I bought a bike for commuting. What upgrades should I make?
Bikes: an HM Snakehead and a Kona Dew
Quoted: 8 Post(s)
I'm no professional cyclist, nor some rich kid with a ton money to spend. I bought a Kona Dew a couple weeks ago and I absolutely love it, but I'm worried about problems presented by the quality of the roads I take to get to work and school. I would greatly appreciate any advice on what upgrades to make to the bike to preserve it and to prevent malfunctions and failures while on the road. Thanks
At the very least, I recommend an underseat bag with a spare tube, patch kit, two tire levers, and size 4 & 5 Allen wrenches. Then, get a decent frame pump and some cheap bottle cages and bottles. You could also get one of those Park Tool bicycle multitools in lieu of the Allen wrenches. Other than that, just keep it maintained well (chain lube, regular adjustments, check the tires for wear and tear, clean it / keep it dry when not riding, etc.).
Also, don't forget about lights (front and rear), a bell to warn pedestrians that you are approaching, and maybe some reflective clothing if you commute before sunrise / after sunset.
As always, get a good, well-fitting helmet.
Don't go for junk, but there's no reason to get the super-expensive stuff that you'll see advertised everywhere.
A very secure lock..
You are not really needing 'upgrades', but adding useful accessories..
Regular bike maintenance and upkeep is all you need. If you don't know about bikes, either waste your money taking it to the local bike shop, go online or go find a used bike maintenance book and learn how to do basic maintenance. The most common and used tools will be Allen keys, a 10mm wrench and maybe screwdriver. If you bike a lot, I also recommend a chain break tool. Don't believe that this forum is used by only the wealthy. I'm sure enough of us are dirt poor. Also, check to see if there's a bike co-op near you.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Buy a small saddle bag, some tire levers, and a spare tube. Hang all that under your seat. Buy a frame pump and hang it from a convenient spot on your bike. Find a lock suitable for where you are parking and leaving your bike unattended.
Past those things, the upgrades will become evident after riding a while.
Mount the rear flasher on the seat post so it aims back where you set it to all the time, not on your helmet or backpack. If you use a solid white front light to see, also put another on that flashes.
Quoted: 111 Post(s)
Liked 5 Times
One change I would advise is to get some puncture-resistant tires, such as the Schwalbe Marathon Plus. These tires are heavy and slow, but they're still not as slow as getting a flat tire--and they make flat tires a lot less likely. And then skip the patch kit.
Schwalbe M+ tires are kinda expensive in the US. If you have a bike with 28" / 559mm wheels then you can try the CST Salvo tires, that are a Cheng Chin copy of the Marathon Plus. Unlike the Marathon Plus, the Salvo only comes in one tire size (26" x 1.75).
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
What we talk about endlessly on the commuting forum are...
inclement weather
darkness
luggage
parking
breakdowns
The kind of repairs you can make on the roadside, and all adjustments, are pretty easy with a standard bike multi tool and maybe a Leatherman.
inclement weather
darkness
luggage
parking
breakdowns
I guess good fenders are nice to have on a commuter. Personally I prefer honjo brass fenders. for the bling.
then good tires, that are puncture proof. if you are riding lots of glass/herion needles and sh1t like that i recommend any schwalbe/continental tire that is smooth and says PLUS on it. then it has this extra rubber foam layer inside it. totally bullet proof.
then we have saddles. this a personal taste pretty much but my butt likes selle italia slr series. and i guess any other saddle that has the same profile as seen from the side.
then we have handlebars. and this is very personal too. only you can deciede whats good for you here. I have tried flat bars, mtb risers, nitto dirt drops, short/shallow ergo road bars, nitto north roads, north roads up side down, time trial bars. you name it i have it (and have seriously tried it).
the problem with changing bars is this: you sometimes have to change shifter systems/rear mech/brake levers/stem length (and it can be a very big difference in length with stems)
on a road bike my ETT (effective top tube) is 55cm and one mtb is 58-60 or so. if you have a mtb/flat bar on a bike and swap to regular road or short/shallow road you need to get a 5cm shorter stem pretty much, and a lot of steerer spacers to rise it up.
if you go nitto dirt drop you will need to go like 8cm shorter and 7cm higher lol no kidding.
