Recommendations welcome for new wheel set
Old 04-01-20, 05:30 AM
marek12pol
hey everyone, I'm at beginner/intermediate rider at best. I have a 2013 Cannondale CAAD10 (2013) bike with fulcrum racing 5 lg wheel set. the wheels were damaged and i'm looking to buy a new wheel set and spend say $500 tops. any recommendations? 700cc. thoughts on the fulcrum racing 7s? any insight is appreciated. i'm a bigger guy. 210lb 6'3". thanks!
marek12pol is offline
Old 04-01-20, 06:04 AM
WhyFi
WhyFi's Avatar
Quoted: 20810 Post(s)
Damaged how? Accident? Pothole? General wear and tear under a big dude?
WhyFi is offline
Old 04-01-20, 06:08 AM
marek12pol
an accident, fundamentally. got rear wheel clipped by a car and then I feel and damaged front wheel slightly. the front real was 'never the same' and I blew a spoke climbing a hill while leaning on it a bit. and here we are.
Old 04-01-20, 06:09 AM
guadzilla
Pointy Helmet Tribe
guadzilla's Avatar
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times in 295 Posts
Handmade wheels from Psimet2001
guadzilla is offline
Likes For guadzilla:
Old 04-01-20, 06:18 AM
NumbersGuy
Bikes: Fairlight Strael 3.0 Ultegra Di2, Lauf Seigla Rigid SRAM Red XPLR
Quoted: 107 Post(s)
Liked 115 Times in 64 Posts
I'd recommend Shimano Ultegra wheels. They're extremely durable, tubeless ready if you want to go that route and not particularly heavy. They can be found for $350 or less and should give you many years of trouble free use. I'm similar size to you and have had them on my 2014 Boardman for over 20k miles of use without any trouble.
NumbersGuy is offline
Likes For NumbersGuy:
Old 04-01-20, 08:25 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
Couple options.. same rim from either
https://us.huntbikewheels.com/collec...wide#techspecs
or, from here, going with some form of 28/32 spoke count on the "Ventus" rims (24/28 if you want a bit lighter weight, probably would still suffice):
https://www.prowheelbuilder.com/pwb-...t-package.html
Sy Reene is offline
Old 04-01-20, 08:36 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
The PWB Signature Alloy Road, seconded. I run them 20/24 in rim brake and 24/24 on my disc bike, and I'm heavier than the OP.
DrIsotope is offline
Old 04-01-20, 10:06 AM
robertorolfo
robertorolfo's Avatar
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times in 113 Posts
Almost thought this thread was a fake.
Answer: Zondas, obviously...
robertorolfo is offline
Old 04-01-20, 10:10 AM
GnipGnop
just having fun
GnipGnop's Avatar
Bikes: 1994 TiCycles Softride, 199X Cyclops Stealth Softride, 1999 Rocky Mountain Soul, 1973 Colnago Super
Quoted: 41 Post(s)
Liked 56 Times in 29 Posts
Mid range campy, mid range mavic, mid range shimano
GnipGnop is offline
Old 04-01-20, 10:48 AM
rdeeui
Liked 9 Times in 5 Posts
I currently ride a shimano RS-11. They were cheap and decent, seems to be fairly durable as I'm around 200 - 210 lbs.
I was looking at these when upgrading wheels, but I ended up spending a little more for more aero. I don't have experience on them myself: Vision Trimax 45 carbon clincher. $441 at merlincycles.
rdeeui is offline
Likes For rdeeui:
Old 04-01-20, 11:02 AM
Russ Roth
Quoted: 1088 Post(s)
Liked 1,024 Times in 723 Posts
An LBS should be able to build you a decent set of wheels, Ultegra and Mavic, Velocity, or their preferred rim with butted spokes. Basic, reasonably light and durable. Shouldn't have to worry for a long time with them.
Russ Roth is offline
Likes For Russ Roth:
Old 04-01-20, 11:24 AM
RiceAWay
Quoted: 325 Post(s)
Liked 112 Times in 81 Posts
You realize you're going to get all sorts of stupid suggestions from people that weigh 150 lbs in their cycling gear don't you? Anyone that mentions Kyseriums shoot them.
Campy Scirrocos (also made by Fulkrum) or the aluminum Fulkrum line are fine.
You can pick these up cheap from ProBikeKit for cheap and they also have these 40 mm deep Chinese aluminum wheels (https://www.probikekit.com/bicycle-w.../12056926.html) that I bought a set of and am really impressed. These wheels are a tad lighter than my 55 mm deep carbon wheels so I will be converting everything over eventually.
It would be nice if they sold strictly clincher wheels since tubeless wheels are very difficult to mount tires on when you get a flat out in the middle of nowhere in the rain (been there, done that, sealant is nasty on your hands which then ends up on the bar tape) Tubeless tires CAN also get flats though that is less often. So you still have to carry a saddle pack with tubes, CO2 and levers. So what it the point of tubeless?
