Thoughts of replicating a TriVelox 'A' type rear derailleur/hub hybrid
Old 12-30-14, 03:02 PM
crank_addict
crank_addict's Avatar
Quoted: 1153 Post(s)
Liked 123 Times in 83 Posts
I like the weird stuff.
I've been looking over the design of the short lived TriVelox 'A' hub (circa 1930's) and was zapped by the thought of replicating and making a frankenhub. I have a fixed Simplex chain tensioner that mounts to the chainstay, various junk cassette hubs, 3 speed IGH internal and cable pieces. The cassette hub would partially be machine slotted for slide actuated gear set. I would just use a single chainring and the chainline would remain constant. Whatcha' think? Crazy?
UK Patent 451,722 - TriVelox A1
crank_addict is online now
Old 12-30-14, 03:09 PM
frameteam2003
Bikes: old,older.and very old
Quoted: 31 Post(s)
Your looking at the "B" model trivelox. The "A" model has a claw that moves the block. I'm at present working on a 1935 sun tandem with a Trivelox(model A )
frameteam2003 is offline
Old 12-30-14, 03:15 PM
John E
feros ferio
John E's Avatar
Quoted: 731 Post(s)
Liked 57 Times in 52 Posts
Does Frank Berto know about trivelox? It's a new one on me -- thanks for the thread!
John E is offline
Old 12-30-14, 03:18 PM
frameteam2003
Quoted: 31 Post(s)
Old 12-30-14, 03:29 PM
crank_addict
You guys are amazing! I'm not fully aware of the differences between the models but did find this pic on Velobase.
My thought was to adapt a cassette hub in the TriVelox type with sliding cog. Maybe I'm incorrectly viewing it and it rather used separate gears.
Old 12-30-14, 03:42 PM
crank_addict
frameteam- That's a first I've seen. Very neat! Yours also has a moving derailleur (in addition to chain tension). I was thinking of having a fixed mount chain tensioner (pivot only) mounted to the chainstay by two bolts. An internal sliding dog would be in the hub center, attached to an external 3 speed type cable parts. A 3 or 4 speed cassette cog set would be joined as one but be able to loosely slide on the splined body. The splined body would be partially slotted, allowing an opening for the internal dog.
Old 12-30-14, 04:01 PM
Bicycle Addict
Bicycle Addict's Avatar
Bikes: Marin Bolinas ridge, Carlton Corsa 5, Falcon Olympic 12, 98 Shesh Rockhopper,
Quoted: 87 Post(s)
My boss in the 70's-80's ran the Sturmey Archer version of what you are looking at and said once sorted it was very reliable, used for commuting he stayed with it for about 8 years, no where near as cool as what you are looking at.
Bicycle Addict is offline
Old 12-30-14, 04:24 PM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1587 Post(s)
Liked 35 Times in 32 Posts
I think you're only partly right, there. The derailleur I have on my Fothergill is a Trivelox Model B, and it's a comparatively conventional design that moves the chain over a normal freewheel. But whatever. Clearly the engineers at Trivelox were capable of thinking outside the box!
When I bought mine, for song, on eBay, a listing with terrible photos, I expected the earlier version to come in the mail. So I thought about how to make the sliding cassette. I think I'd start with an 8 sp freehub body and stack of cassette cogs. grind the teeth off one cassette cog to put in the outer position, then use jbweld or something to assemble a set of cogs into a cassette. Grind them as necessary to make sure they slide smoothly. For the mechanism to move them sideways, I suspect parallelogram derailleur could be modified to interface with the toothless outer cog.
I put new leather on ruined saddles like Brooks, etc. You can reach me by private message.
rhm is offline
Old 12-30-14, 04:46 PM
repechage
Quoted: 1033 Post(s)
Liked 78 Times in 63 Posts
Reminds me of The Hopper Vampire Convincible with all this sliding going on.
Wix.com - Website built by thevintagebikelife based on Blank Website | hopper-vampire
repechage is offline
Old 12-30-14, 05:50 PM
frameteam2003
Quoted: 31 Post(s)
from what I've read on the Trivelox site there were 4 different versions. Mine being the first, then there was the chain pull type.(one with a pull on the right/the other on the left.And finally the last type as described by RHM ---which was a Cyclo type of derailer that moved the chain.
Old 12-30-14, 07:08 PM
rhm
multimodal commuter
rhm's Avatar
Here's a photo of mine, for the record.
Unlike a Cyclo Standard, Nivex, etc, which have two cables, this only has one; and unlike Simplex, Huret and Cyclo Benelux cable-pull derailleurs, this one uses its single cable to downshift; upshift is accomplished by a return spring. It's a remarkably simple, you could even say primitive, design; and it works quite nicely (at least for the narrow range I use it for)
rhm is offline
Old 12-30-14, 07:42 PM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 1402 Post(s)
Liked 143 Times in 100 Posts
SO 'derailleur' or tensioner doesn't move from side to side but that little blade looking thingie moves the cogs side to side.
