is the most info you will probably ever need for tire sizing (unless some new modern stuff comes out and John Allen isn't around to update and nobody takes over):
Tire Sizing Systems
Quoted: 118 Post(s)
Liked 23 Times
Ok cool. I actually read Sheldon's site last night but even after all of it I still wasn't sure about the rim size so thanks, Veganbikes, for clarifying.
Clark W. Griswold
Liked 4,008 Times
If you choose a tire that is available in both wire bead or folding bead, the folding will be noticeably lighter in your hand and when pedaling. More money but might be worth it to you if you are looking for more efficient acceleration.
Quoted: 89 Post(s)
Liked 15 Times
Gatorskins ride like crap. Depends on how much you want to sacrifice for durability. Those Challenge Strada Biancas are probably the other end of the spectrum from a comfort perspective. I like Paselas for a good compromise in an inexpensive tire. I use the T-Serve Messengers which I'm not sure they still make or perhaps have been re-named. Not as harsh as Gatorskins yet still durable.
Quoted: 118 Post(s)
Liked 23 Times
Panaracer T Serve Protex? They are marketed as the tires bike messengers use the most. They get consistently good reviews. I was about to buy the Gatorskins but now I'll have to think about it. The Strada Biancas are too pricey.
Quoted: 1332 Post(s)
Liked 398 Times
I have 23's on my track bike. Road bike has 25's and is probably gonna stay there, SS beater/cushy bike has 28's. 23's on the road are fine IMO, but I think the little extra cush of 25's is nicer. Some articles lately are saying 28 is the new 25, which was the new 23.
Fresh Garbage
Quoted: 399 Post(s)
Liked 274 Times
In fact - just switched back to skinnies from 28s on my Bridgestone roadie, which of course was made to accept bigger tires, & is a bike that it seems everybody loves to shove in the fattest they can.
Apparently as usual, I am heading the wrong direction from what's trending
