RWGPS and calories vs Wahoo Bolt w power meter
I've done a few rides this week and was paying attention to the calories on my Wahoo and in general as I try to lose the 10 pounds I put back on after I lost 30. I attribute the original weight loss entirely to cycling, and I have RWGPS stats during that time but before I had a PM. I did about 2 hours of riding on Monday, and the Bolt said I burned 1476 calories during that ride but when it uploaded to RWGPS it showed only half that. RWGPS uses HR data to estimate calories, but the Bolt is using actual power data. I've always used 500cal/hr as a rough estimate myself for my moderate to hard cycling. One is below the other is above.
I'm fully connected with both power and HR, so which should I believe?
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
I don't have a power meter but I do notice that I, more often than none, get varying results in calories burned across different sites. I upload to Strava, RWGPS and Endomondo and usually get three different results for the same ride. I always go with what my Bolt and Tickr record.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
It's still an estimate, but it's an estimate based on the actual amount of power generated. Efficiency loss differences between calories burned and calories generated are pretty minimal and also pretty standard across a wide range of fitness levels, so the PM is going about as close as you can get outside of a lab.
And here's what make it even more puzzling to me now. I rode my commuter bike today and took the Bolt with me as I usually do, wore an HR monitor, but didn't have the PM pedals. This time RWGPS completely overestimated my calories IMO, reporting about 1500 calories for what I consider an easy ride. On the ride I did with the power meter a few weeks ago at the start of the thread I was pedaling hard and getting a real workout, and RWGPS reported half the calories for the same bike time. Yea, it all nets out, but that's not my point. Why is it so inconsistent?
Non omnino gravis
Quoted: 18883 Post(s)
Liked 10,646 Times
Likes For Seattle Forrest:
Non omnino gravis
Quoted: 2952 Post(s)
Liked 3,106 Times
Power meter.
I was shocked when I was looking at the calorie burned numbers from 3 different bike computers a few years ago. They varied by almost 100% method to method/computer to computer. If you want reasonably accurate caloric burn numbers that track your effort, you pretty much need to use a power meter. If you are, say, trying to lose weight by managing calories and you use some of the computers and their algorithms, you're going to gain weight at a rapid pace by using some of the methods out there.
J.
^this.
J.
J.
Non omnino gravis
Likes For DrIsotope:
But that's the thing, I do have a power meter so why doesn't RWGPS just use that number? And when I rode without the PM I got a high number, but with the PM it estimated a low number? It just doesn't make sense. In any case, I take all of it with a grain of salt. I did a calculation last year, added up all of my calories, divided by 3500, and it was the exact amount of my weight loss. 3500 is an approximate amount of calories in 1 pound of fat. I'm sure you could pick this apart, but on a ballpark calc it was close enough to reality. This assumes too that my diet is perfect, just enough calories to get me through the day without gaining or losing weight. I made no such attempt to keep my diet that way.
When I looked at this a few years ago, Cyclemeter on the iPhone was about 2X what Strava was saying. Garmin, Wahoo, all were somewhere in the middle. They were worse without either an HRM or a power meter and progressively got better as each of those were added but still were higher than Strava which I think is closer to accurate. At this point, I pretty much ignore any calorie number in anything other than Strava (which was the most conservative of all) but still just think of that as more of a figure of merit than anything accurate.
If you mean adding up the calories shown on the bike computer and dividing by 3500 - if that matched anything it was pretty much pure dumb luck.
I agree with this.
Bikes: Nashbar CR5 Ultegra, Trek 2300
Quoted: 14 Post(s)
I maintain a ride database that captures three different and probably totally inaccurate calorie burns. One source is a heart rate monitor, the second Ride With GPS, and the third a formula I found somewhere on the web. Granted, none of the three are probably very accurate but the trend data for similar rides could have value. Surprisingly, the HRM and RWGPS numbers are usually extremely close, frequently within 75 cals for a two hour ride. Both devices probably use a very similar but still inaccurate algorithm. A power meter would be the gold standard but I don't put out enough watts to light a refrigerator and can't justify the expense. In any case, the scale doesn't lie.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
HRM based calories are not as accurate as an power meter but those who claim that the numbers are completely useless fail to recognize that it is an order of magnitude tool. Uncertainty is a given for order of magnitue tools and estimates. The claim to absolute accuracy isn't made and the numbers can be useful as an estimate, especially in the beginning of a project or effort, for trending or to keep track of diet and exercise for the sake or consistency.
Personally, I don't care if the numbers are 20% or even 50% off as long as they are consistent and the bathroom scale agrees. Once I've lost (or gained) some weight I begin to understand how much I can eat and how much exercise I have to do to lose, gain or maintain weight.
-Tim-
The idea of trending is important and the fact that the HRM and RWGPS are close is interesting.
-Tim-
-Tim-
Non omnino gravis
As of the latest firmware (that is, just this week,) Wahoo apparently now discards power data entirely in their calorie calculations. With the Bolt, if my avg. heartrate is less than 65% of max, kcal expended is derived by using an algorithm based on basal metabolic rate:
BMR = 66 + (13.7 * weightKg) + (5 * heightCm) - (6.8 * ageYears)
As my chest strap HRM is a few years old, it can sometimes take about a mile or so to connect with the head unit, so I get absolutely nothing for the first mile-- the kcal screen will just sit on zero.
So combining HR data with dumb algorithms results in me burning absurdly low amounts of calories-- yesterday was 34 miles w/ ~1,000ft of vertical @ 16.8mph: 1,168kJ, 845kcal, or 25kcal.mi.
Today was an even more leisurely 22.5 miles w/ 659ft @ 15.9mph: 723kj, 587kcal, or 26kcal/mi. I climbed less, went slower, and burned more per mile.
So this is great for people without PMs, and not so great for people with. Either that or I've become really, really efficient. I'm wondering what the Bolt does if I just leave the HRM at home.
Quoted: 871 Post(s)
Liked 726 Times
I switched from a Garmin Edge to a Bolt this year and noticed ludicrously higher calorie estimates. I have a PM and every other platform agreed within a few percentage points on my rides. The Bolt's estimates are more than 50% higher. Plus I found out that platforms like Strava will now just blindly accept the Bolt's figure. Thanks, Wahoo.
Non omnino gravis
J.
Non omnino gravis
Wahoo has had a real bad string of firmware updates lately, but none so bad as this. I’m going to leave the HRM at home on Saturday and see what happens. I think Strava defaults to the kJ from the PM for calories/work done, and only uses the HR data for Relative Effort (formerly Suffer Score.) I’m curious as to what’s going to show up in the Wahoo companion app.
Quoted: 941 Post(s)
Liked 319 Times
Non omnino gravis
From Wahoo Support:
"We have not changed this algorithm for several years, so if something changed recently, it's probably due to something changing on the Profile page of the app. I would recommend logging out and back in to the ELEMNT app and then updating your profile metrics (height, weight, heart zones etc).
We are currently working on a calorie algorithm that utilizes KJ data, but for the time being your best bet is either to make sure your heart rate zones are correct, or to simply use the KJ number (plus 10 or 15 percent) for your calories burned."
Nice try Wahoo, but your magical algorithm magically agreed with my PM for more than a year, now just all of a sudden decided I'm super efficient? Their response also utterly ignores the fact that when the data gets imported into say, Apple Health, Health just takes it for what it is, high or low. I cannot believe that Wahoo has never used the PM for calorie data. I looked at a few rides from previous weeks, and it was not uncommon for the Wahoo calories to be within 1% of the kJ total-- yet I've never had one of those instances where the kcal number is stratospherically higher than the kJ.