Yeah I think I go with a Sach orbital hub
Bianchis '87 Sport SX, '90 Proto, '90 Campione del Fausto Giamondi Specialisma Italiano Mundo, '91 Boarala 'cross, '93 Project 3, '86 Volpe, '97 Ti Megatube, , '90 something Vento 603,
Others but still loved,; '80 RIGI, '80 Batavus Professional, '87 Cornelo, '09 Motobecane SOLD, '?? Jane Doe (still on the drawing board), '90ish Haro Escape
Bianchigirll is offline
Old 12-30-14, 08:18 PM
John E
feros ferio
John E's Avatar
Quoted: 731 Post(s)
Someone recently posted a mystery frame with a two-holed chainstay tab that looks as though it would support one of these derailleurs. When were they made and sold?
John E is offline
Old 12-30-14, 08:19 PM
John E
feros ferio
John E's Avatar
Quoted: 731 Post(s)
I see one cable through the hub, a second through the derailleur. What am I missing here? Please post a picture of the shift control end(s) of the transmission.
John E is offline
Old 12-30-14, 09:19 PM
rhm
multimodal commuter
rhm's Avatar
Oh, sorry, that photo was confusing. The cable going into the hub is the standard Sturmey Archer shift cable; it's an AW three speed hub. The only funky thing about the hub is that it has two cogs on it; hence the Trivelox derailleur. The standard Trivelox shifter is a top tube mounted quadrant similar to what Sturmey Archer used at the time. Kinda interesting, in that it indexes; like a modern indexed shifter, there is no attempt to make the derailleur index with the cogs, but rather the indexing is done at the shifter. But whatever its merits, I don't have the Trivelox shifter. I made my own out of scrap aluminum. Here's a photo that shows both the Sturmey Archer trigger on the handlebar and my home-made 'Trivelox' two speed shifter.
The frame that was discussed recently, that had this type of derailleur mount, is the black and gold Claud Butler. This type of derailleur mounting was common in the 30s and continued to the early 50's. I don't know when they stopped making derailleurs that mounted in this way. The Resilion derailleur, for example, was introduced in the 50's but I don't know how long they were made.
rhm is offline
Old 12-30-14, 09:31 PM
frameteam2003
Quoted: 31 Post(s)
Trivelox along side a sturmey archer
Old 12-30-14, 09:37 PM
frameteam2003
Quoted: 31 Post(s)
On the original style trivelox that keep the chain in line the cogs are on a three speed freewheel block that slides on the hub. It might be possible to use a French/Schwinn type cluster that has the splines and machine a splined shaft for it to slid on.
Old 12-30-14, 09:40 PM
frameteam2003
Quoted: 31 Post(s)
The early trivelox frames are easy to I.D. as the rear frame was spaced 130mm for this very wide set-up
Old 12-30-14, 09:47 PM
Steve Whitlatch
Steve Whitlatch's Avatar
Quoted: 530 Post(s)
Liked 15 Times in 10 Posts
I am clueless about this but fascinated!! This is real bike geek stuff.
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
Steve Whitlatch is offline
Old 12-31-14, 01:43 PM
crank_addict
Rudi- Is that another Fothergill or is this the same bike but swapped out the Resilion derailleur?
Also, how well does the gearset assembly slide? I noticed the later patent drawing shows a bearing block for easy slide action.
Old 12-31-14, 02:21 PM
crank_addict
Yet another TriVelox but haven't figured out what is sliding the cogset. It appears to just be a heavy duty fulcrum action tensioner. Perhaps there's a cable thru hollow axle not seen on the other side (in addition to a drum brake)??
File Type: jpg
Old 12-31-14, 10:36 PM
rhm
multimodal commuter
rhm's Avatar
Same bike. I used the Resilion derailleur for a couple years, and it served me well. Buying the Trivelox was almost an accident --didn't expect my lowball bid to win it-- but had to try the Trivelox because it's just so funky. Turns out I like it very well, mainly because it's a heck of a lot easier to remove the rear wheel with the Trivelox; something about the Resilion made wheel changes very difficult. That, and the Trivelox is just so funky
I don't know how those Trivelox gearset assemblies slide. I can't imagine they slide well, moved by an assymetrical mechanism under the weight of the chain, compounded by the tension applied by the derailleur. But I speculate.
rhm is offline
Old 01-01-15, 11:32 AM
frameteam2003
Quoted: 31 Post(s)
Yes this photo is of the trivelox with the hollow axel chain pull from the drum side, in the photo you can see the cable.
Old 01-01-15, 05:00 PM
rhm
multimodal commuter
rhm's Avatar
Yes, the pull must be from the other side, with a hollow axle. But
I don't see the cable. I see the long spring that pulls the jockey cage clockwise to keep the chain tensioned.
I need to get a spring like that for mine! I may try making one from a guitar string, but I may end up using a generic Home Depot tension spring again.
rhm is offline
Old 01-01-15, 06:48 PM
frameteam2003
Quoted: 31 Post(s)
I need to correct myself on the model names
my 1930 claw type is a model A
here are some more :
