Headset mysteries
Headset mysteries
Old 03-13-24, 06:25 AM
big chainring
Quoted: 752 Post(s)
Liked 730 Times in 353 Posts
Headset mysteries
I dont know much about headsets. I typically leave them alone. But I now have an issue on the new frame I bought recently.
Problem is the headset has movement, particularly the lower bearing. Even when its adjusted tight it still moves. So when riding and the brakes are applied I get a jerky stuttering effect. Its a Stronglight steel headset. I tried a different fork race and the movement was less but I think its the lower cup thats just too big. Or is it that I am using a caged bearing? Will loose bearings take up the slack?
big chainring is offline
Old 03-13-24, 06:55 AM
streetsurfer
Quoted: 96 Post(s)
Liked 292 Times in 155 Posts
Did you check that the cage is oriented correctly and not upside down in there?
Other than that, I will leave it to the pros.
good looking bike!
streetsurfer is offline
Old 03-13-24, 06:58 AM
juvela
juvela's Avatar
Quoted: 3814 Post(s)
Liked 3,345 Times in 2,182 Posts
its always good to begin at the root
suggest to face head tube & mill fork crown race seat
headset does not "look" like a Stronglight model P3 or V4
looks more like something from Etablissements Gourgaud (LIGHTRACE brand)
if the lockring is marked Stronglight it may be that the set was put together from pieces
one thing encountered occasionally is a cycle whose headset has been assembled from miscellaneous bits which do not always work well together
suspect source of looseness may be fit of lower head cup in head tube and/or fit of fork crown race - this is a fit which needs to be tighter than interference; it needs to be press
if one of these fittings in not tight enough shimming may be in order
if using retainers try changing to loose ball - these will give longer life in terms of brinelling resistance
juvela is offline
Old 03-13-24, 07:16 AM
smd4
Quoted: 3515 Post(s)
Liked 2,929 Times in 1,777 Posts
Buy a new headset. They're cheap.
smd4 is offline
Likes For smd4:
Old 03-13-24, 07:24 AM
nlerner
Quoted: 3811 Post(s)
Liked 6,717 Times in 2,614 Posts
^ This! Sounds like the existing headset is bodged together from disparate, not-quite-matching parts, including the crown race you swapped in. Start fresh.
nlerner is offline
Old 03-13-24, 07:34 AM
Trakhak
Trakhak's Avatar
Quoted: 2490 Post(s)
Liked 2,961 Times in 1,682 Posts
If the movement is only front to back and is confined to the bottom of the headset, that suggests that the head tube has become "ovalized," such that the bottom headset cup is no longer firmly held in place and is rocking forward and backward.
I had that happen on one bike, an early steel hybrid that I rode hard on rough single-track trails. A car mechanic I described the problem to recommended one of LocTite's tougher formulations. I used it - problem solved. Cheap fix. Might have been this one:
"LOCTITE 660 is a high-strength retaining compound with good gap-filling properties, ideal for repairing worn-out seats, keys, splines, bearings, or tapers without remachining."
Edit: as I recall, it takes some hours for the compound to harden. Might be best to keep the headset press in place for at least half a day or so.
Trakhak is offline
Old 03-13-24, 10:44 AM
big chainring
Quoted: 752 Post(s)
Interesting. This could very well be the case. I have adjusted over and over again and it feels as if its properly adjusted and then it works loose just by me rocking the bike back and forth with the front brake activated. I have used Loctite on bottom brackets where theeads were damaged. Worked well. I will investigate further.
Likes For big chainring:
Old 03-13-24, 11:10 AM
juvela
juvela's Avatar
tip -
the Gripfast seat binder you are using on the machine is Whitworth dimension
juvela is offline
Old 03-13-24, 11:29 AM
fleslider
fleslider's Avatar
Quoted: 477 Post(s)
Liked 179 Times in 91 Posts
How are the threads on the fork and the headset? had this issue with a Peugeot and the threads were trashed causing the headset to loosen..
fleslider is offline
Old 03-13-24, 12:04 PM
randyjawa
randyjawa's Avatar
Quoted: 1372 Post(s)
Liked 1,752 Times in 939 Posts
​​​​​​​Yup! been there and done that. I works.
randyjawa is offline
Old 03-13-24, 12:36 PM
Bianchi84
Bianchi84's Avatar
Quoted: 235 Post(s)
Liked 351 Times in 191 Posts
Are they caged bearings? If so, like someone above mentioned, it might be upside down. If loose bearings, maybe wrong number of them?
Bianchi84 is offline
Old 03-13-24, 03:32 PM
satbuilder
Bikes: A few
Quoted: 289 Post(s)
Liked 198 Times in 103 Posts
Can you confirm the lower cup is loose? The 660 probably won’t help if it’s snug in the head tube.
Could be the wrong sized bearings.
A replacement Stronglight headset for that vintage, if you care about keeping it original, won’t be cheap. You’re probably looking at $100 minimum, if you can find one with decent races.
Goid looking bike, by the way. I always liked the look of Libertas bikes.
satbuilder is offline
Old 03-13-24, 05:59 PM
big chainring
Quoted: 752 Post(s)
Originally Posted by juvela
tip -
Good catch. Only binder bolt I had handy.
Old 03-14-24, 09:25 AM
Velosophy
Bikes: Old Carlton frame and fork. Old Nishiki frame and fork, single speed build? 2003 Scattante full carbon/Ultegra. 90’s trek steel with full 600(purchased for the components) Also vintage K2 full suspension
Quoted: 22 Post(s)
Liked 32 Times in 20 Posts
I just want say sweet ride nice find! Of course it will bee all the sweeter with a headset fix, good luck with it! Let us know how it’s rectified
Velosophy is offline
Old 03-14-24, 09:40 AM
smd4
Since the OP suggests he got it as a "frame," then nothing is "original." He doesn't need a $200 NOS Stronglight headset. He should just spend $20 bucks and get a new headset, instead of trying to put 20 Band-Aids on it. Could have been purchased and installed by now.
smd4 is offline
Old 03-15-24, 04:57 PM
big chainring
Quoted: 752 Post(s)
Messed with the headset again. Went to the hardware store and matched up the bearing size to the one good caged bearings I had. I assembled the headset with the caged bearings on the bottom race and loose balls on the top race. It now functions properly. I just dont like headsets. Hope I never have to open up this can of worms again. And the bike rides oh so sweet.
Old 03-15-24, 05:27 PM
juvela
juvela's Avatar
great to read you got it sorted
juvela is offline
