Tap Handle?
Quoted: 455 Post(s)
Liked 112 Times
Tap Handle?
When the need arises to chase threads in areas where a normal handle won't work what do you use? Chainstay bridge when there is a threaded boss comes to mind.
Thanks!
Thanks!
Quoted: 800 Post(s)
Liked 2,961 Times
Longnose vicegrip.
A 6 inch adjustable wrench, or if it fits in a small socket or open end wrench.
Just be careful you push it sideways and break it.
Quoted: 4195 Post(s)
Liked 3,837 Times
There are tap extender, much like a drill bit extender. I have a couple. The other neat tap handle tool is a ratcheted handle, which I also use. Andy
https://www.mscdirect.com/product/de...04049?fromRR=Y
https://www.mscdirect.com/product/details/05041611
AndrewRStewart
AndrewRStewart
Quoted: 455 Post(s)
Liked 112 Times
The tap socket sounds good. Yes, I know the slip handle movers back and forth unfortunately it is still in the way.
SE Wis
Quoted: 2740 Post(s)
Liked 3,386 Times
I find a 12 (or 8) point socket that fits the tap square end "good enough" and use a ratchet.
Quoted: 1572 Post(s)
Liked 643 Times
That's my weapon of choice too.
"First, do no harm." I'm REAL careful to be sure the tap is straight. If I can, I run the tap in from the opposite direction to be sure that I have it engaged in good threads.