My personal favorites that reside on my bikes is a nitto dirt drop. i regard this the most ergonomic handlebar ever made, and also the best ever made.
https://www.benscycle.com/nitto-rm01...14_870/product
runner up is vision time trial base bar in aluminum. its just the lower base bar here
and nitto north road up side down https://www.benscycle.com/nitto-b302...70-530/product
north road takes mtb shifters and brakes (22,2mm) the vision is also 22,2mm and the dirt drops are 23,8mm so shifter mounts needs to be modified A LOT (in position/angle/distance) to fit.
and xt 9sp shifter mounted on a vision alu time trial base bar, with cane creek reverse levers
xt 9sp on nitto dirt drop, made with a cordless drill and files
a bad ass mod plain and simple
questions?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
This is number one.
If you use the bike to get to work and school then it must be reliable.
Learn to look for issues such as worn tires, brake pads and chain and how to do basic maintenance such as change/patch tubes and tires, lube, tighten bolts properly and adjust brakes.
Keep it clean and well maintained and it should last a long time.
Quoted: 7348 Post(s)
Liked 2,469 Times
Get a bottle of Chain L chain lubricant. It's excellent stuff.
I also think a floor pump is a wonderful thing. When I got one, I wondered why I had toiled so long with a portable pump.
I put a lot of value on good lights, headlight and tail light. I tried to be satisfied with inexpensive lights, but they just don't do it for me. Budget at least $50 for a headlight and $30 for a tail light.
If you're interested in upgrading your bike, you get the most performance gain per dollar with tires. Components don't make the kind of difference people claim. Cheap components usually work just fine.
Quoted: 6193 Post(s)
Liked 4,809 Times
You'll spend more money trying to prevent things you imagine are going to happen as opposed to just letting the things that wear out tell you whether they should be simply replaced or upgraded.
The only other upgrade scenario I like is when your level of riding changes and you have to change a tire size, gear ratio or even the entire bike to accommodate that.
There is a commuter forum with lots of good information.
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
I'll add dyno hub and lights if you will be commuting in dark. I messed around with battery lights for a year before I was enlightened. They are brighter, never lose charge, and if you get the right light you can charge your phone as you ride.
Quoted: 1062 Post(s)
Liked 665 Times
Just to play devils advocate, since you mention riding to school, maybe a seat bag for your repair kit is inviting theft. Since all students carry backpacks, you could just keep that stuff in a pouch in your backpack.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
fenders, lights and a bag. personally i like using a dynamo hub so my lights are always on but almost any lights will work. fenders are really great things to have on wet days. welcome to commuting by bike. its a great way to get around.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
@2wheelride It looks like your bike is pretty much made for commuting. Flat bar, disk brake, 35mm k-guard tires; I'd say there's not much 'upgrading' needed.
Lights and a bell are must-haves for any bike that spends a lot of time on city streets. Fenders, or a least a mudguard/splashguard, because you never know.
A spare tube, pump and patch kit means that a flat tire is a 10 minute delay, rather the 'Walk of Shame'
If you do a lot of curb hopping, you may want to get a bigger (40mm+) tire, as the frame permits, to smooth out the ride, and make life easier on your rims.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Upgrades and accessories, one of our top topics here!
Since you are concerned about your rough roads and breakdowns, top of the list is a multitool, flat repair kit, and a saddle bag to carry them in. Plus a spare tube and pump (or CO2 pump. The saddle bag is a small wedge or rolled-up shape that hangs under the saddle, to put this stuff out of the way and forget about until you need it.
To me, the next most important accessory is how you carry your commuting stuff. Some people are happy with just a backpack but if you're not, a rear rack is convenient and gives you options. I bought a $12 steel rack from Amazon and it's worked brilliantly for my purposes for several years, so you don't really have to spend on that.
Quoted: 5224 Post(s)
Liked 3,581 Times
upgrades? huh? what? we're going shopping?!
