All City 612 Crankset and BB (stuck square BB)
Old 04-22-20, 06:54 PM
somepetalhead
Bikes: CROSS CHECK SZ 52 / MEDICI GT
Quoted: 24 Post(s)
Liked 19 Times in 9 Posts
So im having extreme difficulty getting the drive side bottoms bracket to budge. i have the PT BBT-22 and feel I might strip or slip off that bihhh...
Any tricks or videos one could hip me too... (been trying to stay out of the bike shop and learn how to breakdown everything myself... so far it seems im failing with this BB!)
Thanks in advance.
somepetalhead is offline
Old 04-22-20, 09:18 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3870 Post(s)
Liked 2,563 Times in 1,577 Posts
I use an M8x1.0 bolt plus some washers to hold the tool onto the BB when I really need to give it the business. Also, make sure you're turning it the right way.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 04-23-20, 07:37 AM
somepetalhead
Quoted: 24 Post(s)
mmmm i've read something like this before... although im not that much of a mechanic. is there a video out there that could assist (my knowledge of tools is limited)
thanks
Old 04-23-20, 08:31 AM
Scrodzilla
Your cog is slipping.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 100 Times in 58 Posts
You don't need a video. Just put an M8 bolt through your BB cup tool, securing it to the spindle & cup.
Scrodzilla is offline
Old 04-23-20, 10:06 AM
TugaDude
TugaDude's Avatar
Quoted: 586 Post(s)
Liked 612 Times in 447 Posts
What Scrodzilla said. You can also use a vise to hold the tool after you've secured it with the M8 bolt. You can then grab the frame and turn it instead of turning the tool. This will give the leverage you need. As was pointed out by ThermionicScott, make certain you turn in the proper direction.
TugaDude is offline
Old 04-23-20, 10:54 AM
TejanoTrackie
Veteran Racer
TejanoTrackie's Avatar
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 763 Times in 431 Posts
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
Old 04-24-20, 07:59 PM
somepetalhead
Quoted: 24 Post(s)
thank you sir...
Old 04-24-20, 08:00 PM
somepetalhead
Quoted: 24 Post(s)
https://www.instructables.com/id/Sei...acket-Removal/
this right here worked for me.
The Retrogrouch: Removing An Extremely Stuck Bottom Bracket
this was also helpful but the first link is def more descriptive and to the point. at least for the BB I have atm.
gracias to all on the wisdom.
