Mitts = wind breakers for fingers/hands?
Bikes: Surly Disk Trucker, 2014 w/Brooks Flyer Special saddle, Tubus racks - Duo front/Logo Evo rear, 2019 Dahon Mariner D8, Both bikes share Ortlieb Packer Plus series panniers, Garmin Edge 1000
Quoted: 405 Post(s)
Liked 115 Times
I have done a couple rides this spring that I have been wishing I had some different gloves/mitts.
What I have now are some thinner cloth gloves that are actually pretty nice. They don't do a good job breaking wind, though. I have a pair of Hestra mitts (CZone's) that I like wearing when it is below freezing. They work great. However, they are overkill with warmer temps.
What I am after is a mitt that I can wear as a shell over top my cloth gloves or wear the mitt shell alone just as a wind breaker.
One of my riding buddies has a pair of gloves that have split off index fingers. That isn't what I'm looking for - I want all my fingers in the same pouch.
Any ideas?
Any ideas?
Bikes: Five active bikes: 1983 Diamondback RidgeRunner (early production mountain bike), 1951 Raleigh Sports 3spd, 2012 Novara Safari, 2013 Schwinn 411 IGH, 2016 Jamis Roughneck Fatbike; plus a Trek T900 tandem shared with the family
Quoted: 18 Post(s)
Temps vary as to rider's circulation and tolerance for cold. For myself, in 25-55 F. temps I like the Gore Windstopper gloves. They do, well--stop the wind. I like them so much I have two weights, a lighter set for the top of this range and slightly heavier, more insulated set for the lower part of this range. But even the heavier set is not that well insulated and for colder temps I go with some lobster gloves (thumb and index fingers like a glove, rest light a mitten) and then to full mittens.
I ride mostly urban, so I don't really always get all my body heat going like a more performance-oriented rider without stop lights would, but when I do ride with more sustained effort, the Gore gloves don't seem to get a clammy as some others I've tried.
You can also go two layers. A wool or poly glove under a thicker "shell" glove.
Quoted: 663 Post(s)
Liked 496 Times
I use several types of different gloves in combination. As temperatures get cooler, I use light liner cloves. As weather gets cooler yet, I carry a pair of shell gloves that are windproof and are comfortable over the liners. The shells are from an old pair of ski gloves whose insulation packed out and were no longer warm while skiing. I cut the insulation out and the plain shells fit in a jersey pocket. I will usually carry them even if not used. As temperatures get near the freezing point, I use a pair of fleece gloves in combination with the shells. This system, as it has evolved, is very versatile over a wide range of temperature and is inexpensive.
I have used the shells from a waterproof/goretex pair of ski mitts with removable liners that work well. They are a nice lightweight thing to have in case the weather turns.
Goretex glove shells work well. I also use wind proof fleece gloves. And some thin windproof xc ski gloves, All temp dependent.
I have some unlined lobster shells. I think they're Trek brand. Mittens are slightly warmer, but also a bit more hassle activating the brakes.
It gets really cold here, I prefer to use a pogie and then wear a light glove inside so you have good feel for the brake and shift levers.
Bikes: '85 Bridgestone 400
For seven years I would switch between some basic black leather gloves and my holy grail depending on how wet they got: Military Sniper Gloves. I got them off the Army surplus store. They have two pieces.
