Completely conflicted
we be rollin'
This may be a useless post but wondering if anyone has any input. I already have several bicycles but not completely satisfied because of the stupid pot holes in this city (no joke).
I'm trying to decide between the following:
Norco Indie 2 27.5x2" tires, 46/30 crankset, Shimano SL-M315 shifters
Brodie Tesla 27.5x2.2" tires, 46/30 crankset, Shimano SL-M315 shifters
Breezer Midtown 1.5 27.5x2.4" tires, 48/38/28 crankset, Shimano Altus shifters (likely same as above)
They all look pretty sweet but the Midtown Breezer 1.5 has a 470mm chainstay and 48/38/28 crankset which means I'd have to deal with a triple front derailleur. One plus for the Norco Indie 2 is Planet Bike sells a 27.5 fender which takes 1.9" tires which means they'll likely accommodate 2" tires. For the Breezer Midtown 1.5, there are SKS Bluemels 75U fenders although those look a bit wide. For the Brodie Tesla, I'm not sure which fender might be more compatible.
By the way, I know I made a poll for 3" tires. But I saw a Del Sol electric bike with 2.5" tires and they looked adequate to me. Although I still don't understand why they don't make direct-mount brakes for larger tires.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 763 Times
I think the short answer is there's no market for it. The tested and proven linear pull brake (often called "V brake") works well, is inexpensive, and uses long-pull brake levers, just like mechanical discs. I suspect (though don't know for sure) direct-mount brakes might use short-pull brake levers, which are not common for flat bar bikes anymore, and it'd be another part combination the factory would have to stock.
Quoted: 576 Post(s)
Liked 1,004 Times
Joe Breeze does make nice bikes that ride great though, aside from cliche reviews this is one brand that has a reputation for nice riding bikes and optimizing frames.
There is nothing wrong with triples and 3x8 is proven, but 30x46 is a more modern setup that I frankly really like. I don't know if 8 in the back is enough for that double to shine though. For road buzz, I find Ti or crabon bars to help considerably
Vees do a better job without the drawbacks.
"not completely satisfied because of the stupid pot holes in this city.
I don't see suspension forks on any of those bikes. You're situation is exactly what they are made for. My ride also consists of some bad roads and mup's. My next bike, Likely this Giant Roam 2 Disc has 42mm tires and suspension forks.
https://www.giant-bicycles.com/ca/roam-2-disc
If Giant bikes aren't available, I'd get something similar from another reputable manufacturer.
we be rollin'
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 406 Times
I bought a 2019 Norco Indie3 from a pawn shop cheap. It was listed as "used" but other than puddle splashes it was like new.
I wasn't thrilled about the colour (slate blue) but it has really grown on me.
The Indie3 has a steel fork so will probably take bumps a little different than the Indie2. However, if you adjust with the tire pressure on the 700c45c tires you can dial in a nice compromise between comfort and speed.
It looks like the 2020 models have a different frame confg(?) and the 3 is gone from the line up.
I'm not familiar with the other bikes in your list but I'm very happy with the Norco...
Do you want to know the peculiar reason some bikes were taken off my list? Look at the way the fork is made on the Giant Escape. If I can't install an Atran Granny front rack on it, I may forget about it. There needs to be a hole somewhere close to the axle of the front wheel.
we be rollin'
I just calculated something on a gear calculator. If I choose either the Norco Indie 2 or Brodie Tesla and I want to save my energy for my workouts, I could use only the 4 easiest gears (on the cassette) while on the smallest chainring (30T on the crankset). Then, if I want to gradually go faster, I can switch to the large chainring (46T) on the cranket once I'm in the 4rth gear (like go from 40 gear inches to 60 gear inches once you switch to the large chainring at the front). (This is to avoid cross-chaining of course. It also makes it look like a triple crankset is useless anyway...)
Liked 763 Times
Alternatively, a 36-tooth ring on a triple will take you all the way from about 30 gear inches to 90 gear inches, with no changes on the front required. At a cadence of 60-80 rpm, that's a road speed range of about 5 mph to 20 mph. That's going to cover most of what you'll likely be riding as a hybrid rider. Again, without any shifting on the front required.
we be rollin'
Even though I'm almost desperate to try one of those 650b bikes, I think I might buy a Specialized Sirrus 1.0 and install a 46/30 crankset (with chainrguard) and SL-M315 shifters on it. That's partly because I already have a 700c wheelset I haven't built up yet and I still like V-brakes. Also, I suspect the Specialized Sirrus 1.0 may be one of the only bikes that can take the Atran Granny front rack.
Actually, when it comes to shifting, most of the time in the winter I would be on a 30T chainring anyway (because of snow resistance). Then if I do a shift from 40 to 60 gear inches, I could always shift back one gear to be at 53 gear inches (hypothetical situation on a Norco Indie 2 once I'm on the 46T chainring).
we be rollin'
I just realized I could buy one of those bike and simply have the frame converted to accept V-brakes or even use large caliper brakes. I don't know which of the Tektro models it would take but might be either the Tektro R559 (53-73mm), Tektro 810C (61-81mm) or Tektro 900A (72-92mm).
