Recommendations for a good front "be seen" safety light?
Hello everyone,
I decided to invest in a good set of "be seen" lights for my road bike, since on my weekend rides I tend to have to share the road with cars quite a bit. (I wish I could do all dedicated trails, but I can't).
I got the Knog Blinder R70 taillight, because of its 70 lumens rear brightness, which is good for grabbing car's attention even in bright daylight. Very pleased with it so far. Well built and bright. Easy to fit on the bike.
Now I'm looking for a front light to grab attention "be seen" as well. Something
- Small, easy to fit on the frame (NOT a full on headlight, I don't ride at night with this bike)
- Blinking mode
- Bright
- Preferably decent battery life
I'm looking at the Knog Blinder Mini Chippy, since I am impressed with the build quality and brightness of the Blinder R70 I got for the rear.
https://www.knog.com.au/blinder-mini-chippy.html
But it is not cheap, and so I am wondering if there are better alternatives out there?
Thanks!
- Blinking mode
- Bright
Thanks!
Is the tail light adjustable so it's not angled down when attached to the seat post? I'd get a flasher for the front that is brighter than 20 lumens for daytime and use the strobe feature.
Quoted: 2338 Post(s)
Liked 2,824 Times
i'm a fan of the cygolite brand.
As far as a be seen light, go with a reflector and any cheap blinker.
I have a cygolite expilion 850 and a cygolite metro 450. I do off road trail riding during night though.
I couldn't find anything cheaper than $30 from cygolite, even their lower end ~100 lumen offerings cost around $30.
If $30 is an acceptable price for you, you can get a 500 lumen light from cygolite. It's important to note, lights designed to output more lumens usually have larger batteries which will last longer for just blinking.
https://www.amazon.com/cygolite-metr...dp/b00e1nq3du/
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
To be see I'd recommend a light that has a wide beam/dispersion. I've got a Lifeline brand 300-lumen light that was great for this. Bright enough to grab attention and bring enough to see as well, though my route is well lit.
+1 on the Cygolite Metro 450. Very bright flash mode in bright daylight. Some say "irritatingly" bright. Bright flashing lights are present on all manner of vehicles from school buses and motorcycles to emergency vehicles and garbage trucks. There's a reason, THEY GRAB ATTENTION of other motorists. I'm not very worried about irritation. At night would be a different story.
The Cygolites are bright. Battery life is good (rechargeable) I've ridden 112 miles and it was still blinking after a full day. I usually recharge after every two rides which vary between 40-50 miles usually.
Thanks for the suggestion, I will look into something brighter. They also make a larger version of it which is 80 lumens, should be good for daytime use I think.
I'm a fan of the Cygolite brand.
I have a Cygolite Expilion 850 and a Cygolite Metro 450. I do off road trail riding during night though.
https://www.amazon.com/Cygolite-Metr...dp/B00E1NQ3DU/
Good point, I will take the wide beam into consideration.
Bikes: ...a few.
Liked 409 Times
I have a Metro 400. It's a very good light with excellent battery life...however, the beam is quite narrow and focused. Good for seeing where you're going as it can project a beam far ahead, so great for trails and unlit roads, but perhaps not great for others to see if they are not in the narrow field of view.
Poseur Extraordinaire
Quoted: 41 Post(s)
I have a pair of Blackburn Super Flea's. The form factor is small; these are daytime 'be seen' lights. Three settings: blink, solid low, solid high, with advertised run times of 5 hours, 3 hours, and 1 hour.
There's a 1.5 hour out-and-back ride I do regularly. I start with one light on blink and one on high. At the midpoint, I switch. On longer routes, I will use blink and low.
Bad example
Quoted: 826 Post(s)
Liked 212 Times
If you want to be visible, get a helmet light rather than a frame light. Frame lights tend to be hidden behind parked cars and traffic. Helmet lights do not get hidden. I personally use Light and Motion 360+ and love ‘em.
Quoted: 2112 Post(s)
Liked 663 Times
Con is if you think Mini Chippy is expensive, Mr. Chips is more so.
But it is bright enough to be seen during the day, and with a 120 degree spread so you don’t have to worry is anybody seeing my pencil beam. As far as blinding others, not during the day. (At night, you need another light.)
For me it’s a great light for daytime in the city, no matter if bright or overcast. Also in areas with mottled lighting, such as going in and out of tree shadows for example.
One last point, retroreflectors on the Knog lights are a checkoff item. BUT, retroreflectors in the daytime are useless unless the sun is right behind the viewer, and even then next to useless. Why are some people here recommending reflectors for daytime use?
-mr. bill
The Knog Mr. Chips.
-mr. bill
Exactly, would be great for daytime visibility at intersections with the wide beam. Also when it is bright out but you get under some tree canopy. Around here drivers tend to be blinded by the sun and then have poor visibility in tree shadows.
Liked 663 Times
For long day rides eco flash is fine both for visibility and battery life - and you are right, it's a somewhat interesting flash pattern, alternating left half/right half, but a fairly slow strobe.
-mr. bill
-mr. bill
Non omnino gravis
There is a vast divide between what is a good headlight and what is a good "be seen" light. For a daytime running light, I go for a Blackburn 2'Fer. Claims 60 lumens, runtime around 5 hours, will clip/mount pretty much anywhere, and can be had for about 20 bucks. Good angle dispersion on the light, plenty visible even from distance. And for the people that obsess over how much things weigh, a whopping 18 grams.
Quoted: 8 Post(s)
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
Hello everyone,
You should also go for a rear light on your helmet.
If I could only have one rear light, I would choose one on my helmet, over one on my rack or seatpost, every time.
As for a front headlight, whilst I expect this would be more than you want to pay, I would recommend something like a Cateye Volt 1600/1700, which has a day time flash which consists of two flashes combined, with one flash going at 200lumens and another flash at 1600lumens.
In addition to the high lumen output, this particular flash setting will last over 20hrs, so you don't have to be recharging your light all the time.
The Stupidbright SB3000 Headlight and the CygoLite Hotshot Pro 150 Lumen Tail Light were both selected by me for their extreme brightness and their reasonable cost. I would not hesitate to recommend these devices.
Most of my operation is during daylight hours and these lights fit the bill for maximum visibility.
IMO it is not advantageous to increase the mass of the helmet any more than required, because that additional mass can increase personal injury in a crash.
Bikes: 2010 Trek 7100
Quoted: 697 Post(s)
See if you can track down a Guee Sol 200. Some are apparently discontinued, so we're getting them well below cost. It's not hugely impressive at MSRP, but with the discount, it makes an excellent backup or city commuter light. Slow and fast strobe modes, and USB rechargeable. (Before anyone asks, I haven't tried the plus model, so I have no idea whether it's really an improvement.)
https://www.walmart.com/ip/GUEE-305-...&wl13=&veh=sem
(Only one left there at time of posting, but you should be able to find the non-plus model for around US$20 somewhere.)
corrado33
1
10-28-14 01:50 PM
Chris Pringle
16
02-11-12 09:58 AM
