Have you ever been on a hill so steep you couldn't unclip?
Liked 6 Times
I know, for some of you unclipping is not something you do. So, feel free to ignore. But in reading some of the recent posts about climbing, I remembered a time when the only reason I was able to finish a climb is that it was so steep that if I had tried to unclip, I'd have fallen over before I could get out. I had to keep the pedals moving. If memory serves me correctly the particular stretch I didn't think I could ride was about 21%. I learned that my will was less strong than my actual body on that ride. It was one of those growth points as a rider when you realize how mentally tough great riders have to be.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
It can be a real dilemma . Fearing that you haven't enough momentum to keep going. Yet, if you unclip you loose momentum.. Plan in advance of such a steep grade. If you think you are not up to it. - Don't do it. Or unclip in anticipation of such a steep grade. I usually plan ahead and if I think it's too steep I clip out of fear that I might not be up to it. Its rare I ride in such steep grades that I am not up to snuff. So, such experiences have been rare.
Pray for the Dead and Fight like Hell for the Living
^ Since January 1, 2012
Not sure I completely understand the question. If I unclip my pedals, I positively won't make it over a hill as I will not be able to pedal any longer because I am out of the pedals. I also can't even imagine a scenario where I wouldn't be able to unclip, you just do it and put your foot down. I've done this in a split second in an emergency.
Quoted: 1572 Post(s)
Liked 643 Times
Clipless pedals, once you get the knack, come loose pretty quickly. Mountain bike riders use them and, if you're doing real mountain biking, you're going to attempt some climbs that you can't complete. I took lots of falls back when I was mountain biking (if you're not bleeding you didn't try hard enough) but I can't remember one due to not being able to unclip. Most clipless pedal falls come from clipping out on one side and falling the other way.
Back in the olden days I used toe clip pedals with cleats on my shoes. That combination requires some planning to extricate your foot every time that you stop. I remember once climbing a hill that I didn't think I was going to make. I think that my adrenalin must have kicked in to give me the added boost that I needed.
Ninny
Quoted: 686 Post(s)
What the OP describes is a genuine risk in major hillclimbs. The risk is compounded because climbs that steep are often winding and narrow roads with sharp drops off the side. If you commit to the grade and fail physically, you may not have the energy to unclip fast enough to keep from falling either into the road or off the edge.
Essentially you either have to beat the climb, or fail with enough in reserve to get yourself into a safe standing position. That fine line can be very hard to find when you are at your maximum physical output. And the risk is actually higher for decent riders, because they are more willing to redline themselves.
I've seen good riders fall into the road on Platte Clove, a brutal climb into the Catskills, several times. (That hill is famous for reducing some pros to walking during one particular rainy race.)
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
I've had a few close calls trying to unclip on steep climbs. Scary.
Another problem I've had a time or two is my chain dropping off on the inside when shifting from the large to the small chainring when climbing long hills. Also scary.
Let's do a Century
Quoted: 651 Post(s)
Liked 879 Times
I can relate to what your referencing. There is a 21 per cent hill where I've seen riders unclip and fall over when they tried to put their foot down. Often their cleats would slip due to the steepness and they'd start going backwards. It is not a simple matter of unclipping and stopping. Restarting is another challenge in itself.
Ride your Ride!!
Ride your Ride!!
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
This has happened to me several times while climbing steep and rocky/rooty hills on a mountain bike. Sometimes the difference between success and failure on a climb can be a very fine line. Make it and you keep moving. Don't make it and fall. It is very hard to unclip while you are pushing as hard as you can on the pedal up to the point that you are no longer able to move it. I have made a few falls like this leading to tubling down the side slope or being pinned under the bike without room to move my foot enough to get unclipped. Very comical sometimes. Kind of painful others.
The only time I have come close to this on the road was on Brasstown Bald. I was straing so hard in my lowest gear that I was afraid I would break my chain or my gut! I managed to turn to the side enough to relieve the pressure enough to quickly unclip. To restart I had to start across the grade and quickly build enough speed to turn up the hill and struggle on.
