Press Fit Bottom Bracket confusion
Hi All,
I am building a bike and after doing a lot of reading, i think i am more confused on bottom brackets.
Crankset:
Force CX1 PF30
Frame:
68mm wide
Bottom Bracket:
Are all PF30s compatible?
My confusion comes in when looking at the BB - some fit snugly to to frame like Chris King and others like race face stick out of the shell a bit.
Any way to make sure i get the right bb?
Since i have your attention what are your preference on BBs? any advantages to Ceramic bearings other than lighter wallet. This is for a Road / Gravel / Cross bike, so it will get dirty.
Extra bonus for Orange BBs
thanks!
Crankset:
Force CX1 PF30
Frame:
68mm wide
Bottom Bracket:
thanks!
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
Is your frame a press fit BB or threaded, it is not clear in your post. You said you have pf30 crank and your frames BB determines your course of action. Report back and we can go from there, might ask to post this to mechanics forum we deal there better than here.
Quoted: 6556 Post(s)
Liked 58 Times
Just go with a standard PF30 BB such as offered by SRAM and Loctite it in place. Stainless bearings if possible. You will save bundles of money and are likely to have no issues. Ceramic is for the gullible. They offer no advantages. Since the major issues with press fit BBs is the creaking, not bearing failure, spend your time on money on getting the installation with Loctite 609 correct. Ceramic bearings are the least of your needs.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
You have to go with a PF-30 standard BB if the frame is a PF-30 frame. There are threaded options for PF30 though that are kind of the bees knees, but more hassle or expense than they may be worth for you.
You don't need to loctite in a PF30 bb. Just drench the cups in a waterproof grease. Press and forget. Helluva lot easier to remove it when you need to and replace as needed because honestly they aren't that expensive anyway.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
I eat carbide.
Liked 1,306 Times
FWIW - I bore out every PF30 that comes into the shop. So many of them are made below min spec size and end up squeezing the bearings assemblies and causing a lot of drag. When I bore them correctly with the right tools to spec size they end up being pretty dead on and work great.
Ceramic in a BB isn't needed - to echo above.
Quoted: 399 Post(s)
Liked 185 Times
I will throw a different angle if it was myself I would get a shimano crank like a 105 and the go with a Praxis conversion. More expensive but very good eliminates the issues of press fits I think.
cycle-dog spot
Bikes: Look, Niner, Ellsworth, Norco, Litespeed
cycle-dog spot
Mainly just wanted to let others know that for sure the RF X-Type Shimano adapters are sweet and I have lots of use on mine.
Carry on!
I'm pretty sure the "Cinch" BBs only work with their "Cinch" cranksets. Might be wrong. Whatever, they're certainly not what the OP wants.
