Sram Crankset question
Old 08-04-20, 05:40 AM
Tandem Tom
Quoted: 455 Post(s)
Liked 112 Times in 85 Posts
Yesterday a friend was visiting and riding his Trek Domane? and experienced a dropped chain. It was stuck between the small ring and the BB. So I was going to remove the drive side crank and free it up. Took my 8mm hex and removed the retaining bolt but was met with a problem. It appears that a much larger crank puller is required.
can anyone she'd a bit of light on this?
Thanks!
Tandem Tom is offline
Old 08-04-20, 06:00 AM
andrewclaus
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times in 430 Posts
Not sure. Could it be a self-extracting crank with the retaining ring missing? That fooled me the first time I saw it, but as I recall the puller threads fit the hole.
andrewclaus is offline
Old 08-04-20, 06:12 AM
Dancing Skeleton
Dancing Skeleton's Avatar
Quoted: 74 Post(s)
Liked 57 Times in 34 Posts
Non-drive side crank comes off with a little wiggling, no puller needed.
Dancing Skeleton is offline
Old 08-04-20, 07:03 PM
scott967
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times in 54 Posts
I guess this is a GXP crank. There should be a retainer threaded in the NDS crank so when you unscrew the bolt it bears against the retainer and forces it off the spindle (self extracting). When the NDS is off use a rubber mallet or even just your hand or block of wood / hammer to push the spindle in far enough to loosen the stuck chain. If the retainer is missing don't know an easy way to use a thread-in puller. https://www.jensonusa.com/SramTruvat...k-Bolt-en.aspx
scott s.
scott967 is offline
Old 08-05-20, 05:27 AM
dsaul
Quoted: 714 Post(s)
Liked 800 Times in 475 Posts
A bit more information is necessary. SRAM GXP cranksets have the drive side arm permanently mounted to the spindle and there is no bolt on that side. If there is a bolt on the drive side, it is probably an ISIS crankset and requires a different crank puller than a square taper. https://www.amazon.com/PARK-TOOL-CCP.../dp/B07CB7Q4FK
dsaul is offline