Quoted: 576 Post(s)
Liked 1,004 Times
we be rollin'
lol, I know the answer is not obvious. People recommend hydraulic disc brakes, however I read they can freeze at -15°C (5°F). And mechanical disc brakes apparently aren't as good as V-brakes anyway. Since I want to go down from 4 bikes to 2, I would likely use that bike in the winter as well. I wouldn't use my touring bike in the winter though.
Quoted: 576 Post(s)
Liked 1,004 Times
At least you can mount a cable disc system on those bikes. How do you want to mount V brakes? Do the wheels even have brake tracks?
Liked 763 Times
we be rollin'
In terms of braking power in dry weather, they are about on par; but discs are more consistent in all conditions, regardless of actuation method.
I may have found a partial solution, the Giant ATX 3 (V-brake version). Sure, it's a Tourney bike but I mean it has the mounting holes for backrack and fenders. And I just have to get one of those front racks that connects on the front hub to get 4 bags on the bike. I'm sure there's space for fenders with the 2.1" tires on there but not sure if it will take Kenda Kwick Seven.5 2.2" tires AND fenders at the same time (maybe because the Seven.5 are slick tires). It's a 27.5" bike so the circumference should work better for pot holes anyway (than 26" wheels).
The practical problem is real though. I went grocery shopping yesterday with 4 bags on my bike and even food in my backpack. What was it like? I had to slow down to a snail's pace in some places. I mean some parts of this city looked like it was bombed in the second World War and never recovered. It's not just pot holes, it's places where the asphalt is very undulated marked with pot holes and even rocks about. It's an absolute travesty. lol There's an area that's supposed to be replaced by a new bridge but because of FREAKIN' CORONA it hasn't happened yet.
By the way, I did find some other models with 27.5" wheels and V-brakes: GT Palomar, Diadora Novara & Orbita (at Sports Experts), CCM FS Sector (although that one is only a buy at $300 Canadian at Canadian Tire).
Of course if I did buy a Giant ATX 3 V-brake version, I'd probably want to modify it. I'd replace the shifter/brake levers with separate brake levers and Rapidfire shifters, put on an Allen key type seatpost clamp, change the crankset to 46/30T crankset etc. I'd prefer rigid forks but understand the rigid fork version of this bike (although a disc version) was discontinued. I'd admit though this is a bike I could run stock for a while until I want to spend money on it.
Liked 763 Times
There are definitely pros and cons to both types of brakes, but continual adjustment like you describe is not an attribute of even mechanical disc brakes, at least in my experience.
Quoted: 238 Post(s)
Liked 406 Times
Quote:
Originally Posted by hybridbkrdr View Post
I've read some people ride with tools in their pockets so they can adjust on the road because that's how often you have to adjust some mechanical disc brakes.
Re mechanical discs....I was wondering the same (when I was shopping) but now that I've put on some miles on my Indie I have only had to make an adjustment (once) after removing the front wheel for transport. All that was required was re-loosing the front wheel and re-seating it so the rotor was true between the pads.
That said......I do carry tools in my backpack just in case.
we be rollin'
Anyway, this thread is a bit weird in the sense that I went from considering hybrids to mountain bikes and now to cruisers. Because of a bit of chondromalacia in my knees, the laid back style of a cruiser might annoy my knees. But, I think if I buy a seatpost with a pronounced setback and install it back to front then push the saddle forward as far as I can, that might do. Then I could change to 30mm riser bars on the Specialized Roll and be done with it. The Specialized Roll has 27.5x2.3" tires, rigid forks and V-brakes. The kind of bike that I could probably tour with without having problems with complicated disc brakes nor suspension forks. All I'd need are front and back racks and fenders. Plus I could change the crankset to a 46/30T and add a front derailleur and front 2x shifter. And install a 142mm saddle. One person on Youtube measured the tire on a Roll and it was nearly 62mm. I mean if I had any questions that V-brakes could work with 2.4" tires, then I have my answer.
There are also others in the same category such as the Jamis Hudson & Explorera 2 and Marin Stinson. Actually, in the Cyclingabout channel on Youtube, one person said V-brakes are simpler to maintain on the road.
Liked 763 Times
The Roll is probably your best bet for a good Out Of The Box experience. The only potential issue is the laid-back seat post, which will put your feet further forward on the crank compared with many other choices, but you've already acknowledged potential ways to address that. V-brakes will definitely work with wide tires like this, and will be a much better choice than caliper brakes if you prefer rim brakes. It looks like the Rolls with rim brakes come with a 1x crank, but with frame cut-outs for the internal cabling. You may have some fiddling to do to get the cabling in place for a front derailleur, but it's definitely possible.
As a disappointing aside, it looks like Specialized really simplified their Roll portfolio as of late, and have taken out the nicer models. It appears the best model you can buy is a $635 Roll Sport with mechanical disc brakes and a 3x7 drivetrain. The main page for the Roll shows some of the nicer ones apparently on clearance...presumably because they've been discontinued.
Quoted: 238 Post(s)
Liked 406 Times
The only "mod" I did to the handlebars was trimming off about 1" from each end. I also played with the height of the bars by adding/removing the stem rings.
Likes For Speedway2:
