Front wheel bent
Bikes: Giant Contend SL 1 Disc
Quoted: 155 Post(s)
Liked 78 Times
Front wheel bent
With bike on stand, i spin front tire as fast as i can and i can see a very clear gap for a whole revolution at my disc breaks. However, if i shift my vision to the side wall of tire i see about 1/4 inch deflection off the right side of tire. When i stop the wheel at this spot i can see no signs of obvious damage. Nor can i see anything out of wack on the spokes. All the spokes are tight.
Bike is new 2018 Giant Contend SL Disc, with about 500 miles total. The tires only have about 100 miles on them as i recently when wider to 28s from the stock 25s (same tire maker).
Is that 1/4 inch an issue?
thanks for any info yall can provide,
JAG
JAG
Uber Goober
Is the deflection in JUST the tire? Or the rim also? Or the brake disk?
If it's JUST the tire and the rim is true, let the air out of the tire, see if it can be shifted around to seat better, or if maybe the tube is under the rim somewhere.
If it's tire and the rim, rim needs to be re-trued, or, if too messed up, replaced.
If the brake disk is out-of-true, it may be possible to gently bend it back, or may be easier to replace. A bent brake disk and out-of-true wheel are generally issues unrelated to each other.
Quoted: 155 Post(s)
Liked 78 Times
JAG
Quoted: 1851 Post(s)
Liked 678 Times
It could be the wheel is slightly out of true, but if it's not rubbing anything, it's not really an issue.
And sometimes, labels on tires can give the impression that the tire is wider at points even if it isn't.
Quoted: 155 Post(s)
Liked 78 Times
JAG
Should Be More Popular
Quoted: 22587 Post(s)
Liked 8,924 Times
Make sure.tube isn't twisted inside tire. Is it near valve stem?
bike whisperer
Quoted: 1527 Post(s)
Liked 718 Times
So shouldn't the thread title have been, front tyre not mounted properly?
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Quoted: 663 Post(s)
Liked 496 Times
You can check if the rim is true yourself by holding a felt tipped pen steady against the fork and them spinning the wheel. The pen should leave a near solid line of ink around the rim or be heavily marked in just one or two high places. If actually truing the rim, you can get to within 1/2 mm with this backwoods method.
