I want a very nice threaded headset
I am rebuilding my fixed gear after ~20k mikes. This will include replacing the headset. This is my main ride and I want something nice, smooth and durable. I also want it to match the rest of my stuff, which is plain aluminum with small or no logos. The little seal on the top is a big plus to keep my sweat from corroding the steerer/stem. I learned (the hard way) that the Chris King grip-nut headset is not of threaded forks :-(. I believe I have an Italian threaded fork because: the bike is Italian and the current headset says Italy on it.
Three I am looking at:
- Velo Orange
- Campy Record
- Soma
Are there any I missed? Anyone have any good or bad experiences?
Ride Safe,
Joe
- Velo Orange
- Campy Record
- Soma
Ride Safe,
Joe
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
IRD Technoglide
https://www.retro-gression.com/colle...readed-headset
The IRD headset looks nice and meets the requirements. Thanks.
Chris king does not make threaded headsets.
Ride Safe,
Joe
Ride Safe,
Joe
Quoted: 399 Post(s)
Liked 274 Times
I didn't get what you said in your OP, and you compounded your error in post #4 ...
In fact Chris King makes two 1" threaded headsets - the GripNut that seau grateau linked, and also the 2Nut. I think the difference is that the 2Nut (which is what I have on my bike) has a bigger stack height.
I'm not trying to push Chris King headsets - there are many very nice 1" threaded headsets out there and even something cheap...errr...inexpensive ala Tange-Sekai is surprisingly good. But having said that...
I love my Chris King 2Nut 1" threaded headset - it has served me flawlessly for more years than I care to think about. Prior to my CK, I had a modern production threaded Campag Record Headset for a couple years. It worked fine and they are unexpectedly cheap...errr...inexpensive , I just wanted a change, and since I was over having to have a full-bore Eye-talian build...I figured you can't go wrong with something from Chris King and I've never regretted getting it...
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Plenty of nice threaded headsets out there. But first, how much stack height do we have to work with?
aire díthrub
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times
Wait a minute. Isn’t technically ‘italian’ the same as standard ISO in regards to headsets? Because I thought it was commonplace in Japan for what most might call ‘british’ to be called ‘italian’, or am I wrong? Like aren’t they all 30.2 with 26.4 crown races? And Japanese JIS is 30mm with 27mm crown race? I know some frames have 30.2 with 27 crown races, is that Italian or Taiwanese? I’m a bit confused on this now. Cause Chris King absolutely makes 1” threaded headsets, but I don’t think they make ‘Italian’ or JIS.
There is a large gap between the top nut and the stem. Not correct.
Old fart
Liked 3,400 Times
Source: Sutherland's 4th Edition
The difference is not enough to make them incompatible, and the mismatch is recognized as a "class B" fit. If your headset has aluminum threaded parts, the steel steer tube threads will re-form the aluminum threads to match. If both the headset and steer tube are steel, there will be some re-forming of the threads on both parts. This is seldom an issue in use, as long as you don't make a habit of swapping out headsets.
Commuting and Pleasure
If somebody wants to dive deeper into the different threads, there is a very comprehensive overview, guess by whom? Of course, Sheldon Brown:
Sheldon Brown's Bike Glossary
Scroll down a bit for the headsets.
/Björn
/Björn
And check the height of your actual headset. There are noticeable differences in the height, assuming that you want to reuse your fork and it is cut to the height of you actual headset this limits the range of choices. I replaced my Tange once with a Campagnolo and ran almost "out of thread" at the top. Removing one washer helped, but gives a bad feeling thinking about it too much.
And Campagnolo makes really nice treaded headsets, specially the vintage ones....
Here some sample from my bike:
/Björn
/Björn
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
They're very close, but not identical. The difference is in the thread angle; Italian threads are cut at a 55° angle, while ISO and English use a 60° angle:
Old fart
Liked 3,400 Times
Old fart
Liked 3,400 Times
Quoted: 18376 Post(s)
Liked 4,511 Times
Stronglight makes a sealed bearing headset.
I'd prefer my bearing cups to be fully covered from the top side.
Best threaded headset ever? Shimano cartridge-bearing units from the 90s. Such as XT, LX, 600, Dura-Ace. Actually the 600 units were the best, in that they shared all of the same parts as Dura-Ace, except steel instead of the easily-damaged alloy crown race featured with Dura-Ace.
Before you commit to a headset, research what actually kills headsets. It is false brinelling. For every one headset killed by corrosion, I see 5 killed by false brinelling. Road headsets are alost exclusively killed this way.
It seems that Shimano was the only headset maker that figured out the solution to this problem. They can still be found on Fleabay. Just make sure you don't get one of the orphaned and useless JIS models.
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
Old fart
Liked 3,400 Times
I did an experiment with a Stronglight A9. In 1988 I built up a commuter bike using a Stronglight A9 headset. I rode it for 20 years in all kinds of conditions, and did zero maintenance on it. In 2008 I opened it up to see how it had fared. This is what I found on the races after cleaning:
Very slight discoloration on the lower races; nothing untoward on the upper. I swapped upper and lower races and re-assembled. I'll check again in 2028, but since I retired in 2016, I no longer have to commute in inclement weather.
Bikes: Tommasini, Caad 7 , Seven, Pinarello
Quoted: 65 Post(s)
Liked 15 Times
