when changing saddle...
So I'm upgrading my saddle finally...is there a way I can make sure I get the same position back for the slide adjustment? are the measurement marks universal?
Quoted: 6556 Post(s)
Liked 58 Times
No and no. I would compare the lengths of the two saddles. If they sre the same, put the nose of the new saddle just ehere the old saddle was. Then make corrections based on how you sit on it. You can measure your knee position relative to the pedal spindle and adjust the new saddle to give you the same. Or just by comfort. If the new saddle is longer or shorter than the old one, adjust the starting point of the nose by half the difference in front or behind the old saddle position. . Again follow up with fine tuning.
Good luck
Good luck
Brown Jersey Winner
Quoted: 243 Post(s)
Liked 13 Times
i generally measure the distance from the tops of my bars to the widest point on the saddle, seeing as thats where my ass likes to live but my saddles are all quite different in length/shape
was it you @rpenmanparker that detailed measuring your bikes with the back tire against the wall? that seemed like a good method
Bikes: Look 585
Quoted: 25 Post(s)
No and no. I would compare the lengths of the two saddles. If they sre the same, put the nose of the new saddle just ehere the old saddle was. Then make corrections based on how you sit on it. You can measure your knee position relative to the pedal spindle and adjust the new saddle to give you the same. Or just by comfort. If the new saddle is longer or shorter than the old one, adjust the starting point of the nose by half the difference in front or behind the old saddle position. . Again foll.ow up with fine tuning.
Good luck
Good luck
Farmer tan
Take a photo of the old setup from the side so you can approximate the tilt as well. Using a level is futile, since there aren't any flat areas on which to place one anyhow.
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times
Took me at least a 100 miles over a week to finally dial my fit back in when I got a new saddle this year.
