Tire circumference
Tire circumference 700 x 25
I can use some help with finding the right tire circumference to set in my Wahoo app.
My tire is a "Bontrager R1 700 x 25 / hard-case lite".
When I choose a "700 x 25c" in my Wahoo app, it sets a circumference of 2.105 millimeter.
However, when I measure the tire circumference manually, it is about 2.130 millimeter and according to the Wahoo app I have to choose "700c Tubular".
My question is: What is the difference between "700 x 25c" and "700c Tubular"? And what is the right size in millimeters to use?
I think tubular is a tire type that has an innertube sewn into the tire and glued to the rim.
The typical tire most people use is called a clincher. The R1 is a clincher.
Tubeless is the other type, sometimes called TLR.
Tires squish and their effective diameter shrinks, once weight is applied. If you're real picky on a bike that you actually ride on the road, you can get a helper and roll down the driveway for 3-4 revolutions and measure the total.
On a trainer, it's not that critical, since it's all make believe riding. These days, I just put in 2105mm for my 25mm tires and call it good. If you're training seriously, it's more about time and power, not miles.
Quoted: 20810 Post(s)
Liked 9,456 Times
I assume that you've got a wheel sensor on the bike, if you're asking about this? Why not just let the Wahoo auto-calibrate?
Likes For noodle soup:
So I thought setting it manually is a more acurate choice.
Liked 9,456 Times
Yeah - Automatic is the setting that you use. Are you recording rides using the phone app or a Wahoo head unit? If a head unit, saying that it's "guessing" is shortchanging things a bit - it's using GPS and historical ride data to calibrate and adjust. Phones have a better chance of being all over the place, though.
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
To measure tire circumference, first check your tire pressure. Then stretch a tape measure out on a suitably long bit of floor, street, or driveway. Put the valve stem at the end of the tape, a couple inches away from it. Sit on the bike. Roll forward, pushing with you feet. Check the measurement when the valve stem comes around again. To make that finer, ride a long known distance, a RWGPS route for instance. Modify your number by the percentage difference between the known distance and your reading.
Results matter
Results matter
Quoted: 6193 Post(s)
Liked 4,808 Times
With the disparity you are concerned about.... if I didn't move a decimal the wrong way, over the course of 100 miles (160.9 kilometres) you will be off by 29.4 feet (8.97 metres). Do you need more accuracy**********???
Measuring the wheel circumference off the bike will be a disparity from doing a roll out because the tire isn't that circumference when weight is it giving it a smaller diameter. Is the difference material? Probably not.
The only thing I might say about auto calibration is that it might be that one day the auto calibrate gets flaky. Maybe for GPS satellite interference with environmental factors. And it might be that it goes flaky when you are doing the best most important ride of your life. Murphy certainly must have a law about that!
I had it happen exactly once. A long long time ago. I'm pretty sure they have built in some additional code to look for such as I've not seen anyone complain about it like I was seeing ten years ago.
Quoted: 3948 Post(s)
Liked 7,292 Times
Likes For tomato coupe:
Liked 9,456 Times
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Or..? Have someone sit on your bike? Measure from your axle center to the ground (radius of wheel). C = 2 pi R.. or 6.28 x Radius (measured).
