Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Changing stem from 90mm to 50mm>
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 11-18-18, 12:31 AM
Cheeky DeVille
Cheeky DeVille's Avatar
Bikes: Raleigh Burner MKII
Quoted: 13 Post(s)
Will be getting back on a bike after many many moons, I will have to ride a while before i get comfortable again. I like the Trek FXII Disc. 15"/S frame.
https://www.trekbikes.com/in/en_IN/b...-disc/p/23350/
I'm 5'2"/55YO and can reach the handlebars but with no bend to my arms... I kinda anticipate neck and tennis elbow issues... The salesman (owner) suggested I try the 90mm for a while and then switch if i need it...
Would it be premature to switch to a 50mm stem at the onset and just be comfortable right off the bat?
Also my standover is about an inch or so... is that okay? Didn't feel too deterred by that though.
Cheeky DeVille is offline
Old 11-18-18, 09:08 AM
JonathanGennick
JonathanGennick's Avatar
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times in 37 Posts
Standover is fine. Don't worry about that.
Perfectly reasonable to put on a 50 mm stem, but I am of the school of thought that it's usually best to move handlebars upward and backward at the same time -- all things being equal. Thus, were it me, I'd throw on a riser bar at the same time, or maybe a high-rise stem, or even an adjustable stem.
JonathanGennick is offline
Old 11-18-18, 09:34 AM
Baboo
Bikes: Bike Friday NWT, Rans Stratus, Cannondale R500, trek 720 multitrack, Rockhopper
Quoted: 35 Post(s)
Liked 36 Times in 22 Posts
I agree on the up and back at same time. If it were me I would just put an adjustable stem on it until I can get it dialed in, then change the stem to one that matches that position. The reason I say this is that my experience with adjustable stems is that if you stand a lot they tend to creak.
Baboo is offline
Old 11-18-18, 11:37 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
I bought a used bike from a taller person, .. that's what I did..
fitted a 4 bolt face plate 5 cm stem, I had on hand..
Dealer is saying , essentially, 'try it as we got it' ,
the stem included to build up the bike, as supplied by the factory..
Up Angled short stems are a thing... as are stem raisers,
and replacing cables and housing if they, as set up in factory,
don't reach the new higher bar location....
fietsbob is offline
Old 11-18-18, 07:54 PM
Cheeky DeVille
Quoted: 13 Post(s)
Thanx guys. I have a better understanding of stems and raisers now. Cheers
TKJava
General Cycling Discussion
15
06-22-16 08:56 AM
kenshireen
Road Cycling
13
04-19-16 08:17 AM
matimeo
Commuting
12
09-17-11 02:45 PM
deepakvrao
Road Cycling
4
09-03-10 08:14 AM
echappist
Road Cycling
6
05-04-10 10:04 PM
