Cable conundrum!!
Quoted: 4199 Post(s)
Liked 3,851 Times
Since front der shifting is less cable dependent then rear shifting splurging for high end cable/casing will have a less a noticeable effect then well routed and installed "good" cables have. But it's your $. Of course to some peace of mind is priceless Andy
AndrewRStewart
AndrewRStewart
Non omnino gravis
Shimano Optislick Road Bicycle Shift Cable Set
Nearly as good as what you get with the DuraAce, and oh, so so much cheaper. The coated cables are very good.
Quoted: 18371 Post(s)
Liked 4,507 Times
How much bike mechanic work are you doing?
I frequently order cables 10 or 25 packs, stainless from E-Bay China, $1 to $2 each. They can take a few weeks to arrive.
If you just need this cable now, just go down to your local bike shop and ask for a good stainless Shimano Compatible shift cable.
Do you also need cable housing?
Shimano also sells cables/housing. Or Jagwire.
Quoted: 2026 Post(s)
Liked 1,096 Times
Liked 3,851 Times
Also remember that cable coating usually won't hold up to the contact with casing end caps or cable stops (just where friction can be great) Andy (who runs uncoated SS cables on all his bikes).
AndrewRStewart
AndrewRStewart
A nice shiny new die drawn SS cable and new housing will get you fixed up. Go to your LBS, shoot the breeze, buy the cable and a few feet of housing, they more than likely will toss in housing and cable ends.