Carbon aero wheels are strong but a definite pain in the butt. They have VERY uneven spoke tension and most of the Chinese cheap wheels have those flat plate "aero" spokes. These do NOT read the spoke tension properly so they are all under-tensioned by a very large amount and those wheels are dangerous since they can take off in some other direction to where you're pointing. They do make cheap Chinese carbon wheels with round straight pull or regular aero spokes though and these are acceptable. You must use carbon fiber brake pads and Campy makes the very best carbon brake pads.
RiceAWay is offline
Likes For RiceAWay:
Old 04-01-20, 11:37 AM
tomato coupe
Quoted: 3952 Post(s)
Liked 7,297 Times in 2,947 Posts
Campy Scirocco. Fulcrum.
... those wheels are dangerous since they can take off in some other direction to where you're pointing.
I have a dog that does that ...
tomato coupe is offline
Likes For tomato coupe:
Old 04-01-20, 11:39 AM
tomato coupe
I was in the local 4x4 shop the other day, looking for new wheels for my Jeep. They recommended Zondas.
Old 04-01-20, 02:58 PM
robertorolfo
Quoted: 943 Post(s)
I'm digging your initial suggestion and disdain for tubeless, but I can't get onboard with the wheels you linked to. You really expect those hubs to last? And what's with these low-quality Asian producers throwing an Italian sounding name on products? Do people really fall for that?
Old 04-01-20, 03:19 PM
WhyFi
WhyFi's Avatar
Your schtick is already tired. No need to harass people for recommending something other than Campy - give it a rest.
WhyFi is offline
Old 04-01-20, 03:26 PM
robertorolfo
Quoted: 943 Post(s)
"Harass"? You call that harassment? Seriously?
For something similar to the amount of those no-name wheels he could have several options that, while perhaps not as aero, will probably serve him much better.
Old 04-01-20, 03:27 PM
WhyFi
WhyFi's Avatar
And you don't know a thing about the company that you're bashing. Wonderful.
WhyFi is offline
Old 04-01-20, 03:42 PM
Bah Humbug
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times in 2,026 Posts
You claim to not intend to have threads blow up, but you keep making inflammatory posts.
Bah Humbug is offline
robertorolfo
Quoted: 943 Post(s)
OK, and what does that have to do with some accusation of harassment?
But yeah, they are a Chinese company that picked a random Italian name to try and lend credibility to their products. I don't need to know them to call them out on it.
Old 04-01-20, 03:44 PM
robertorolfo
Quoted: 943 Post(s)
What is inflammatory? People are offering their opinions on wheel options, and I offered mine. I didn't say anything about anybody personally, I merely commented on a product that someone suggested. Isn't that the whole point?
Edit: To add to that, what's the problem with calling out cheap products as being possibly, wait for it, cheap? The guy started the thread by saying he had Fulcrum wheels that served him well for years. Recommending another Campagnolo/Fulcrum product is logical, as is the assumption that he might not be pleased with something of lesser quality.
Old 04-01-20, 03:52 PM
Bah Humbug
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
You have an extremely aggressive and dismissive tone. It was one thing when it was your thread, but the OP doesn't deserve this one going off the rails.
Also, if you want to talk about names, you might go digging up what languages all of Campy's names came from. Hint - it's not all Italian. How dare they? Who do they think they're fooling?
Likes For Bah Humbug:
Old 04-01-20, 10:08 PM
guadzilla
Pointy Helmet Tribe
guadzilla's Avatar
Quoted: 519 Post(s)
You know that many Italian companies put an Italian name on a Chinese-build bike to lend credibility to their product, right? You gonna call them out on that?
Back to the topic: OP, big guy. Seriously, get hand-built wheels with extra spokes.
Old 04-02-20, 01:54 AM
illdrag0n
illdrag0n's Avatar
Bikes: 2014 Focus Mares AX 2.0, 2019 Cube Litening C:62 Race Disc Teamline
Quoted: 121 Post(s)
Liked 140 Times in 68 Posts
DT Swiss P1800. Strong wheels, good hubs (DT 370 3 pawls). Poney up for the P1600 if it's in your budget (DT 350 ratchet hubs)
illdrag0n is offline
Old 04-02-20, 03:42 AM
Greatestalltime
Greatestalltime's Avatar
Bikes: Tcr advanced sl & Protos
Quoted: 116 Post(s)
Liked 60 Times in 33 Posts
At that price I second the Ultegra. They’re indestructible and no to low maintenance. Great wheels.
I bet the Scirroco? and other Campy wheels in that range are nice too. I’ve never tried them though.
Greatestalltime is offline