- flat protection tires, a smidge wider than what you have now
- fenders
- rear rack & matching clip-on trunk
- strobes front & rear
- extra tube, flat repair kit & pump
- cpl tools or multi-tool in case you need to make an adjustment before you get back home
- mirror for your safety glasses
- & all new clothes!
- Soli Deo Gloria -
Liked 736 Times
A summary of this thread is as follows.
The OP should get:
underseat bag
spare tube
patch kit
two tire levers
reflective clothing
well-fitting helmet
a very secure lock.
10mm wrench
screwdriver
chain break tool
small saddle bag
frame pump
rear flasher
puncture-resistant tires such as the Scwalbe Marathon Plus
CST Salvo tires
leatherman
good fenders
selle italia slr
handlebars
a 5cm shorter stem
a nitto dirt drop
nitto north road
floor pump
good lights
dyno hub and lights
rear view mirror
bigger (40mm+) tire
CO2 pump
strobes
cpl tools
all new clothes
-Tim-
The OP should get:
underseat bag
spare tube
patch kit
two tire levers
reflective clothing
well-fitting helmet
a very secure lock.
10mm wrench
screwdriver
chain break tool
small saddle bag
frame pump
rear flasher
CST Salvo tires
leatherman
good fenders
selle italia slr
handlebars
a 5cm shorter stem
a nitto dirt drop
nitto north road
floor pump
good lights
dyno hub and lights
rear view mirror
bigger (40mm+) tire
CO2 pump
strobes
cpl tools
all new clothes
-Tim-
Bikes: Nashbar Road
Liked 341 Times
The OP should get:
underseat bag
spare tube
patch kit
two tire levers
reflective clothing
well-fitting helmet
a very secure lock.
10mm wrench
screwdriver
chain break tool
small saddle bag
frame pump
rear flasher
CST Salvo tires
leatherman
good fenders
selle italia slr
handlebars
a 5cm shorter stem
a nitto dirt drop
nitto north road
floor pump
good lights
dyno hub and lights
rear view mirror
bigger (40mm+) tire
CO2 pump
strobes
cpl tools
all new clothes
-Tim-
The OP should get:
underseat bag
spare tube
patch kit
two tire levers
reflective clothing
well-fitting helmet
a very secure lock.
10mm wrench
screwdriver
chain break tool
small saddle bag
frame pump
rear flasher
CST Salvo tires
leatherman
good fenders
selle italia slr
handlebars
a 5cm shorter stem
a nitto dirt drop
nitto north road
floor pump
good lights
dyno hub and lights
rear view mirror
bigger (40mm+) tire
CO2 pump
strobes
cpl tools
all new clothes
-Tim-
I want to add "bike computer" to your list because I have one on almost every bike. I must have had a reason for it at some time, though it escapes me now ...
" I would greatly appreciate any advice on what upgrades to make to the bike to preserve it and to prevent malfunctions and failures while on the road. Thanks" To answer this, the only upgrade needed right away is a set of tough tires to reduce chance of flats.
To preserve the bike, keep it clean and lubed. Overhaul the hubs yearly. Replace chain every 1000 miles, cassette as needed. If riding in the rain, cleanliness of the drive train is of utmost importance because the rain water carries a ton of grit with it and washes out the oil on the drive train, ultimately replacing it with gritty water. Clean it after every wet ride and save yourself lots of aggravation over time. Same goes with salty winter roads.
My son has a Dew Plus and had commuted on it from 2007 to 2018 when the frame broke. Moving to Seattle he quickly learned how damaging rain is to a bike. The thing has disc brakes and they needed to be replaced often due to wear.
Create a PMS schedule by the day. week, month, year and stick to it.
On the road repairs just follow the lists in previous posts for tools of choice.
Liked 2,469 Times
Funny that you should recommend tougher tires. My inclination is to replace original tires with lighter tires to make the ride more pleasant and to be sure that you're prepared to fix the inevitable flat.
I had two flats within a month of installing my Continental GP 4000S II 28mm last year. I then added Mr. Tuffy liner and was flatless the other 6 months with these tires. I'm about to reinstall them this year (I use Marathon Plus 35mm during Fall and Spring season), hopefully I haven't jinked it...
