Go Back  Bike Forums > Bike Forums > Winter Cycling
Shimano hydraulic disc brakes (BL-M396) leaking (I think) in very cold temps
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Old 03-08-19, 06:04 PM
robo
robo's Avatar
Bikes: 1990 Burley Bossa Nova, 1992 Paramount PDG-70, 1993 Specialized Stumpjumper, 2005 Jamis Dakar XC Pro, 2007 Rivendell Bleriot
Quoted: 20 Post(s)
My winter bike is a 2015 Scott Sub Speed 10, which has Shimano BL-M396 hydraulic discs.
I commute daily in Minneapolis, where we have cold winters, with commuting temps sometimes below -5F (-20C).
I've started to believe that that at very cold temps, somewhere below 0F, the Shimano brake system starts to leak. Maybe it's the seals shrinking or perhaps going hard, but in any case, after exceptionally cold days, I seem to end up with air in the brake lines, and squealing, juddering brakes (and oily looking calipers and rotors).
It took a couple seasons of commuting to figure out why my brakes were acting up like this, and I had replaced both the rotors and pads in earlier attempts to fix the problem, thinking they were at fault. But now I'm fairly certain it's due to fluid leaks.
Anyone else experienced this? Are other hydraulic systems better suited for cold temperatures, or should I be looking to replace this with a cable system?
Cheers,
robo
robo is offline
Old 03-08-19, 07:52 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 3978 Post(s)
Liked 453 Times in 288 Posts
Mineral oil apparently cannot freeze solid, but gets pretty thick below 0C, to the point where it "gels." This would certainly explain your brakes behavior below zero. Brakes using DOT fluid will not experience thickening or freezing, but have to be maintained more regularly due to the hygroscopic nature of DOT fluid.
DrIsotope is offline
Old 03-09-19, 08:45 AM
robo
robo's Avatar
Quoted: 20 Post(s)
but the problems Im seeing seem to be the opposite. The fluid doesnt gel, it leaks out. So I suspect the fluid is still liquid but the seals are being affected by the cold.
robo is offline
Old 03-09-19, 02:47 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6938 Post(s)
Liked 253 Times in 208 Posts
Leaking out from Where?
Sure the fittings did not loosen up?, snug them down a bit?
AFAIK , because my TRP Hy Rd brake has no hoses, master and 2 slave cylinders behind the pads,
are in the same part.. the diecast caliper, So no bleeding is to be anticipated ...
fietsbob is online now
Old 03-09-19, 04:27 PM
wolfchild
wolfchild's Avatar
Quoted: 1445 Post(s)
Liked 124 Times in 76 Posts
I also had the leaking problem with shimano brakes many years ago. Had them rebuilt with new seals and it kept on happening. I think it was the combination of cold and road salt that damaged the seals That's one of the reasons why I changed to BB7s. I just hated dealing with leaking fluid.
wolfchild is offline
Trellaine
Commuting
54
02-13-19 03:18 PM
TheReal Houdini
Bicycle Mechanics
7
11-28-18 02:39 PM
CanadianBiker32
Winter Cycling
10
05-23-17 05:07 AM
Maverick6652
Mountain Biking
9
03-26-14 10:38 AM
irclean
Bicycle Mechanics
8
12-21-10 07:17 PM
