Wheel size 700c same as a 29er?
Are 700c road bike wheels the same size as the 29 inch mountain bike wheels? Are they interchangeable if running disc brakes?
Thanks
Thanks
Non omnino gravis
Bikes: 3 Speeds, DIY Recumbent Trike, Sun Tomahawk
Quoted: 10 Post(s)
Generally, usually, the hubs are 130 mm OLD on road, 135 mm on mountain. The rims are 622 mm bead seat diameter in both.
Bikes: Fitz randonneuse, Trek Superfly/AL, Tsunami SS, Bacchetta, HPV Speed Machine, Rans Screamer
Quoted: 100 Post(s)
The rims are interchangeable, but seldom the hubs. Different axle lengths, like 130mm road vs 135mm (old) MTB. Different axle types, thru axle vs skewer. Both road and mountain change "standards" so much these days, it is a complex question. You could probably swap tires, but wheels, well... don't count on it.
Bikes: Cannondale SuperSix EVO w Hi-Mod frame, Raleigh Tamland 1 and Giant Anthem X
Quoted: 352 Post(s)
Liked 8 Times
Can I put 700x38 gravel tires on my 29" mtb? Just swap the tires, not rims
You can certainly try ..
just realize there are minor variations of the BSD in rims & tires, so some combinations fit tighter/looser than others
Although I Wouldn't put a tire on a rim that is wider than the tire..
Non omnino gravis
Quoted: 352 Post(s)
Liked 8 Times
Thanks for the reply. I recently bought a cheap $125 Walmart 29" hardtail Mtb for training and thought of saving the mtb tires on replacing them w 700x38 gravel tires
Quoted: 21 Post(s)
Quoted: 90 Post(s)
Liked 18 Times
I'm guessing yes, but I clicked on this thread to find out info myself. I got a 29er mountain bike at the flea market this weekend and the tires say 29x2.00 (I think that's the width. didn't go out to make sure before I typed this), then in parenthesis it has 700x50.
Calamari Marionette Ph.D
The x 2.00 and x 50 mean the same thing as well. 2.00 inches wide is the same as 50mms wide.
Quoted: 352 Post(s)
Liked 8 Times
FYI, a few months ago I replaced the 20z2 knobby tires with 700x38 hybrid style road tires. Straight forward install and no issues after about 400 miles. I was amazed at how much faster the bike rides now
