Most durable Cog
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2632 Post(s)
Liked 3,147 Times
Most durable Cog
Hello all.
I have a fg that I use to commute on sometimes and that I do a fair bit of winter base miles on, esp. in ****ty weather.
I stripped the rear hub, so I am going to JB weld a cog on there instead of just toss the wheel out. Because this will be the last cog that ever goes on the wheel, I want it to be very durable (hardened steel FOSHO).
Do any of you w tons of FG miles have recommendations for very durable and hard rear cogs? This bike will be used primarily for 1-3 hr rides (nothing longer) and short trips around town/to campus when im wearing regular street clothes.
BTW if any of you have exp w JB welding please chime in.
THX
THX
Beausage is Beautiful
Bikes: Nabiis Alchemy
Quoted: 20 Post(s)
Liked 13 Times
Buy a cheap cog and replace the wheel as soon as you can.
Long rides aren't your worry. Skidding and anything that induces large stress loads to the bond are your worry.
Do it for the time being if you have to, but no more than what is necessary.
Be safe.
Be safe.
artesc all the way.
Bikes: 2008 Redline 925 (bleh!)
yeah, don't use a stripped hub.
that being said...dura ace is fairly cheap and very durable.
Bikes: Bianchi San Jose, fixed
Buy a new wheel.
Surly cog's have a beefy tooth profile, cant comment on how long it will last yet.
My Dura Ace cog wasn't as beefy but it was super smooth, however I thought it wore out bit soon (~3.5 months of life)
Then again I was regularly riding an average of 60 miles a day 5 days out of the week on it.
If your only doing 1-3 mile trips you will obviously see longer life in your cogs.
Not actually Tmonk
Liked 3,147 Times
That was a 1-3 hr trips not miles.
I should just buckle down and buy a new wheel, and I will as soon as this one gives but I gotta make it last for all its worth cuz im broke.
Is a JB weld a really short-term solution? Like under 3 months? If that's the case I wont even bother.
But im concerned about a durable cog regardless of new hub or JB weld job. Dura ace is the fav. vote so far.
artesc all the way.
jb weld is a very short term solution...as in get a new wheel as soon as possible. I mean, you can find a rear wheel for like 50-60 bucks.
Jb weld has the potential to work for a while, but do not trust it at all. ride with brakes, no skidding, no skipping, etc. plus, jb weld hasn't worked too well for me between aluminum and steel.
FNG
Bikes: Raleigh Special * Nishiki MTN Winter Commuter * Trek Soho 3 * Specialized Langster Seattle
thread derailleur
Bikes: 82 Bianchi ECO Pista, Pake, Kilo TT, some *** bmx i found underneath an old house
EAI. If you want higher tooth counts, like above 17, DuraAce doesn't have them.
Likes For erichsia:
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
more teeth = longer lasting, but more torque generated and more torque means its easier to rip it off again.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Bicycle Repair Man !!!
Surly cogs seem to last a good long time... my longest serving cogs are the antique 1/8 track cogs I have collected over the years as they never seem to wear.
Likes For 1fluffhead:
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
Think I have 4 MN winters of cranking up hills on my Surly cog... seems to be holding up very, very well considering it has lasted longer than everything else on the bike.
Quoted: 20 Post(s)
Liked 13 Times
Any cog that's not made of balsa wood is going to out-last this guy's application. He needs a new wheel. Period.
Bikes: Panasonic NJS Keirin x2, Level Professional, Bianchi CUSS, GT Pulse
Take your wheel to a machine shop and have them spot weld the cog on, yeeeaaaaa
Are the lockring threads stripped? If its just the cog threads that are stripped, you can JB weld a Miche carrier and you will still be able to replace cogs.
Bikes: All City Nature Boy, All City Macho Man
Not actually Tmonk
Liked 3,147 Times
I just realized that I will be able to afford a new wheel early next year, mid Jan-ish depending on when paycheck comes in.
Having said that I will JB weld the cheapest cog I can find on there and buy a new wheel next year.
Thanks for all the replies.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Old fart
Liked 3,400 Times
Bikes: 2008 Bianchi Pista
i have tried this before, same situation where i was broke as a joke and tried to jb weld my lockring on. didnt end well at all. i lost the lockring going down a hill and started freewheeling downhill. luckily, i was able to ditch into a yard instead of an intersection. so, from my experience, not worth it. try and make a new wheel/hub happen if you can
I just wanna ride
Bikes: 2013 BMC Impec
yes, the best solution is to just take it to any machine shop and have them weld it into place real quick. It will stay on forever at that point and you won't need a new wheels until you want to change cogs. And most shops should do it for free in 3 minutes
Has there been a new breakthrough in metallurgy? Last time I checked, steel and aluminum are kinda hard to weld together
However, you could crank the cog on as tight as possible, then have a couple small holes drilled through the cog and hub where they meet and then have pins inserted with an interference fit... but this would cost at least as much as a new hub.
