For the love of English 3 speeds...
#9851
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
I know this isn't exactly a 3 speed, but I figured this was the best thread for this. This is a Raleigh Sprite with a SA S5 hub stamped 69 on it. A guy who was tearing down a shed had this bike in it for the last thirty years and passed it along to me. It's dusty but the frame should clean up nicely. It looks like the pedals and the grips are not original. Does anybody know what the originals would have looked like and where to find vintage pedals and grips for this bike? Also, I don't seem to find too many different examples of this model when doing a google image search. Is there not much interest in the 5-speeeds or are they just uncommon?
I don't know much about these, but I think that it'll have a lot in common with a 3-speed Sports, except for the rear hub, obviously. I can't imagine that pedals and grips are going to be any different.
#9852
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
Thanks guys, multiple, for the info, I appreciate it.
I had a duh moment on the front bracket, yes indeed it is for a headlamp. I will just need to find the bracket for my Miller lighting set (I have the head lamp, tail and dynamo and original wires but not the correct clamp).
I will definitely look at the B72. The reason I was thinking B17 is that I have the bike set for aggressive riding (I know, I know, yes, yes) and since I have a moderate forward lean on it I was thinking a B72 might be too wide. BTW, I am not leaned over nearly as much as on my road bikes or even my Surly CC, comparatively I am quite comfy on it. I may look at locating a bigger frame in a salvage bike. I realize that the swept back bars of these English cruisers allows a longer top tube than I would ride on a performance bike (all of my bikes have a tt of 22 plus or minus) and this Raleigh Sports is right in there. But yes, I will study on that.
1. I do not know how to adjust the hub. I am pretty good with derailleurs but have never been in a 3 speed hub. When I am trying to get first there does not seem to be any give in the chain coming from the hub?
2. Also, I was indeed going to install the Miller lighting set, it does work but is heavy?
#9853
Bikes: 2014 Cannondale Synapse Carbon 4 Rival; 2014 Cannondale Trail 7 29; 1972 Schwinn Suburban, 1996 Proflex 756, 1987(?) Peugeot, Dahon Speed P8; 1979 Raleigh Competition GS; 1995 Stumpjumper M2 FS, 1978 Raleigh Sports, Schwinn Prologue
Quoted: 213 Post(s)
#9854
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
The Miller light set is almost identical to some of the SA lighting sets. I think it is built a little better and it is slightly heavier. You can find mounting brackets on ebay to fit the headlight that will allow you to use that 'thing' on the headset.
#9855
I won't go into all the specifics here about how to adjust the shifting on a 3 speed Sturmey archer hub, but if you do an online search for it you'll find a page by Sheldon brown. Basically when your shifter is in the middle position, look through the hole in the drive side axle nut, which projects beyond the frame where the indicator chain enters. The indicator chain is connected to an indicator pin which is inside the axle and screwed into a clutch. Anyway, when shifter is in middle position the shoulder of that pin should be even with the end of the axle. You may have to use a flashlight to see.
If you search online and see some photos or diagrams it will make better sense.
Go here and scroll down to "cable adjustment"
https://sheldonbrown.com/sturmey-arch...tml#adjustment
#9856
Count Orlok Member
Pedals are probably regular rubber block pedals. Many bike recyclers have old Raleigh parts and may have pedals and grips.
If what you have works and is comfortable, keep it.
Although not that common, the S5 is an excellent hub, but the shifters are the weak point. I've met a few people who have S5s, and most have changed out the shifters and just use regular triggers on the bars. Is yours an S5, with a bellcrank on the left, or an S5/1 or S5/2, with toggle chains on the left?
About the Sturmey-Archer S5, S5.2 and AT5 Wide-Ratio 5-Speed Bicycle Hubs
#9857
Quoted: 1299 Post(s)
Liked 103 Times
Inflate Hard
Inflate Hard
#9858
Bikes: 1962 Raleigh Sports, 1968-72 Triumph 10 Speed, 1972 Raleigh Ltd 3, 1974 Raleigh Tourist, 1976 Peugeot UO-8, 1980 Bridgestone Kabuki Submariner 12. 1986 Fuji Sagres .
Quoted: 7345 Post(s)
Liked 2,452 Times
I've had my 69 Sprite on the road for two years now and I LOVE the S5 hub! I could go on and on about it, but there's one thing I'd like to tell you right away. If you find that the bike shifts poorly, don't blame the hub. It's the shifters that stink. I did my best to get along with the original stick shifters, but they are just plain bad. My bike shifts perfectly now with a regular 3 speed trigger on the right and a SunTour handlebar friction shifter on the left for the bell crank.
