Road bike's chainring
Old 08-04-20, 01:19 PM
alij2018
Quoted: 51 Post(s)
Liked 3 Times in 3 Posts
Hi, why road bikes have big chainring like 50T? Isn't ot more tough to climb?
alij2018 is offline
Old 08-04-20, 01:22 PM
Litespud
Quoted: 645 Post(s)
Liked 797 Times in 446 Posts
Assuming that this is a serious question from someone who has posted 53 times: Generally you also have a small chainring for climbing. If you don't have that large chainring, you'll spin out at any decent road speed (and remember that road bikes are capable of higher speeds than MTBs because they're generally more efficient)
Litespud is offline
Old 08-04-20, 01:29 PM
Reflector Guy
Reflector Guy's Avatar
Bikes: Bianchi Infinito XE, Via Nirone 7, GT Aggressor Pro
Quoted: 599 Post(s)
Liked 1,271 Times in 588 Posts
I sometimes wish my big chainring was just a little bigger. Climbing hills isn't a priority where I live (and come to think of it, on my old 10-speed I used to have, the FD didn't even work and I went for years without even using the small gear).
Reflector Guy is offline
Old 08-04-20, 01:32 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
If you can climb a steep hill in a big chainring, higher gear, (Like Johan Museeuw ) you get to the top faster than your rivals , so you win.
fietsbob is offline
Old 08-04-20, 02:21 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 10425 Post(s)
Liked 11,899 Times in 6,094 Posts
That's what the other one is for. Little one going up, big one coming down.
genejockey is offline
Likes For genejockey:
Old 08-04-20, 02:33 PM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3674 Post(s)
Liked 5,432 Times in 2,759 Posts
53/11 FTW!! Doing things the easy way isn't for Real Men....
shelbyfv is offline
Old 08-04-20, 02:52 PM
genejockey
genejockey's Avatar
Then you have to spin down the other side in 39x23.
Old 08-04-20, 06:43 PM
BoraxKid
Quoted: 325 Post(s)
Liked 109 Times in 72 Posts
50t is not a big chainring, it's actually a compact chainring. A full-size chainring is at least 53t. Whether or not it's hard to climb depends on the rider, not the gear. HTFU.
BoraxKid is offline
Old 08-05-20, 10:50 AM
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 550 Post(s)
Liked 325 Times in 226 Posts
No. 50x34 yields a low gear like 42x29 which is sufficient for most mountains including those in the Colorado Rockies and European Alps.
Big cassettes let the pro peloton eschew small ring use, avoiding the potential for a stage losing chain drop as with Andy Schleck in the 2010 Tour de France 15th stage.
Drew Eckhardt is offline
Old 08-05-20, 06:24 PM
Cougrrcj
Cougrrcj's Avatar
Bikes: A few...
Quoted: 620 Post(s)
Liked 371 Times in 257 Posts
BITD 40+years ago, most entry- to mid-level road bikes had a 52/42t crankset up front and a 14-28t five-speed freewheel out back. Generally a wide-enough gearing for most of the country.
'Race bikes' would drop the rear gears down to 14-21 or less.
Triple cranksets appeared with smaller inner tooth counts for hill-climbing ability.
Then along came six speed freewheels that allowed for more gears in a person's preferred range for varying conditions from 13t up to 35t..
Then seven, eight, nine, ten-speed rear clusters with small rings of down to 11t.
Along with that latest rear cluster 'advancement' came the 'compact crankset' where the big rings got smaller, so the overall gear ratio stayed the same...
The goal is to get gear ratios in the range you need. Use this tool https://www.gear-calculator.com to figure effective gear ratios... Use this app to change the front chainrings or rear sprockets and play around!
Cougrrcj is offline
Old 08-05-20, 06:29 PM
GlennR
On Your Left
GlennR's Avatar
Quoted: 3004 Post(s)
Liked 2,433 Times in 1,187 Posts
50... how about 104tooth?
GlennR is offline