Bikes: Trek 1.1
Quoted: 11 Post(s)
Liked 5 Times
So far this is the thing I fear most since I started using clipless pedals last Fall. Particularly on a group ride where I have not scouted out the terrain first. Applying the brakes while unclipping might hold you in position long enough to unclip and get a foot on the ground. Lately I have been practicing on a short steep grade near home to see how well I can climb. Actually even before using clipless pedals I once ran into difficulty after coming around a corner and suddenly faced with a steep climb before having shifted down. Have fallen over twice on fairly level ground when I first started using them but the results were just sort of humorous; a skinned knee in one instance but nothing serious. A hill, however, seems far more potentially dangerous.
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
The steepest I've ever climbed was 18 or 19%. I remember thinking, "I hope I don't come unclipped" as I pulled up on the back side of the stroke.
It never occurred to me that I'd want to unclip and stop, because I knew I wouldn't be able to start again. So I just continued up the hill.
Track stand. A big safety skill in that situation to gain time. One of the significant causes of broken bones on slick rock is stalling out on a too-steep climb and falling off the bike then tumbling down to the bottom. Slick rock has pheneminal traction when dry. There's a particular area in Moab that is hell on bones because of that. I stayed away from it.
It's recommended by the pros like Ned Overend to learn a good track stand to protect your self. One of my things to do, but never got too.
On Brasstown bald, going up on a motorcycle was scary. The wife and I leaned forward as we had the feeling we were going to flip over backwards. A few of my much younger friends have stalled out there. I saw some triples for the second Tour of Georgia for the stage that finished there.
Al
Al
Yes, working my way from Pie Corner to Boscobelle in Barbados. Climbing up a very steep gradient (unknown) on a narrow road and had resorted to traversing when an oncoming car forced me straight up the hill. Couldn't keep the front wheel on the ground and ended up on my back. Must have been funny to see.
Squeaky Wheel
I think this is the same hill. Gives you a better feel for how steep it is.
Steep Climb
Steepest road climb I have ever done was 24% - I made it up fine, but even if I would have had to unclip it would have been easy to put my foot down and stay upright.
Steep Climb
Time for a change.
Liked 5 Times
Spike Milligan
Spike Milligan
Ninny
Quoted: 686 Post(s)
Like I said above, it is more likely to happen to strong riders, because they are more likely to push themselves to the redline until they are completely spent.
Bikes: 1976 Apollo Mk IV, mid-'80s Miyata touring bike, mid-'80s Miyata mtn bike, 2007 Trek 6500 mtn bike, 2008 Trek Madone 5.2
Mountain biking. Five times in about two hours.
Dharma Dog
Bikes: Rodriguez Shiftless street fixie with S&S couplers, Kuwahara tandem, Trek carbon, Dolan track
I do most of my ridng in a fixed gear. I figure my limit in a 70-inch gear is an 18% grade. Unless you are racing in an actual hillclimb (where you are not allowed to get off the bike), I see no point in staying on the bike when you get to the point where you can walk up the hill faster. There is no shame in walking the bike up the hill; the pro's do it all the time in the Belgian classics when they lose momentum up the cobbled climbs.
I often wonder at the extra-low gears some riders use. Really, if you can walk faster (and easier), what's the point?
L.
L.
Sumerian Street Rider
Bikes: Dahon Mu P8, Fuji Absolute 1.0
Quoted: 29 Post(s)
Typing this reminds me of one more fun fact about the "hell hill" conclusion to that 80 miler. As I went into the climb on the last hill I had a brain fart and forgot to shift into the gear I needed to be in. I had the correct rear cog but forgot to shift out of the middle ring on the front. I did not realize my mistake until the grade was too steep to shift. Maybe I could have but I've never shifted while pedaling that hard before so I did not try since this was not the time to experiment with that. I just muscled my way up because I was confident I could unclip if I stalled.
Ken
Quoted: 514 Post(s)
Liked 449 Times
Regarding the original question, yes I have. So I kept pedaling.
Riding
Bikes: Motobecane Fantom Cross Pro; Motobecane Nemesis Pro
I think he's talking about coming unclipped and walking the rest of the hill... of course you can't keep pedaling once you come unclipped