I like the S5, too. It works well. Range is slightly greater than that of the AW hub, and gaps between gears are slightly smaller.
#9860
Liked 103 Times
Glad I did though. That granny gear is nice to have on a 34 pound bike.
Inflate Hard
Inflate Hard
#9861
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 439 Times
#9862
Quoted: 278 Post(s)
Liked 71 Times
Three more questions.
1. How do I remove the grips without destroying them, heat gun?
2. Running the wires for my front/rear dynamo, how is the headlamp wire typically routed (obviously zip ties were not around)?
3. Spokes, I know I asked once in part already, is there not a suitable replacement?
That square lantern is really a cool piece!
Thanks.
Thanks.
#9863
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
#9864
Liked 439 Times
#9865
Bikes: 73 Raleigh Grand Sports
Quoted: 5 Post(s)
Thanks for all the info on the S5 hub. Mine has the TT shifters, although one of the black knobs is a little chewed up I'm not too concerned with it. Just cleaned the dirt off of it this evening it looks like the paint has held up nicely. I know there will probably be various preferences, but what polishing compounds work best with these Raleighs?
#9866
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
#9867
Count Orlok Member
Thanks.
Thanks.
2. The traditional method involved clips for the wire, or wrapping around the fork or frame, or both:
3. Not sure what you mean. You can use modern stainless spokes, but you'll need spoke washers, as per Bikesmith. I've used DT.
Remember to use spoke washers, if you use modern spokes. They have larger radius bends for modern, thicker hub flanges.
For DT spokes I use 2 washers under the heads of inside spokes (head on the outside) and one for outside spokes. For Wheelsmith I use 3 and 2.
Sun CR-18s are the only alloy rim in the 3 speed size, 26 x 1-3/8" (590 etrto) available in the US, 32, 36 and 40. Raised center "Westrick" steel rims have the same ERD, so you can reuse the spokes if they are in good shape. With flat center "Eastrick" rims you are out of luck.
#9868
Quoted: 278 Post(s)
Liked 71 Times
1. I usually use a pick or small screwdriver to work under the edge so I can get the straw of a can WD40 under the rubber. Spray a bit in and try to work it around.
And, pretty cool but the rear light, well, it lights up nicely and the front light does as well. But, I will have to find a bracket for it to mount to the Raleigh "thing" on the front.
On the Sports in your photo, I notice the brake pads are nearly full down in order to engage the rims, mine are mid way. Did Raleigh source different length brakes from year to year?
#9869
Count Orlok Member
#9870
Phyllo-buster
Quoted: 2296 Post(s)
Liked 2,046 Times
Edit. that Sports is older with very different generation of parts and maybe slack geometry, brake bridge position, fork length. Calipers could be designed for range of frames.
#9871
Quoted: 278 Post(s)
Liked 71 Times
Some 3 speed clamps for brake cables will have a little bump for routing wire. I can't find a picture and I'm too lazy to go out to the garage now.
I just stole that pic off the interwebs. I don't know that Raleigh sourced much of anything until sometime in the '70s--they built just about everything in house.
In working on this bike, I have found some odd bolt/nut sizes that do not correspond to SAE or Metric wrenches. . Since in one of my careers I was/am an A&P mechanic, I have a surplus of tools, somewhere around the value of some people's houses alone, and yet I had to dig to the back to find some British Bastard wrenches and Whitworth. And still it does not fit!
#9872
Liked 439 Times
#9873
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
I still have this idea of building a super-light 3-speed with some hot-rod touches. That said, the big shifter probably does not fit with the super-light concept. Oh well, this will be a project for next winter, so I've got plenty of time to figure it out.
#9874
Liked 2,452 Times
For removing grips, I prefer water or something slimy like soapy water. You can spray Fantastik or something similar. This stuff dries a lot faster than WD40.
You can attach dynamo wire with silicon glue. Secure it temporarily with zip ties until the glue dries. This way, you can put the wire on the inside of the fork and make it nearly invisible.
#9875
Abuse Magnet
Quoted: 151 Post(s)
Liked 174 Times
Also, there doesn't need to be a continuous bead of product along the length of the wire...1/4" blobs every three inches or so is sufficient.
